Question about Intel Motherboard
Intel D865GBF Motherboard
I am considering a few up grades to my board. I would like to replace my CPU cooling fan with a Thermaltake Big Typhoon. At same time I would like to replace the Heatsink on my Northbridge chip with the Thermaltake Extreme Spirit II Cooling Fan. I am planning to replace all my case fans and HD coolers at this time. I found one case fan and HD cooler fan not working during a routine cleaning of my Inwin Full Tower Case.
I am not sure that the changing of the Moboard fans changes are a good idea due to the complexity of the change, I am not sure how to remove the retention mechanism for CPU from motherboard, and the Heat sink for the Northbridge cooler(no fan). Any Help or opinion would be helpful.
Thanks Jharper91
  • 270 Answers
I tink the processor have a round heasink shape whcih is in LGA 775 package .
ther will be four pin like structures on 4 corners of the hearsink . and while carefully examing u can found a notch on ecah legs . take a flat scrw driver and turn the legs in anticlok wise direction .. this will losen legs . after that hold on top pf that legs and pull slowly out each legs ......very careful whil removing intel fan
Posted on Aug 06, 2009
  • 1,066 Answers
The thing that holds the heat sink on top of the cpu,. that little bar thing, has a hook on one end that sort of catches a part of the socket and latches down. take a flathead screwdriver and try to unhook the hooked side of it.
Posted on Mar 11, 2009
  • 2,351 Answers
Hi Jharper91,
There is no easy way to explain how to remove your Intel® Pentium® 4 processor with out some pictures. Intel does have a site showing how to install. Once you understand how to install you'll be able to remove. Try looking through this link from Intel.
Newer Intel Pentium 4 processor use 4 plastic pins to hold the retention clip onto the board. To remove them you will need to lift the motherboard out of the case. Using a needle-nose plier to squeeze the plastic ends together & pop-out the plastic pins.
The north bridge can be glued onto the chipset & have
2 pins bent inwards on themselves. Bend them in and push them through. If glued, use a hair dryer to heat the cooler, thus making the glue soften. Each board can & do use different methods to hold coolers to the chipset's. You might want to keep in mind the total db of adding a bunch of coolers. It may get very noisy for you.
I hope you find this helpful.
If I can help you more just post you're question's here.
Good Luck Jharper91!
Posted on May 21, 2008
What year is this board
It was made in the year of our Lord - 2003
It was a cold dreary day in March, and no big fanfare of computer geeks wanted to see the board. Quick meeting, and out the door.
AGP 8X technology.
No SATA RAID features
No voltage adjustments in BIOS Setup.
Aug 17, 2012 | Intel Desktop Board D865GBF (MBIND865GBF)...
D865GBF video drivers for win7
Try to visit this site:
You can select auto detect or simply search by full modelnumber.
Or install this program, Its free:
It will tell you the exact name of your main board.
Intel have made many boards,so it could be under another name.
Good luck.
Feb 23, 2011 | Intel D865GBF Motherboard
My video drive and audio drive not working........ i lost my mother board cd to install the drivers........wat to do
You will find your driver here just enter D865GBF into the search box and there are 45 drivers listed for your motherboard
Please rate this solution
Jason Dunn
Oct 31, 2010 | Intel D865GBF Motherboard
My computer restarts frequently. Some times after
Maybe it is a heating problem. Try putting a new thermal paste on your CPU and cleaning fans. (there is still a possibility that it is a power supply component problem.
So you should consider buying an UPS.)
Also check capacitors, if they are deformed - replace them or buy new MB.
Good luck! :)
Nov 28, 2009 | Intel D865GBF Motherboard
Intel D865GVHZ (Gateway Hazelton) motherboard system cooling fan
This fan error message shows up when the CPU fan is not plugged into the CPU FAN plug on the motherboard. The Intel D865GVHZ
motherboard has a total of 4-fan plugs so it is easy to plug the CPU fan into one of the other fan plugs that is not marked CPU FAN on the motherboard.
Apr 12, 2009 | Intel (8W501B1M3G) CPU Fan, CPU Cooling...
MY compuer helds after few minutes
the computer is probably old considering the chipset of the M-board. it might be overheating i would recommend cleaning it from any dust filling the cooling devices especially the cpu cooling
Mar 02, 2009 | Intel Desktop Board D845EPI Motherboard
**System randomly hangs**
Electrolytic Capacitor Failure on some Intel mobo. Products Affected:
Intelreg.gif Desktop Boards D865GBF, D875BZL, D865GLC, D845EPI, D865PERC, D865GRH, D865PERL, D845GVSR, D865PESO, D845GLVA, D865GWV, and Intelreg.gif Entry Server Board S875WP1-E.
Should replace the capacitors shown in the photo attached. 73d0b16c-0d36-4176-be42-6dd73b32fb65.jpg
Oct 24, 2008 | Intel D865GBF Motherboard
Two possibilities:
  • the CPU is really overheating; and/or
  • the motherboard is falsely sensing high temp.
Corrective measure for an overheating CPU would be:
  • clean, re-lubricate or replace the fan;
  • clean or refit the heatsink. If it is overclocked, you may need a better heatsink.
If the CPU is not really heating up abd the motherboard is sensing erroneous temp readings, then the problem may be with:
  • BIOS version, try to flash and update the BIOS; and/or
  • check the temp probe underneath the CPU, it may need cleaning or slightly bending away from contact.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 13, 2008 | Intel D865GBF Motherboard
PC Freezing !
Update BIOS to P25*%20XP%20Professional&lang=eng
Reset BIOS to default settings.
Check CPU Temperature, Prescott CPUs run hot.
If board is under 3 years old and was a retail box package, it will be under warranty, contact Intel.
Jun 29, 2008 | Intel Motherboard
Trouble shooting
OC failure = over clocking failure. Make sure the CPU fan is clean, free from dirt & dust. Check CPU fan plug is connected correctly. If the CPU fan still stops after a few seconds replace the CPU fan.
It's harder to find just a fan to fit your heatsink, which sits on your CPU. It is easier to find a new heatsink \ fan combo for your Intel. Use your manual to find what Intel chip is on your board. Use that information & search google for a heatsink & fan combo. Pay close attention to how your current heatsink is mounted to the Gigabyte board.
Mar 24, 2008 | Computers & Internet
Intel Motherboard Logo
178 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
