Question about Fahrenheat Electric Convector Baseboard Heater, 3'
Conecting heaters Do you make any connectors for joining 2 baseboard heaters together?
  • 61 Answers
You need to check ampere of the units and make sure your not putting to much on one circuit. you take the load side of the thermostat and attach to the other heater.
Posted on Nov 30, 2008
How to bypass heatercore
un hook heater hoses at the heater core insert a steal barb fitting clamp down
Apr 15, 2013 | 1995 Ford F150 Styleside Regular Cab
Can I connect 2 6 foot electric hydronic heaters together? I am replacing t electric baseboards that were installed attached to one another.
you have to be sure supply wire is able to handle total amp draw.it should be 10 gage.if it is,without getting too technical youre fine.
Dec 22, 2010 | Fahrenheat Electric Hydronic Baseboard...
I'm replacing a non-hydronic electric baseboard heating unit with a Fahrenheat hydronic one. My old unit was 240v using 2 conductors plus bare ground wire. The fahrenheat (PLF series) unit's instructions...
Hello. The red and the black are the hot wires. Therefore, connect one of your conductors to the red and the other conductor to the black. Use wirenuts. The bare ground wire should be solidly attached to the new unit's green wire using a wire nut.
Regards, Joe
PS: please rate my answer. Thank you.
Jan 06, 2010 | Fahrenheat Electric Hydronic Baseboard...
How do I know if I have 240v when replacing old baseboard heaters
When you turned off the power to the heaters was the breakers a double (2 pole ) one? If so, then yes, it defintely is 240v. There are very few 110v baseboard heaters out there anyway. The best way to check is to have an electric meter and check it out for sure. Actually if you are working on electrical circuits and you do not have an electric meter to check if you have them shut down for sure, you are on dangerous ground. Always be safe and check before working on any circuit.
Nov 14, 2009 | Fahrenheat Electric Hydronic Baseboard...
I PURCHASED NOMA 1500 WATT BASEBOARD HEATER AND
I am haveing the same problem.........., the first 10 i installed no problems....... now the last one i am ..............did you have any luck
Nov 12, 2009 | Heating & Cooling
Marley Hydronic baseboard heater not turning on
on the one that don't work use a clamp around ammeter and see if you are drawing current. no current, the heater element is shot!
Oct 23, 2009 | Marley Electric Hydronic Baseboard Heater,...
No i didn't. I need instructions for wiring a
you have baclk and red wire supply and a black and red wire to load (baseboard).
your switch will have 2 black and 2 red.
connect blk supply to 1 black on switch ( it doesn't matter which one)
connect red supply to 1 red on switch
then
connect black from baseboard to black switch
connect red from baseboard to red switch
if multiple baseboards that have several loads at thermostat then just connect baseboard blacks together and reds together before connecting at switch.
Oct 17, 2009 | Heating & Cooling
Replacing a non-programable thermostat for electric baseboard heater with model CT410B. This is a 4 wire thermostat replacement for a previous 2 wire. Directions indicate that I can do this. I connect...
If you take thermostrat back off and connect the wires together will baseboard heater get hot. If not you may have bad heater. If it gets hot your new tstat may be bad. The way you have it wired is correct. Most line voltage tstats have a ground screw. Your 's may not but will work without one .
Jan 23, 2009 | Heating & Cooling
Baseboard heater
the stat points are stuck together or the stat is defective. try tapping on it to make them loosen up or replace the thermostat.
Dec 08, 2008 | Fahrenheat FBE15002 Baseboard Heater
Fahrenheat Electric Convector Baseboard Heater, 3' Logo
51 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
