Question about Sharp XR-11XC Multimedia Projector
Lamp replacement just changed the lamp on my sharp xr 11xc however now both red standby light and red lamp light are lit. Can I reset or does it need some special service
  • 3 more comments
  • traks137 May 21, 2008
    I take back all the bad thoughts i had about the service. Thank you Marie you are a gem.
  • datxbadboy Oct 09, 2008
    I reset the lamp counter per my user manual, but now i am getting the same thing over and over again. did i miss something?
  • Anonymous Nov 13, 2008
    just replaced lamp on XR-11C Sharp projector. the red power light comes on but it will not turn on.
    Help
    Mike
  • Anonymous Nov 16, 2008
    I have same problem with the lamp replacement and trying to find the manual to reset the timmer. I don't know why sharp had such a stupid design. -dan
  • clinthaley Mar 25, 2009
    I have the same problem. I installed new bulb reset the timer. The standby light turns green and the lamp light flashes green for a while. Then it shuts off and both turn red. No picture ever comes up.
  • 563 Answers
Hi traks137
You will have to reset both the lamp and filter timer before it will change the status of this unit.
Your user manual will have all the steps in it on how to do the required resetting.
Thanks for using Fixya !
Posted on May 21, 2008
  • Marnus Jacobs
    Marnus Jacobs May 21, 2008
    Hi traks137
    It's only a pleasure to be of help.
    Thank you once again for using Fixya as your one stop solution shop !
Lamp issues
Look at the ballast module. It controls the lamp operation
Nov 30, 2013 | Sharp XR-11XC Bulb/Lamp
I replaced the lamp, then the projector is not switching, but the standby and lamp indicator are red, no button is working. how can i reset?
Check if you need to reset the lamp life time counter clock after changing the lamp. Check the manual for details.
Aug 09, 2010 | Sharp XR-10SL DLP Projector
I have a Sharp XR-11xc and my bulb recently burned out. I ordered and replaced with a new lamp. It would turn on but no light would be projected. I read up on the subject and tried the reset of the lamp by...
I have the exact same problem. I've only reset the counter once though. It worked great at first, but seems to be getting worse. It's like it tries to start, just doesn't light up (maybe not warm enough???) then retries like 5 times until switching to the red light. Unplug and retry.... and eventually it does come on, and once on, all is ok. Is this just the projector trying to slowly 'break in' the new bulb since it has almost no hours?
Apr 21, 2010 | Sharp XR-11XC DLP Projector
My Sharp XR-11XC Projector died not long ago with very few hours of use. The unit will not power up nor does it show any signs of trying to. No LED lights, no fans - nada. I tested the fuse and it's...
I opened mine up hit the red reset in the front and now all good. If ur red light is blinking make sure ur lamp compartment is shut properly, if not the red light will blink and unit won't turn on.
Mar 26, 2010 | Sharp XR-11XC Multimedia Projector
I just replaced the lamp in my xr-11xc sharp projector, reset the timer, and it turned on. after shut down, i tried it again, and now the standby light comes on, i hear the fan spin up, then the lamp...
the colorwheel may be bad. if it doesn't spin, the lamp won't strike. if the colorwheel is ok, replace the power supply/ballast. you can get one and do it yourself, or send it to a sharp service center. either way, try www.avsolutionsny.com. they're really good.
Jan 27, 2010 | Sharp XR-11XC DLP Projector
I just changed the bulb in my sharp xr-11xc. it worked fine till i turned it off and now its not working again
reset the lamp timer. hold down the menu, down arrow, and enter buttons, then press power.
Nov 20, 2009 | Sharp XR-11XC Multimedia Projector
I bought a new lamp for my sharp XR-11XC. Standaby/on light is flashing and lamp light is red. TI tried two new lamp. all has the same problem. Need help, Thanks!!!
have you reset the lamp timer yet? can't remember the procedure for that one exactly often hold power and down and left arrows whilst plugging in power. Check info on instructions that came with your new lamp.
Nov 18, 2009 | Sharp Projector lamp Projector Lamp
Sharp XR-1S Projector, no picture, lamp light flashing..... help!
if it's under 1 year old, it's still under warranty, so send it in and get it fixed for free.
Jul 06, 2009 | Sharp XR-1S Multimedia Projector
Sharp xr-11xc only displays black & white
Sounds like your connection is bad, check ur connections on ur cables
Oct 25, 2008 | Sharp XR-11XC Multimedia Projector
443 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
