Question about D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point
ADD ANOTHER COMPUTER TO WIRELESS NETWORK USING d-LINK
I need to set up another computer to access the wireless network. How do I do that?
  • Ahsan Burhany
    Ahsan Burhany May 11, 2010
    you need to set up another computer to access the wireless network, it means another already connected, am i right?
    so, just makes network setting replication with the computer that already connected.
    feel free to ask me more :)
    Genius:
  • 1,224 Answers
Buy a wirless router
i see that now t-mobile is selling them for 89 in there stores check it out
Posted on May 21, 2008
Bridge will not find router
Setting up a wireless router with a Windows client can be complicated.
There are a number of measures and options that have to be understood, and it's all too easy to make a mistakes--but D-Link provides an easy-to-walk-through configuration system to help you set up your D-Link wireless router.
Plug one end of the Ethernet cable into the DSL modem.
Then plug the other end into the "WAN" port on the back of the D-Link wireless router.
Connect wired computers to any of the other Ethernet ports on the router using another Ethernet cable.
Access the D-Link Configuration Screen
Open your web interface and type "http://192.168.0.1" into the address bar, then hit "Enter" or "Return."
Use "Admin" as the username and leave the password blank when the login screen appears.
Click "OK." You should now see the D-Link configuration screen.
Set Up General Security
Change your administrative password by clicking on the "Tools" tab and choosing the "Admin" button. Enter a new password under the "Administrator" heading.
Confirm it, and click "Apply."
Disable the wireless Local Area Network (LAN) if you don't need to use the wireless access and you want to make sure no one else is able to access your network.
Under the "Home" tab, choose "Wireless" and select the "Off" option.
Enable Wireless Encryption Protocol (WEP)
Locate the "Home" tab in the D-Link Configuration screen, and click on the "Wireless" button.
Use the "Open System" button beside "Authentication."
Select the "Enabled" button next to "WEP," and set the encryption key to "128 bit."
Set the "Key Type" to "ASCII" and choose a 13-digit password for the "Key 1" field.
Write down the password in a secure location.
Click "Apply."
Change the SSID
Change the SSID to make it more difficult for others to locate and use your network by clicking on the "Home" tab and locating the "Wireless" button.
Change the default SSID to one of your choosing, then click "Apply."
Disable SSID broadcasting.
Under the "Advanced" tab, click on "Performance" and check off the "Disabled" box. Again, click "Apply."
Filter MAC Addresses
Click the "Advanced" tab in the D-Link "Configuration" screen and select the "Filters" button.
Choose the "MAC Filters" and click on "Only Allow Computers with MAC Address Listed Below to Connect to the Network."
Enter the name and MAC address of the computers allowed to access the network, beginning with the one you are currently configuring.
Click "Apply."
Mar 18, 2014 | D-Link DAP-1522 Xtreme N Duo Wireless...
Problem with D-Link 1360 n access point. Not able to visit ip address 192.168.0.50
The internal Wi-Fi radio is enabled by default on most new wireless routers.
However, if you purchased a D-Link router used, you may find that the internal radio is disabled because the previous owner had an exclusively wired network and wanted to eliminate the possibility of a hacker breaking into one of her computers.
Enable the Wi-Fi radio on your D-Link router to enable your computers to connect to the Internet wirelessly.
Connect the router to your computer using an Ethernet cable.
Open a web browser and browse the IP address "192.168.0.1."
Enter the username "admin" and leave the password blank.
Note that these are default values; both the user name and password can be changed.
Click the "Setup" tab at the top of the screen, then click the "Wireless Settings"
Scroll to the bottom of the screen and click the "Manual Wireless Network Setup" button.
Place a check in the box labeled "Enable Wireless" and click "Save Settings."
Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamationmark! or a red Xright click install drivers.
The driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
If you cant install the driver
Make sure you Ethernet/internet is enabled in biosrestart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigateto integrated peripheralslook for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its
"Enabled"ima
D-Link Wireless Router
D-Link routers use the connection from your Internet service provider to create a wireless network for the various Wi-Fi- enabled devices in your home or office.
Once the router is installed, you can truly enjoy the portable capabilities of your laptop or other wireless device.
D-Link routers have a straightforward installation process, despite the advanced technology behind wireless equipment. So there is no reason to wait around for a technician to help you install your wireless equipment. Remove the cable that is attached to the "Internet" port on the rear of your DSL or cable modem.
Plug the Ethernet cable into the "Internet" port on the modem and plug the other end of the cable into the "Internet" port on the rear of the D-Link router. Attach the power adapter to the port on the rear of the router and plug the adapter's cord into a outlet.
Remove the power cord from your modem and wait 10 seconds before plugging it back in.
This will reinitialize your modem and force it to establish a connection to the D-Link router.
Your router will immediately begin distributing a wireless network with the "D-Link" network name.
