Question about Panasonic CQ-VD7500U Car DVD Player
Power connector diagram
I need to find a power connector diagram. In the 16 pin connector I need to know which pins are for ground and power. I do not have the the power connector I was trying to find the appropiate pins that would turn the stereo on so that I can use a seperate power to see if it works.
You need to buy actual harness. you will fry the unit if you don't, trust me
Posted on Feb 07, 2009
2002 fxdl no power white wire high beam indicator on dash indicates high beam is on still no power
Well, electricity is electricity and wiring circuits are wiring circuits. I do not have a 2002 fxdl electrical service manual either so cannot help there. On a 2003 the white wire goes from the headlight to four pin connector 38B and from there to four pin main harness connector 38A pin 2 and from there to connector 20A pin 4 and from there to (fxdl only) connector 21A pin 2 to connector 21B pin 2 to high beam indicator light which has BK wire ground going to 21 B pin 6 to 21B pin 6 after which it joins other BK ground wires to speedo and to 20B pin 12 and then to 20A pin 12 to TS/TSM pin 12 (ground)
POWER from ignition switch into lighting 15 amp fuse by connector 38 pin C R/BK and out from fuse by BE to connector 24A pin3 and out connector 24B pin 3 BE into handlebar switch then out from handlebar hi/lo switch into connector 24A pin 4 W and then out from 24B pin 4 W to connector 20A pin 4 W (which joins to speedo connector 20B W and also goes to connector 38A pin 2 W which goes to 38B W pin 2 to the headlight high beam element on the right side pin with the low beam element connection on the left side (on the wiring diagram) (Ground wire is also on the (diagram) right side and goes also to HDI position lamp is on the bike and HDI position light power is from connector 38B pin 1 O/W etc.
Connector 20 is a 12 place Multilock is console gauges connector located under the console on fxdl
Connector 21 is a 10 place Multilock console gauges connector located under the console on fxdl
Connector 24 is a 6 place Deutsch left hand controls and horn connector located on the frame backbone
Connector 38 is a 4 place Multilock headlamp connector located on the frame backbone
Jun 19, 2014 | Harley Davidson Motorcycles
Wont commnicate for inspection
Check all the fuses and I mean all the fuses. This is generally caused by the OBD II connector not having power on pin number 16. Pin 16 is the last pin on the shorter row of the connector but, you have to know the orientation. If you look at the connector on the car, READ THIS CAREFULLY, if the connector is wider at the top, the pins are numbered from left to right. The top row is numbered 1-7 and the bottom row is 8-16. If the connector is wider on the bottom, just invert the above instructions. Check to see if the connector has battery power to pin 16 and ground on pin 5. DO NOT GO PROBING AROUND THE OTHER PINS!! If the vehicle is running and the MIL light is on when the ignition is turned on and goes off when the vehicle starts, your problem is probably right there. Let me know how you make out.
Feb 23, 2014 | Cars & Trucks
Where is the diagnostic port located on a 2000 fiat marea
on a 99 2.0 model you will have 2 diagnostic ports. both of them will be the fiat 3 pin type.
to connect the 3 pin fiat connector to a 16 pin obd2 connector you need 4 lengths of wire. use 3 lengths of wire to connect the 3 pin connector to the obd connector. also use 1 length of wire for power to the obd connector.
on the 16 pin obd2 connector use the following pins
4- chassis ground (connect to ground on 3 pin connector, or any good chassis earth)
5- signal ground (connect to black wire pin on 3 pin connector)
7- k line (connect to white wire pin on 3 pin connector)
16- 12vDC (connect to battery positive terminal)
Apr 08, 2013 | Cars & Trucks
My obd2 isn't getting power what I do?
Check Pin #16 on the Data Link Connector (DLC) for battery voltage. (See Diagram)
If there is no battery voltage present check the fuse marked "OBD II" in the engine compartment fuse block. It is a 10 Amp fuse. If the fuse is good, repair the circuit between the fuse and pin #16 at the DLC.
If battery voltage is present at Pin 16 at the DLC, check for ground at pin 4 on the DLC. If ground is not present, repair the ground circuit between the DLC and Ground G202 located at the left side of the dash.
HINT: the easiest way to check BOTH of these at the same time is to use paper clips plugged into pin #16 and Pin #4 and connect a light bulb between the two. If the light illuminates brightly, power and ground are both OK.
