Question about Samsung SGH-d807 Cellular Phone
Not hearing anything when the slide is up, only when it is down, can you tell me what might be the problem and how do i get it solved?
When making or answering the phone if using the phone when the slide is up the person on the other line can hear me, but i cannot hear them.
  • LadyPN Jun 23, 2009
    yes thank you
    Sergeant:
  • 282 Answers
The problem is in connector. You need to change it.
Posted on May 21, 2008
HOW DO I LOOP A SOUND FILE TO KEEP PLAYING TO THE END OF THE SLIDES WITHOUT EXTENDING THE TIME OF EACH SLIDE?
1) File > New > Presentation > Create (new presentation with all default settings)
2) Panel at right: Slide Transition > Modify Transition > Sound = "apert" (fourth in the drop down list)
You should hear a short (~2s) sound at this point, as the effect is "previewed". If you don't hear it, try the "Play" button at the bottom of the Slide Transition panel. If that doesn't work, then OOo is not able to play sounds and you have to fix that before proceeding.
3) Slide Transition > Modify Transition > Sound = "Other sound" > (select your long music file).
You may or may not hear the preview for this, it depends on whether your music file has a quiet leader at the beginning. If the audio starts right away, you should hear it. If the audio starts after 1-2s of silence, you won't hear anything.
4) Click "Slide show" (bottom of the Slide Transition panel) or F5.
You should hear the music start. It will continue to play even after you advance to the next slide (which is the black "End of show" screen. Advance again to end the show and the music should stop.
Jul 29, 2015 | Computers & Internet
When a make a call l can't hear the other people , how can l solve ?
can you tell when they pick up and dose the phone make a ringing noise when some 1 calls
Apr 13, 2012 | Finarea MobileVOIP
No sound at all ,good picture ,mute is not on
If using a box make sure sound not turned down on it.
In Set menu make sure speakers are switched ON.
Look for a slide switch on rear of set for Internal/external speakers. It may also be in set's menu as an option.
If ear put right to speaker"s do you hear anything?
still not working likely an audio output circuit problem.
Mar 28, 2012 | Televison & Video
Black screen but power lights are on and will not shut down or do anything
Hi
I would turn the laptop carefully upside down making sure that the power cord is NOT connected and remove the battery usually a slide catch or something similar holding it in position
hopefully that will cut all power to the laptop and hence hopefully shut down
when light go out and you can hear nothing then put battery back in and use power cord if needed
Jan 30, 2011 | Toshiba Satellite L500 Series Notebook
When making a call, the ear piece doen't work - you can't hear anything. You can use the speakerphone and this works.
Your Nokia mobile phone shows symptoms of a faulty earpiece. The easiest way to solve the problem is to visit your nearest mobile repair shop and have the earpiece replaced. Normally shouldn't cost more then USD 10.00
Jan 01, 2011 | Nokia 6500 Slide Cellular Phone
I cant hear anything on my nokia 6500s expect on speaker
The problem with your phone is the earpiece, since you have adjusted and try increase the volume, yet, same problem. The earpiece on your phone is bad that is why you cannot hear the party calling you or hear anything while you call.
All you need to do is to replace the earpiece on your phone and you will see that you can hear whoever you are talking to on your phone.
Replace the earpiece on your phone and you will see that the problem is solved. meanwhile, you can keep using the headset pending the time you will replace the earpiece.
Take care.
Aug 09, 2010 | Nokia 6500 Slide Cellular Phone
I have a sidekick slide and i can hear the phone ring but not people talking
The problem with your phone is that the earpiece on your phone is bad that is why you cannot hear the party calling you or hear anything while you call.
Change the earpiece on your phone and you will see that the problem is solved. meanwhile, you can keep using the headset pending the time you will replace the earpiece.
Good luck.
Aug 08, 2010 | Motorola Mobility SIDEKICK SLIDE Cell...
My using Nokia n95. When I pull up the slide to
There is a problem with the slide, You can personalise the Silent profile to ringing, if it turns to silent again. The slide is the major problem and if it persist visit Nokia phone shop. Thanks
Jun 04, 2010 | Nokia N95 Cellular Phone
I cannot hear calls but they can hear me
Not much to tell you other than putting the factory software back on it. Thats the chance you take when you flash any phone.
Sep 21, 2009 | Palm Treo 500 Centro
Samsung SGH-d807 Cellular Phone Logo
41 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
