Question about Dell OptiPlex GX150 SF PC Desktop
Install new hard drive
Could someone please tell me or direct me to an installation guide for a new hard drive in my old Dell Optiplex GX 150?
If all that you are doing is replacing the hard-drive then you only need to do the following as the Dell cases are a screwless design and only require you to:
  • pop the case open,
  • disconnect the drive and power cables, (noting these for reassembly later)
  • push the green drive rail tabs inward toward the drive, and
  • remove the drive from the case.
Next you'll need to replace the hard drive.
Tools needed:
  • Philips head screwdriver, or
  • Nut driver.
Procedure:
  • Take the old hard drive to a flat space, ideally a workbench and unscrew the four mounting screws from the drive rails.
  • Take your new hard drive out of its Anti-Static bag and begin to put the drive rails back on the new drive.
  • If this is the only drive in the PC I suggest you set the drive to being the Master drive on the IDE bus. If you do not know what this means google the drive model (on the label on the hard-drive) and you'll find details of how to set up the drive to be the master on the IDE bus.
When the above procedure is complete you'll need to re-insert the drive back into computer case. That is simply reversing the procedure you used to take it out of the case.
Finally you'll need to reboot the computer and go into the BIOS to ensure that the drive is being seen and is of the correct size.
Lastly you'll need to pop in the OS CD-ROM and rebuild the system.
Note that on some of the early GX150's there was a problem with the firmware of the CD-ROM that allowed you to load the OS, reboot and then the installation would hang as the OS could not read the hardware due to an incompatibility. This can be solved by simply replacing the GX150 CD-ROM with another CD-ROM during the build and then putting the old CD-ROM back in place after the final reboot of the PC before you log on for the first time.
Hope this is of some help from a newby solution provider.
Sincerely
Andrew Martin
Posted on May 21, 2008
Windows 7 has been installed in my optiplex gx 240 pc but this is no drivers for sound , lan drivers to fix the problem
Go to the Dell support site on another computer,and look for drivers for you computer model. Download them on a usb drive or on an SD card and install them on you Optiplex computer.
Sep 22, 2013 | NEC Black Nec/dell Optiplex Gx-150/240 Ide...
Install a new harddrivw on the optiplex gx620
Two wire are needed to attach a new hard drive.
Please refer to the links below ,to see how the attaching cables looks.
This cable is connects Hard drive to Motherboard
SATA Data Cable
This cable connects Hard drive to Power Supplier
SATA Power Cable
Jun 07, 2012 | Dell OptiPlex GX620 PC Desktop
Sir how two install a audio driver for dell optiplex gx 520?
If you go to this site, you can get all of the drivers for the Optiplex GX 520. Please make sure you select the correct version of Windows that you are running (Windows XP, Vista, or 7). Then, select "Audio" from the drop-down list, and download the driver for ADI 198x Integrated Audio.
If you're running Windows XP, you can just click here to go directly to the driver download.
Once you download the driver, just double-click the file to start the installer.
Aug 09, 2011 | Dell OptiPlex GX520 PC Desktop
Hi, my dell optiplex gx 150 was infected by multiple viruses so i decided to re-install xp booting from cd. after copying all the files from the cd and the pc restarts, its failing to continue installation...
1.You have a corrupted boot sector on your hard drive.
2.you will need to format the drive and then re-install the Operating System.
3. If you are not able to do this then a new hard drive is needed.
4. install a anti virus program after installing the operating system
Feb 08, 2011 | Dell System Board for Optiplex GX 150,...
I have a dell optiplex gx 620 put in with new wd sata 500gb hard drive but will only show 130 gb
maybe the hard drive is not yet recognized by the system. try to reformat your hard drive by using disc management. got to control panel, performance and maintenance, administrative tools, computer management. under storage, click disc management, right click on the new hard disc drive and click format.
Sep 06, 2010 | Dell OptiPlex GX620 PC Desktop
I the video drivers for this desktop computer optiplex gx 150 dell
All your Dell Optiplex drivers can be downloaded and installed from this link providing you have the original hardware. http://support.euro.dell.com/support/downloads/devices.aspx?c=uk&cs=ukdhs1&l=en&s=dhs&SystemID=PLX_PNT_P3C_GX150&os=WW1&osl=EN
Hope this helps FixYa! If you find this information helpful, please leave us some positive feedback to let us know.
Apr 08, 2010 | Dell OptiPlex GX150 PC Desktop
We need dell optiplex gx 150 drivers
Direct from Dell:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PLX_PNT_CEL_GX270&os=WW1&osl=en&catid=&impid
Apr 01, 2010 | Dell OptiPlex GX150 PC Desktop
My hard drive crashed on my dell optiplex gx 60 i got a new hard drive but now it wont reconize my cd rom so i cant figure out how to install windows
Hi
Please try the following
Click on F12 or del tto enter bios setup when you first switch the power on
go through the options until you find Boot sequence
Choose the CD rom drive from there and ensuring the CD is in the drive save the settings and restart this will allow the CD drive to be picked up
Please can i ask that you leave feedback and vote if this has been useful
Feb 11, 2010 | Dell Optiplex GX60 PC Desktop
Installing a sound card into my Optiplex GX260
Hi
OptiPlex GX260 can be Small Form-Factor, Small Desktop or Small Mini-Tower. Compatibility with PCline 5.1 PCI depends on the profile of the PCI Card and the Profile of your OptiPlex.
GX260 Small Form-Factor is compatible with Low-Profile PCI Cards only. GX260 Small Desktop and Small Mini-Tower are compatible with standard PCI Cards. (Small Mini-Tower however uses a PCI Cage).
Check OptiPlex GX260 Systems User's Guide - http://support.euro.dell.com/support/edocs/systems/opgx260/en/ug/index.htm
From here you visualize the 3 form factors. Also there is info and steps to install PCI cards.
NB:
1. Generally, upmarket PCI cards are standard height. Some manufactures supply a metal piece to allow it to be used in Low-Profile or Standard Profile.
2. Driver software needs to be installed after the hardware is installed.
Mike
Apr 12, 2008 | Dell OptiPlex GX260 PC Desktop
Computers & Internet Logo
122 people viewed this question
Alun Cox
