Question about HP Computers & Internet
My laptop won't turn on. I have the AC adapter plugged in but it still doesn't turn on.
  • tinamehl May 21, 2008
    Actually I did that. I took the battery out and let it sit awhile. Then I plugged in the AC adapter without the battery in But it still won't turn on! Then I tried putting the battery back in and the same problem is still there, no power. I bought a new AC adapter and it hasn't made a difference.
  • Mark Williams
    Mark Williams May 11, 2010
    Master:
    Sergeant:
  • 482 Answers
Try takeing out the battery and unpluge the power cord. then put battery back in, the plug power cord back in, and then turn it on.
Posted on May 21, 2008
  • farren wadley
    farren wadley Jan 05, 2009
    You may need a new battery, they dont last verry long. I get every thing on ebay my self and save a lot of money. The battery needs to hold a charge.
Mini dell 910, no power
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
http://www.chargerbuy.com/replacement-dell-inspiron-mini-910-30w-ac-adapter-19v.html
Nov 21, 2012 | Computers & Internet
Gateway laptop won't come on
Possible causes:
Nov 04, 2012 | Gateway MX6027 PC Notebook
My laptop won't boot. It's start and then it turn off by it self.
Possible causes:
1.AC adapter failure.
2.Power jack failure.
3.Motherboard failure.
1.Test the laptop power adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
3.If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Nov 01, 2012 | Acer Computers & Internet
MY ASUS F5VL MOTHERBOARD WON'T TURN ON???
Possible causes:
AC adapter failure.
Power jack failure.
Oct 30, 2012 | ASUS F5VL-A2 Notebook
Computer doesn't turn on. Tried just using AC plug in with no battery but doesn't turn on. When the AC Adapter is plug in there is a orange light on when battery is in and a white light with
If you are still having trouble I would take it to a local pc technician. I have had good luck an UniComputers on 23rd st but its not cheap...
Sep 30, 2012 | HP Pavilion g4-1117dx Notebook
When i plug the charger in the orange battery light comes on and the computer turns off
Try removing the battery from the back and then running it directly through the AC adapter. Sometimes the battery and AC adapter have conflicts and it can cause a laptop to become inoperable.
If this doesn't fix the problem in any way, I would recommend trying a new battery or AC adapter.
hope this helps
Sep 29, 2012 | Toshiba Satellite P200D-11R Laptop AC...
My laptop won't turn on, and the charger doesn't seem to be doing anything. even when plugged in, it won't start. ideas?
You've to replace the ac adapter, if it's brick doesn't get warm or LED does not glow on Power Jack on the laptop. offcourse, check with the wall different sockets
power jack can also be loose. so jiggle the cable to find out.
if notebook is getting power, you can remove the battery, ac adapter, hold and keeep pressing poer button for a minute, then, turn it on.
finally, you can take out hdd and ram, put them back again and turn on the laptop. hope it will help
Sep 17, 2011 | Compaq Presario CQ60-220US PC Laptop
There's seems to be a short where the AC adapter goes into the Laptop. Loose parts in that area of the Laptop where the adapter goes in. It won't turn on. Maybe it's the battery.
Unfortunately, this is a frequent issue with laptops. Being moved around frequently can cause the AC Adapter to pull at the DC Jack on the laptop. If it is loose, it can mean there is a broken connection within the laptop. What you can try is powering the laptop on with it plugged in and the battery removed. If that doesn't work, I'd recommend going to your local Best Buy and picking up a universal AC Adapter. If that doesn't work, you can always return it, even if opened.
Aug 27, 2011 | Acer Aspire 5735 Notebook
I have a toshiba laptop about 2 years old. I didn't use it for a few days and now it won't turn on at all.
was it plugged in when you tried to turn it on?
if not, try charging it for a couple of hours. the battery must be completely empty
other than that I might need more details
Aug 07, 2011 | Toshiba Computers & Internet
Computers & Internet Logo
15 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
