Removing the stand from a flat panel TV
I have an Insignia 42" flat panel plasma TV ( NS-PDP42 ) that I want to wall mount. How do I remove the base, which folds into 2 pieces, but does not seem to want to let go of the TV. The owners manual has no instructions for removing the base, and my removing a few obvious screws had no effect. I'm sure I'm missing something simple but any help would be appreciated.
  • Anonymous Jun 24, 2008
    Sharp Aquos has the same problem...???
  • mbaybutt Dec 17, 2008
    I'm running into the same problem with a Dynex 42"... anybody, any thoughts?
    President:
  • 749 Answers
None of these TVs have any problem removing the stand.
Stands for 32'' and larger TVs plug into the TV's body and are attached by 4 to 8 bolts that go through the cover, then through the plugged-in part of the stand and attach to the internal frame.
In most cases the bolts are 4 - one for each ray of the fork that goes into the TV.
Since bolts for the frame are metal bolts and bolts for the plastic back cover are usually wood-type screws (sharp on the top, wider thread) you can visually tell the one for the stand from the rest.
Look right above the stand for four, six or eight symettrically placed heads that are different from the ones you see on the corners.
Once you unscrew those the stand should feel more flexible and you can simply pull it back.
In order to do all that you have to have the TV laying on its face or back.
Watch out if it's heavy - you may need to support it towards the end of the operation. It's unlikely for it to get damaged if it falls down, but you still don't want to try your chances.
Giving it a little lift also helps unscrew the last bolts...otherwise all the force of the TV is pressing against it...and that makes it harder to unscrew.
Posted on Nov 07, 2009
Insignia 22 stand mount
Keep checking Ebay. I hate that site, but sometimes they are a necessary evil.
Jun 21, 2012 | Videosecu TV Mount for Insignia...
Im having trouble removing the base stand, I'm trying to mount it on the wall. I removed the 4 screws on the bottom but cant get the metal legs off.
Generally the stand is screwed on from the back of the TV. there should be 4 screws that will come out all the way and allow for the stand to be removed
Mar 13, 2011 | Maxent MX-42HPM20 42 in. Plasma HDTV
I need an Insignia TV stand for a 42" LCD HDTV
Try the T.V. manufactures website, E-Bay or the store where you got the T.V. from.
Jul 15, 2009 | Insignia LCDTV26 26 in. Television
How to get code for insignia ns pdp42. remote is incorrect setup
This TV is the same as the LG 42PC3D. Find a remote code for that TV and you'll be in good shape.
Jun 11, 2009 | Insignia 42" LCD Flat-Panel HDTV
Need base for Insignia TV
It will either slide out from the front/back or to the side..Some actually bolt on from the bottom using screws/bolts.And then again some are not meant to be taken off.Make sure it is a wall mountable tv.Then try to take the stand off as directed.
May 29, 2009 | Insignia LCDTV26 26 in. Television
Tv stand screws
Check the kitchen drawer next to the fridge for the screws !!
When you get new screws, use lengths 1/2".. any longer and you might hit something inside.
Don't know why this is posted under IS-LCDTV26.. I would pull a screw from my 26" and measure it, but it's most likely different than your 42"
Sep 01, 2008 | Insignia LCDTV26 26 in. Television
Remove base of Insignia ns-ltdvd26-09 lcd tv for wall mounting
Open up the panel on the back of the TV which covers the various input connections. At the bottom of the area previously covered, there are 8 screws (two rows of four screws). Remove them, and the entire stand should now slide right out of the TV. You can then replace the screws back in their holes, so you don't lose them. You do not need to disassemble the stand to do this.
Jul 11, 2008 | Televison & Video
to remove base from insignia tv
1)remove plastic cover from bottom rear of tv
2)remove 8 philips head screws on rear of tv above base
3)pick up tv and base will come off
once you remove it you realize how easy it is
Jun 29, 2008 | Insignia LCDTV26 26 in. Television
Akai Plasma PDP42Z5TA - removing base stand
The base removes with the support arms that rise the height of the tv. remove all the screws from the back of the support arms and the base will slide out with the arms. you will need the holes open to mount to the wall mount
Jun 16, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Televison & Video Logo
1,370 people viewed this question
Top Televison & Video Experts
