CD and DVD Burners
Problem for CD and DVD Burners
Generic problem for all CD and DVD Burners
Used USB 2GB stopped prematurely now nee...
By Jaymie78 on May 21, 2008
Hello, My key had not finished writing to a Excel file when XP restarted.
Now the key wants to be reformatted? I have files on the key.
How can I get to the files without deleting them by reformatting the key?
Cheers, Jaymie
Comments:
May 22, 2008
- Hey mate, thanks for the reply. I tried that and it only finds my working WD hard disk. This is where I have other files. But it is not my 3GB USB key, this does not show in the software I downloaded so I am unable to access the disc to recover files from it. Any other reccomendations. Cheers!
May 22, 2008
- Hi where is CHKDSK in Vista? scan disk did not work as it said it needed to be formatted.
Please advise.
May 22, 2008
- Hello, I have tired the above and it says 'The type of the file system is RAW. CHKDSK is not avail for RAW drives'
Any other info please?
Jaymie
May 22, 2008
Jaymie
Solution #1
posted on May 21, 2008
Not Rated)
Benimur
Rank: Guru
Rating: 88%, 3785 votes
You can try file recovery utilities such as GetDataBack.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Comments:
May 21, 2008
- you can also try file recovery softwares from here, here or here.
Incidentally, if you are using a Mac, pls try here.
May 22, 2008
- Hi again,
have you tried Ajkill's suggestion of trying it in another PC?
May 23, 2008
- Hi again Jaymie78,
Let's recap:
1. you have a flashdrive that became unformatted;
2. being so it is now RAW and therefore CHKDSK will not work;
3. you have tried several file recovery program (including GetDataBack?) and none worked; and
4. you have tried the same flashdrive on other PCs and likewise cannot be accessed.
From all appearances, the flashdrive is a goner (and unfortunately so are the files). Worst case scenario, you can try:
a. Format the flashdrive. Of course the files will be erased but technically they are no longer there in the first place hence a recovery cannot be performed, and then immediately thereafter;
b. do file recovery using bestdarngood's posted software or those that I have posted specially GetDataBack.
Rationale: There is nothing to loose as they are already lost. By formatting, you are making the flashdrive readable. Using the file recovery software, there is still a chance that some of the files would be recovered even if the drive has been formatted. Of course this is at best a 50-50 chance since other than this (based on your post that none of the file recovery software works), nothing works.
Solution #2
Not Rated)
bestdarngood
Rank: Guru
Rating: 89%, 439 votes
Alright Jaymie, you can get the information recovered for free with the program at the following website
http://www.top-shareware.net/recover_usb_drive_data.html
after doing this, you can then reformat the usb which should delete most if not all of your data. Please let me know if you have any questions about this or just need more help.
good luck
Comments:
May 22, 2008
- For CHKDSK
You need UAC enabled and admin privileges, then go to Start>Run>Cmd
Then type "chkdsk" for need help, use the "chkdsk /?" (without quotes) for info.
you can also go to my computer, right click on the drive, click properties, click on the Tools tab and then click Check Now
May 22, 2008
- Follow the instructions at the first link
http://www.z-a-recovery.com/unformat-tutorial.htm
and download the program at the second link
http://www.z-a-recovery.com/download.htm
This should recover the data when the CHKDSK has this error message
Let me know how it goes
May 24, 2008
- Were you able to fix this, if so then please give me some feedback by rating my solution. If you need any more help, I would be glad to assist you, just ask.
thanks and Have a Great Day!
Solution #3
Not Rated)
Ajkill
Rank: Wiz
Rating: 84%, 1102 votes
Remove the key and try in other computer if your able to read the file , if not you need to reformatted the key in order to work.......
good luck.........................
Comments:
May 21, 2008
- or try the Benimur solution.
Solution #4
Not Rated)
micromaster
Rank: Wiz
Rating: 82%, 758 votes
try CHKDSK..
i'll post back the link here later..
thank you
Comments:
May 21, 2008
- Windows runs Chkdsk to make sure that there was no file resulting errors. This can turn stray pieces of files, or lost clusters, into file fragments for your review.
May 22, 2008
- Hi there again,
Here's HOW to do CHKDSK @ VIsta
Let us know.
Thank you
May 23, 2008
- -or- try this software Active File Recovery 7.3 Build 101
Popular Solutions for CD and DVD Burners
Questions and Unsolved Problems for CD and DVD Burners
Answer
I need an internal cd/dvd burner drive tray where to buy one
Answer
Hi my name is kerrie.. I am looking for a gz-mg26 burner. CU-VD10 SHARE STATION.Apacer AD330 DVD... (More)
Answer
dvd duplicator disc in the trays but it says target drive not ready
Answer
I just got a Que!Fire 24x10x40X CDRW and I plugged it into my mac os x v10.4.11 with a firewire cord... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For CD and DVD Burners:
Top CD and DVD Burner Experts
Rank: Guru Guru
Solutions: 14911
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more CD and DVD Burner Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
