Question about Samsung Televison & Video
Unit runs for approx 40 mimntes then starts changing channels by itself and when in av mode switches of ever 10 minutes or so and has to be reset
  • Samsung Master
  • 8,617 Answers
I would need your model number in order to help you with your problem
Posted on May 21, 2008
Need installation instructions for GVA 100 set top box
Just bought one of these cheap.
Very basic just plug in and it sets itself up to some degree.
- make sure tv is on appropriate AV channel as you'll need the on screen menu to set it up initially using the remote control.
- then set the unit to scan for the tv channels, took about 10 minutes for me.
- NOTE ... there is no power on/off switch. Plug the cord into the 240v outlet and unit comes straight on. You can't turn it off except by switching offf at power point. Or using the standby button on the remote.
- NOTE ... there is also no display on the unit. So yoy have no channel display on the unit. It is all done on the tv screen.
But it does have quite a good EPG and menu guide.
For the price, can't complain.
Jun 04, 2011 | Televison & Video
Jvc model av36f702 it jumps of evry time im trying to put it on with the remote . i tink the timer is set to 0 secones .can i reset the tv.
press display button & it shows the following
NOW 12:20 PM
• The current channel or AV input (Channel 07)
• The current time (12:20 pm)
• Sleep Timer status/minutes remaining (The Sleep Timer is off)
• On/Off Timer status (Set to turn on everyday at 7:00 PM, off at 10:00 PM)
• Each Press of the DISPLAY button changes the display mode:
Press the SLEEP TIMER button & set it to OFF
Dec 22, 2010 | JVC AV-36F702 36" TV
Tips to operate without remote
You might try hitting the MENU button on the tv itself to see if you are able to select input / source that way. Some TVs also have the Aux Inputs selected by scrolling through the channels until you come to the aux inputs.
Jun 22, 2010 | Prima C2012 TV
Unit comes on and runs for 5 minutes, the circuit trips off
30 is the correct size breaker for this unit. It sounds like there is a grounding issue going on in the system. Or off of the Thermostat. Something is grounding out causing the switch to trip. Are you running #10 wire to breaker and the unit? If not you will need to increase your wire size
Jan 03, 2010 | Dayton D-F79 Electric Space Heater- the...
Limited recording time
WS-100: 64 MB
HQ mode: Approx. 4 hours 20 minutes
SP mode: Approx. 8 hours 40 minutes
LP mode: Approx. 27 hours 20 minutes
You can go to the menu of the device and change the recording mode from HQ to SP to get longer recording time. Page 7 of the instructions explains how to change this.
Mar 19, 2009 | Olympus WS-100 Digital Voice Recorder
Universal remote works for basics but won't change input
good day , what button can you see infront of your TV screen?
Not familiar with this model but if you'll manage to locate a button marked as "TV/AV" or "AV" press this button until it the display switch to A/V mode (audio/video). Or if this is a really old model, from Tuner mode or channel model. set the channel station to 1 then press the " - channel " button and see if it will change from tuner mode to A/V mode
Jan 31, 2009 | Toshiba 32A33 32" TV
Ok here is a small checklist for you before going into panic mode.
  1. Most combo DVD/VID players will have a button on the face of the unit for switching between DVD & VIDEO, ensure this is set for the correct mode of operation.
  2. AV channel on TV's come in several different modes for multi outlets on the TV itself (ie: it may have more then 1 outlet for AV - rear, side & front on some TV's) ensure you have the correct AV channel selected.
  3. Check the connection configuration in your user manual, there may also be incorrect connection to the TV or Unit itself.
  4. The yellow lead usually is the Video lead ( this is for both modes DVD & VIDEO ), this is the one that is most likely incorrectly connected. Double check where it needs to go. The correct lead & socket should also be yellow if this is the case.
  5. AV in and AV out - Make sure you check both on the TV and the unit for the label AV IN and AV OUT, this is the most common connection error, it should be AV OUT from the unit > AV IN on the TV ( mostly the rear connection points will have this as with the ones on the rear of the unit )
  6. One other possible scenario is that you are not using AV leads ( commonly referred to as RCA Leads ) - you may well be using 5.1 connections ( All in one bundle that connects directly to the back of the unit and also the TV. This usually eliminates connection errors as it has several smaller pins in either end that connect at both ends. It is highly unlikely that these are incorrect in any case. This would most likely only be on the incorrect TV channel selection. Ensure you are on the correct one by cycling the channels with the unit playing either DVD or VIDEO.
  7. There can be other scenarios that will make your life difficult, however i feel in the majority of cases, the ones described above are the most common offenders.
  8. Other then this, perhaps consider having the unit checked by a professional ( to ensure it works normally ) this would confirm if either the unit is faulty and needs repair or the connections are incorrect.
Hope some of this helps, as most of these problems can be solved on the spot with a quick visual, however seeing your current setup is not possible and these tips are the most likely to help. Trust you find it's something simple of this nature.
Jan 22, 2008 | Televison & Video
SHR 1040 "Froze Up"
You can try holding down mode and channel 2 at
the same time for 10 secs. This should reboot the recorder.
Dec 23, 2007 | Samsung 4 Channel Dvr
Short cycling
The most common cause is the fan relay on the main circuit board. However, if the outside temperature is 30degF and the inside is 60-65degF then the cause could be the insulation is ruined or missing on the backside of the unit's firewall. This can cause the unit's internal thermocouple wire to read below 45degF which is the freeze sentinal temp level. Anything below this temp level will cause the unit to come on for a few minutes to warm up the air and bring it to 46degF or higher to protect internal plumbing from freezing.
The best way to check for this is to manually set the unit to one of the heat modes and the thermostat up just until the heater comes on. Let it run until the unit turns itself off. Then set the mode switch back to Off and see if the unit still cycles on and off as before.
If it does then the main circuit board should be replaced unless you are comfortable de-soldering and re-soldering another fan relay in place.
Dec 20, 2007 | GE Zoneline AZ38H12DAD Split System Air...
Can't shut off closed caption
I have the JVC I Art 46" TV. The Close Caption was turn on accidentally by my grandson. After lots of searching for the original remote. I called JVC Customer Support. He told me to change the Close Caption settings to CC2 and T1. That fixed the CC without having the original remote.
Apr 10, 2007 | JVC AV-32F704 32" TV
Televison & Video Logo
23 people viewed this question
Jerry Greenberg
Jerry Greenberg