If no problem with power or ground is detected at the DLC, check the Owner's Manual for your code reader.
May 11, 2012 | 2000 Kia Sephia
I am trying to find the wiring diagram for my 2002 FXD. I am installing a trunk and need to know the light wiring diagram in order to hook up the tail and turn lights on the trunk.
Connector 7 is under the seat. It is the main harness to tail lite connector. The wires from main connector are:
2002 All DOM and INT Including FXDWG
Connector 7 pin 1 goes to tail lite 94 connector pin 2 = BW
pin 2 goes to 94 pin 1 = O/W
pin 3 goes to 94 pin 5 = V
pin 4 goes nowhere = empty
pin 5 goes to 94 pin 6 = BK
pin 6 goes to 94 pin 4 = R/Y
pin 7 goes to 94 pin 3 = BE
pin 8 goes nowhere = empty
Connectors 93, 94, 18, 19 are all in the tail lite assembly.
19 = Rt Turn pin 1 = V/BN pin 2 = BK
18 = Lt Turn pin 1 = V/BN pin 2 = BK
93 = Brake and running lites pin 1 = BE = Dom running pin 2 = O/W = HDI running pin 3 = R/Y = Brake pin 4 = BK = ground
Jul 25, 2010 | Harley Davidson FXD Dyna Super Glide...
Problem with panel front conector in Dell Dimension 2200 motherbo
The following information is to assist you in performing the right connections. You should take precautionary measures such as grounding yourself and completely disconnecting the PC form any source of power.
This picture shows the connector for the front panel power button, reset button, and power and hard disk lights: an 8x2 pin connector with 1 pin missing:
The table below lists the pinouts for the connector. The orientation of this table is the same as the picture above, this shows the top part of the connector. All the pins below pin 8 appear to be non-connected.
Each pair of pins labeled Power and Reset goes to the 2 wires for the corresponding button. The hard disk and power LED wires connect to the corresponding LEDs, you need to ensure the proper polarity of the + and - wires for each LED or it will not illuminate.
The above information is for your information only.
Mar 01, 2010 | Dell (2M502) Motherboard
No power to radio but fuse is ok
You will need to remove your radio to check this. They have 2 different radios for your vehicle. When you pull out your radio that is how you will tell. One will have 16 pins in the plug for the radio or it will have 7 pins for the plug in the radio. If you have the radio with the 16 pin connector the your power wires are pin # 7 a yellow with a green tracer wire and pin # 16 an orange with a black tracer. Your ground will be pin # 8 a black with a green tracer wire. If you have the 7 pin connector then your power wires are pin 1 a orange with a black tracer and pin # 3 a yellow with a green wire. Your grounds will be pin # 2 a black with ayellow tracer and pin # 6 a black wire with a green tracer if you have all of that then the radio has probably failed.
Apr 13, 2009 | 2000 Ford Focus
Need pinouts
I have an old pc chips M575 motherboard that also uses the J3 ATX Form card. I can only assume the pinouts are the same so here they are from the manual.
Pins 1-4 and 10- 13 are USB connectors
USB USB
Pin Description Pin Description
1 +5v 10 +5v
2 data- 11 data-
3 data+ 12 data+
4 ground 13 ground
Pins 5-6 and 15-16 are PS/2 Mouse Connector
Pin description
5 +5v
6 Mouse CLK
15 Mouse Data
16 ground
Pins 7-9 and 17-18 are Infrared connector
Pin description
7 Ground
8 Reserved
9 +5v
17 IR in
18 IR out
hope that helps
Nov 18, 2008 | Pc Ware M748LMRT Motherboard
Wiring harness on my 94 Ranger
I have a 94 Ranger XLT extended cab. Here are the power/ ground connector pinouts and wire colors as shown in the factory service manual:
Pin 1 LG/Y Radio Memory Power (B+)
Pin 2 BK Ground
Pin 3 Y/BK Power (Hot in RUN or ACCY)
Pin 4 LB/R Illumination (dims with dash lights)
Pin 5 O/BK Illumination (does not dim)
Pin 6 BK/LG Ground
From the diagrams, looks like either ground will work.
Hope this helps.
May 30, 2008 | Car Audio & Video
Need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Mar 27, 2008 | Altec Lansing ADA425 3-piece 30-watt...
Panasonic CQ-VD7500U Car DVD Player Logo
592 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
