Question about Frigidaire Affinity ATF7000ES Front Load Washer
Frigidaire Affinity e 25
I have had this washer for approximately 6 months. I was doing a load of wash, and the thing stopped part way threw the load. It keeps beeping e25, it wont spin, and it won't drain the wash water. I have called the repair people 4 days ago with no service man to my door. I finally got the wet clothes out, but the stinky water is still in, any idea on what I can do to fix it before it becomes a lawn ornament?
  • shoesamory00 May 25, 2008
    Error 20 water not pumping out
  • bustyboots May 27, 2008
    Thank you oldfixer for trying to help me out. Its a good thing that I followed your instruction as close to what you suggested. Fortunately for me, I forgot to unplug the washer before trying to tip it over on its side to check the hoses. As soon as the washer was on it side, with the door closed, it clicked into gear and starting running. As soon as it started, is as soon as I tipped it back and I haven't had a problem since.
    Thanks again!!
    Genius:
  • 1,028 Answers
Dip as much water out as possible remove bottom panel remove hoses from pump ckd hoses and pump for blockage
Posted on May 21, 2008
My washer will run for a short time and them stop and just beep repeatidly
Frigidaire washer beeps for no reason, driving us crazy ...
? 1:03
https://www.youtube.com/watch?v=gP51k2bhbbg
Nov 6, 2011 - Uploaded by NatalieJonathan
Our Frigidaire washer keeps giving us ridiculous beeping issues, and for no reason. ... Mine stack dryer above ...
My washer pauses during wash cycle and will not restart ...
www.shopyourway.com > Manage My Life > Questions
The washer will stop during wash cycle and just beep. Sometimes we can turn it off and it will run again. Getting worse ... My washer is a Whirlpool 3.5 cu. ft.
FIXED Whirlpool Duet Washer Stops and Beeps - ApplianceBlog
www.applianceblog.com/.../48786-Whirlpool-Duet-Washer-Stops-and-B...
Jan 16, 2015 - 6 posts - ‎2 authors
It's a front loading Whirlpool Duet Washer 4.0 cu ft, with Tumblefresh ... wet it stopswashing and starts beeping (three beeps, pause, three beeps, pause, etc). ... The clip that holds them into the CCU (I think that's the right term) has a ... with my fingers so I could get a couple loads of laundry done until I can .
Jan 05, 2016 | Washing Machines
Has a e62 error
Frigidaire Washer Error Code E62 - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Apr 4, 2012 - 10 posts - ‎4 authors Hello, We have a 6 year old Frigidaire front load washer model GLTF2940ES3. Up until now it's worked fine. The machine now constantly ... Frigidaire Washer error code 31
May 1, 2015
Frigidaire Affinity Front Load Washer Won't Start ...
1 post
Dec 4, 2013
Frigidaire washer E6E error
Jul 31, 2012
frigidaire affinity E62 error code
Oct 30, 2010
More results from forum.appliancepartspros.com
Oct 19, 2015 | Washing Machines
Washer Seal ripped door seal
Yes. Because all front load and or stacked machines are bad! It is called Planned obsolescent. Meaning, it is normal for a new machine to break and become obsolete! These seals on the front loaders can be Expensive around $100 dollars...Sorry
Feb 19, 2014 | Maytag Washing Machines
My Frigidaire Affinity washer stopped working in middle of cycle and shows E41 code.
Hello Shawn Smith - Typically error code E41 indicates that washer has detected that the main control board thinks the door switch is open. Try reprogramming the washer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, contact a professional to move forward accurately and properly assist with the repairs.
Mar 03, 2013 | Frigidaire Affinity ATF7000E Front Load...
How do i get code for my affinity washer
Hi - Could you please press and hold the start/pause and cancel button together at the same time for approximately 30 seconds? What error code does it display? With this information I can assist you further with the issue that the washer is having.
Oct 29, 2012 | Frigidaire Affinity ATF6000F Front Load...
I was using the spin cycle to spin water from a scarf. I decided to stop the stop so I hit cancel button. Now the washer door is locked and I can't open it.
• If the cycle is interrupted during spin, it will take approximately 2-3 minutes for the door lock to release. DO NOT force open the door. • To stop the washer, press Cancel.
Jan 05, 2011 | Frigidaire Affinity ATF7000E Front Load...
My washer stops half way through the cycle and blinks????Frigidaire affinity front load washer for some reason just stop halfway through the cycle sometimes.
Take note if the drain pump is operating. If it stops halfway, it must be stopping for a problem that has arisn, Normally, the water is not being pumped out.
Jun 13, 2010 | Frigidaire Affinity ATF7000E Front Load...
Washing Machines Logo
151 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