Connect your computer to one of Ethernet ports on the rear of the router and open a Web browser.
Type "http://192.168.0.1" into the address bar and press "Enter." Enter "admin" into the username field and type "admin" again into the password field.
Click "OK" to open the wireless configuration page. Click "Wireless Security Setup Wizard" to create a wireless password for your router's network.
Click "Apply" to save the changes to the router's settings.
Network D-Link wireless
Type the router IP address, "192.168.0.1", into your Internet browser. Press "Enter" on your keyboard.
Enter your username and password to log into the D-link configuration panel.
By default, the username is "Admin" with a blank password field.
To prevent outsiders from being able to access your D-link router's configuration panel, change the username and password to something more secure.
This can be done by selecting "Tools" from the menu and selecting "Admin."
Select "Administration Settings" and enter your new username and password.
Save your changes by clicking "Apply."
Enter the IP addresses for the computers you want to give access to your router.
You can do this by clicking the "DHCP" link underneath the "Home" tab.
Click "Apply" to save the IP addresses.
Select the "Wireless" link underneath the "Home" tab.
Enter a name in the "SSID" field to identify your wireless network.
Choose "WPA" for your "Security" option.
WPA will provide the highest level of security for your wireless network.
Create a WPA password to access your wireless network.
For maximum security, enter a combination of numbers, letters, and symbols.
Store your password in a safe place in case you ever forget it.
Click "Apply" to save your settings.
Install a software firewall program on your computer to add an additional measure of security for your wireless network.
A few of the popular firewall programs available are Norton Antivirus, McAfee and Zone Alarm.
Mar 18, 2014 | D-Link Wireless N Access Point Dap-1360 -...
Ll i need to put password to my accese point (dlink) please tell me how ?
There are a number of measures and options that have to be understood, and it's all too easy to make a mistakes but D-Link provides an easy to walk through configuration system to help you set up your D-Link wireless router.
Click "Apply." Change the SSID
Disable SSID broadcasting. Under the "Advanced" tab, click on "Performance" and check off the "Disabled" box. Again, click "Apply."
Enter the name and MAC address of the computers allowed to access the network, beginning with the one you are currently configuring. Click "Apply."
Feb 19, 2014 | D-Link DAP-1522 Xtreme N Duo Wireless...
No puedo intalarlo
The Zero Configuration Utility built into Windows XP may vary depending on if you have installed Service Pack 1 or not.
Download Service Pack 1 here.
Without Service Pack 1
Step 1 Right-click on the two computer monitor icons in the system tray and select View Available Wireless Networks.
Step 2 Highlight your wireless network which is the SSID of your wireless network (if you are connecting to a D-Link router or access point it will be default) and click Connect.
Step 3 If you do not see your wireless network in the available networks box click on the Advanced button. Select Add and type in the SSID of your router or access point, uncheck this computer is connected in and ad-hoc peer-to-peer network, and then click OK.
With Service Pack 1
Please read here regarding Service Pack 1 and disabling the SSID Broadcast.
Step 2 Uncheck the Allow me to connect to this wireless network even though it is not secure box. Highlight your wireless network (if you are connecting to a D-Link router or access point it will be default), and click Connect.
How Do I enable Encryption using the Zero Configuration wireless utility?
Jan 18, 2011 | D-Link AirPlus Xtreme G DWL-2000AP...
Need disc for dynex dx-wegrtr
You can confiure your without disk too .
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 07, 2010 | Dynex Enhanced-G Wireless Broadband Router
How to configure a D-link access point DWL-3200AP
http://192.168.0.1
or
http://192.168.1.1
Jun 02, 2010 | D-Link AirPremier DWL-3200AP 802.11g/b...
Enable security on wireless network
You can secure your wireless network wit WEP or WAP code.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
May 06, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
My question is ''thes settings saved on this computer for the network do not match the requirements of the network'' how to connect the wireless internet on my computer now? PLEASE see
See there are some old settings saved on your computer for the same wireless network name.
I believe the operating system on your computer is windows VISTA / 7 .
Now you will need to remove the network from the preferred network list. then add the new network on your computer and you will be able to connect to the network. Make sure that you have all the wireless settings of your network. If you are not sure about the wireless settings of your network then you will need to check the wireless settings of the network.
Apr 08, 2010 | WiFlyer - Portable, shareable WiFi base...
I forgot my user mname and password for my wifi connection
For know your security key Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
The old password is in * or # format so you need to enter new password.
Let me know if you need furhter assistance.
Mar 26, 2010 | WiFlyer - Portable, shareable WiFi base...
I forgot the password of my dwl-900ap+ and can not connect additional pc to the wlan. Help
http://192.168.0.1
or
http://192.168.1.1
Jan 10, 2010 | D-Link Air DWL 900AP (DWL-900AP) 802.11b...
D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point Logo
1,678 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
