Question about HP Office Equipment & Supplies
We have an HP C6280 All-In-One PCS and it will no longer copy or scan. Also, it won't turn off consistently. Happened out of the clear blue... It still prints online. Thanks, Marcia
  • 3,037 Answers
The first thing to always try is a hard reset, try unplugging it for a minute and replugging it in and see if it starts working. Let me know how this goes and we can try getting it to work from here.
Posted on May 21, 2008
  • Benjamin Patri
    Benjamin Patri May 21, 2008
    you can also try reloading the drivers at
    http://h10025.www1.hp.com/ewfrf/wc/softw...
    also make sure that the scanner/printer is still showing up in the control panel.
    you may also try a system restore before this happened by going to Start>Control Panel>Performance and Maintenance>System Restore
    The system restore will not delete anything important and is reversible. Also since the copy function isn't totally related to the computer, the above may not help at all but is still worth a try. Please let me know how this goes and please answer the question I asked in your other thread, thanks
  • Benjamin Patri
    Benjamin Patri May 22, 2008
    http://h10025.www1.hp.com/ewfrf/wc/gener...
    this is what I got from HP
    Follow the steps mentioned on the webpage and check for the
    functionality, however, if the issuer persists, perform the steps
    mentioned below:
    A semi-full reset will do the following:
    The user settings to the factory defaults, Language and country settings on some models.
    Reset the All-in-One to the factory default settings by using these instructions:
    1. Unplug the power cable from printer when the printer is powered on.
    2. Press and hold start black and start color buttons while plugging in the power cord.
HP Photosmart C6280 Scanner not found with Mac Tiger
I'm using a software called VueScan, which has drivers for almost all scanners and works well. Maybe you should test it?
Jan 27, 2014 | Apple Mac OS X 10.4 Tiger for Mac
HP C6280 will not print self test diagnostic
Do you have an Anti-Virus program installed on your PC? If so, can you try and disable it before you print.
for more help visit CBR Tech Solutions
Mar 13, 2013 | HP C6280 All-in-One Printer
Scanner failure cannot copy or scan
Turn off the printer. Clean the Scanner Glass with lint free cloth. Wait till the water dries.
Try connecting your printer directly to wall outlet or different outlet
This should help
Regards,
Sean
Feb 16, 2013 | HP C6280 Photosmart All-in-One Printer...
My HP Photosmart C6280 All In One Printer will copy or scan.....I have uninstlaled the software, downloaded the new software and reinstalled the software several times and this is still happening.....Can...
Its not software issue,for copying you need not required any software, just plug in power & take copy, if copy is not happening, its definitely printer faulty only..
Open flat bed, check scan head,mechanism & cable,if found any breakage in mechanism,scan head or cable, replace it & check..If its difficulty for you submit unit in service center..
Dec 07, 2011 | HP Photosmart C6280 Printer
My HP Photosmart C6280 All in One will not scan or copy.....it comes back as unable to scan or copy. I have reinstalled the full feature software
Its not software issue,for copying you need not required any software just plug in power & take copy, if copy is not happening, its definitely printer faulty only..
Dec 06, 2011 | Office Equipment & Supplies
Device manager will not load drivers for Hp c6280
You might have to load the software for it.Before you begin download the latest drivers and install file for it.Unplug the device start to load the software only plug the device in when you are told by the software,hopefully this should take care of this.
good luck
Sep 17, 2009 | HP Photosmart C6280 Printer
My HP Photosmart C6200 All IN ONE serial # MY7AJH63BB, will not print photos coming from my Mini Mac computer on to the photo paper in the photo paper tray. It will only print onto 8x11 paper sheet. I...
None of the buttons on my 3 in 1 photosmart c6280 work but I can use to HP solution to get prints ,scan , and copy. Can not turn off or clear '! "button with out unpluging
THANKS
Nov 29, 2008 | HP Office Equipment & Supplies
The copier and scanner are not working
hi friend
remove & reinstall u r printer driver
then after try to scan
Mar 31, 2008 | HP Photosmart C6280 Printer
24 people viewed this question
Ben Johnson
