Question about Kenmore 24032\24036 Top Load Washer
Washing machine smell
Hello. I was recently using an oil based stain to stain my deck. I washed out the brushes and things in our slop sink in the basement. Our washing machine emptys into the slop sink. The sink got clogged with the stain and it must have backed up in to the washing machine. Now all the clothes being washed come out smelling like the stain. I have tried bleach and vinager and niether have worked. Can you please help me!
  • matt142 May 22, 2008
    The inside of the tub does not have any stain on it. It must be in the piping or something!
  • 868 Answers
You need to use a steel wool with alot of ajax/comet and start scrubbing the entire inside of the tub.Its not going to wash out any other way.
Posted on May 21, 2008
  • Archie Ferrarini
    Archie Ferrarini May 22, 2008
    Maybe you have discovered a new method in wood staining.
I'm doing a project on my floor, a brown paper floor which requires staining and then 6-10 coats of polyurethane but the stain is oil base can i put a water base poly over top of this some people say yes...
I have little experience of oil based stain other than knowing it is supposed to give long-lasting protection without further covering.
I prefer to use a spirit based stain and find it gives good results and once the spirit has evaporated it is quite inert and won't interfere with any subsequent finishes overcoating it, in fact it is designed to be overcoated.
I have used a water-based varnish and I found it particularly unimpressive compared to the usual alkyd resin or oil based stuff and it will be a long time before I use it again. Buying coloured varnish would mean you don't need the stain. I haven't tried it but I think a small amount of spirit stain could be added to oil based varnish...
Sep 28, 2017 | Washing Machines
What kind of finish can I use on top of a gel stain? Can I use simple linseed oil or tung oil?
Generally, if the gel stain is water based, use a water based finish. If it is oil based, use an oil based finish.
If you are going to use oil over water, read directions to determine waiting time between applications.
Also determine your finish by the type of surface that you stained, and the look you want to achieve.
Thorough explanation, including links to YouTube videos are available at the link. https://generalfinishes.com/blog/2014/12/do-gel-stains-need-a-top-coat#.WY42Pq2ZOLI
Aug 11, 2017 | Washing Machines
OIL STAIN ON A CLOTHES out of washing machine E12477
Are they getting the oil stain from the washing machine? If so, you need to get a tech out to inspect your washing machine. If you are putting oily clothes into the washing machine hoping it will come out, it's too late, you need to pre-wash with Shout or Tide to remove oils and grease. The more you wash and dry it the deeper the stain will set. Sounds like you need to throw those clothes away.
Jan 20, 2015 | Washing Machines
Model 970-c44072
none of us would know that different smell, call the local engineer for a quote eric
Jan 18, 2018 | Kenmore Washing Machines
I bought the face foundation with the brush attached and not only did it saturate the brush while flying, but it has splashed on two of my favourite shirts and I have tried everything to get the stains...
For a stain caused by anything with an oily base (including most makeup), try Murphy's Oil Soap. It's vegetable oil based, so it can break up the oil in the makeup. Dab some on full-strength and let it soak in before washing.
Feb 21, 2011 | Revlon Age Defying Spa Foundation...
Smell coming from washing machine like stagnant water-hotpoint wma 44....seems to be coming up through the drain in sink
Hi from retired Englishman in France,
If the smell is coming from the drain in the sink, it is more likely that THERE is the problem rather than the washing machine. Washing machines deal only with 'dirty' clothes whereas sinks have all sorts of things going down them! You could have a partially blocked u-tube (not to be confused with YouTube!) in the sink because normal (changing/flowing) water in the u-tube should block smells coming from the main/foul water drainage system.
I would definitely investigate the sink! If it is not practical to remove the u-tube, use a propriatory sink cleaner ensuring that it is the right one for the job- OK for plastics or OK for metal (not chrome).
Good luck,
John C
Jan 25, 2011 | Hotpoint Washing Machines
Foul smell comes from my zanussi jet system washing maching, so bad now that wahing smells of sewerage \r\nhelp please! i have a mountain of washing to do
Have u moved anything recently? the outlet hose must be above the sink waste outlet other wise water from the sink will go into machine
Jun 11, 2010 | Washing Machines
Recently my washing machine has been giving off a putrid eggy smell when on any program. I clean inside the drum, the drawer ect often. i have checked both inside and outside drains and cleaned them. i was...
it may well be stuff from your sink drain trap syphoning back into your washing machine
sounds like you need an anti syphon valve to be connected in line with your washing machine waste water outlet
Check that hose discharge from washing Machine loops up above the minimum height as specified by the machine manufacturer and at least to the underside of the work top for an inset sink before connecting into the sink trap.
http://www.wickes.co.uk/invt/420182
Nov 18, 2009 | Washing Machines
Kerosene smell from the dryer
I have read other places that if you have recently painted, stained, varnished or used something in your house that has some sort of oil base it can make you dryer make your clothes smell like Kerosene. My dryer started doing the same thing and it was at the same time that a contractor was staining some trim in our basement. Good luck.
Mar 22, 2009 | Kenmore 73952 Gas Dryer
Kenmore 24032\24036 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
