Question about Nikon D40x Digital Camera
Nokon d40 Appiture
In appiture mode camera wont go below 4.5 alothouh lens is 18-55 3.5-5.6
  • 111 Answers
The aperture varies according to focal length... at 18mm the lens will go as wide as f3.5, but at 55mm the lens only widens to f5.6
Posted on May 21, 2008
I have a Nokon D40 DSLR and a Vivatar Zoom Thyristor 3500 flash that I want to fire off camera to capture high speed photos.I would have the D40 in dark room with shutter in bulb setting. any Ideas
You can either use a PC cord to connect the flash and camera, or you can use a remote trigger to fire the flash cordlessly. Your local camera store should be able to provide options for both.
Jan 25, 2017 | Nikon D40 Digital Camera
Having trouble with my Nikon D5000 recognising new lenses. How do I fix this problem. I have a Phoenix 650-1300mm f/8-16MF Lens and also a Samyang 800mm F8.0 SLR Interghangable lens. My Nikon D 5000 will...
You might want to have a little look inside the mount on the camera body and make sure you haven't moved the little metal clip there. (I think it was on the left as you look at the open front of the camera). There was a thing on the Nikon web site about the clip and it possibly getting displaced, bent or broken. I only saw it whilst looking around about this camera just before buying it (I am a bit clumsy with stuff but mine is fortunately OK).
Hope you get it sorted.
May 02, 2011 | Nikon Cameras
I have a galileo FS 135DS 1100 X 135mm and am having difficulty getting it into focus. I have no user manual. What can I do besides addjusting the appiture?
You focus by turning the focus knob -- on the side of the focuser. Practice during the day time on a distant object.
Mar 20, 2011 | Optics
Bought a Sigma DG 70-300mm 1:4-5.6 autofocus for my Nikon D40. When the lens is attached the settings get locked on MF. Is there anything I need to adjust to fix this problem? Charles
The Sigma 70-300mm f/4-5.6 DG will not autofocus with the D40 since the lens does not feature an internal focusing motor (HSM). The D40 does not have an AF motor in the body and hence it can autofocus only with lenses featuring an integrated motor (eg. Nikon AF-S lenses, Sigma HSM lenses, Tokina DX II series etc). Unfortunately you can use the said lens only in MF mode.
Sep 02, 2010 | Sigma 70-300mm f/4-5.6 DG Lens
Ive got the nikon d40. when i take photos close up they are blurred. there r 2 settings on the focus lense one is letter a one letter m. you have to move switch to indicate one or other. camara wont take...
The letters you're referencing is the M/A (manual / auto) focus switch. The lens has this switch and operates in Auto Focus mode when set to "A" and manual focus mode when set to "M".
You have to manually focus on the subject when in letter "M". If you do not, the result will be out of focus. From your description, it sounds like the camera / lens combination is attempting to focus and operate the shutter in auto, and focusing in manual; but due to some type of damage resulting from possible mishandling, exposure to dust, dirt or even moisture is interfering with the successful completion of the process.
You could isolate the problem to determine if the cause is in the lens or camera by simply attaching the lens to another compatible Nikon camera or placing a different auto-focus lens on your D40. The problem will either stay with your D40 or follow the lens when attached to a different camera. It is also *possible* that due to numerous attempts of auto-focusing with your D40 & lens combination, that both the lens *and* the camera have been damaged. If the problem is severe enough, the problem in the failed device could cause failure in the otherwise normally working device, too.
You might be best served by contacting Nikon Service & Support below:
http://www.nikonusa.com/Service-And-Support/Service-And-Repair.page
You also said you lost your manual. You can download the manual for the D40 directly from Nikon in your choice of English, French or Spanish from the link below:
http://support.nikontech.com/app/answers/detail/a_id/14157/session/L3NpZC9YRTgxQVpKag%3D%3D/kw/D40%20manual/p/19%2C334/c/187/r_id/116678/sno/0
Oct 09, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
The Autofocus does not work on my Nikon D40
1 Possiable dirty lens contact terminals
2 Auto focus motor in lens is jamed/malfuntion
3 Auto focus engagement pin on camera body is not engaging the lens
4 Correct lens,old nikon lens and some 3rd party lens wont work on the D40
Jul 18, 2009 | Cameras
D40 lens works in manual mode but not in auto
TAKE THE LENS OFF THE CAMERA. SEE IF YOUR CONTACTS ON THE CAMERA AND THE LENS ARE CLEAN, PASS A CLEAN PENCIL ERASER ON THE CONTACTS, DON'T LET RUBBINGS FALL INTO CAMERA!! TRY THE LENS NOW.
Feb 24, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon d40 lens
The Lens focusing motor is broken and it is replaceable
Jul 31, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Changing my appiture
You will need to be in AV or manual mode to change your apperture.
AV is apperture priority and manual allows you full control of all settings on your camera.
Hope this helps!
May 16, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
400D total blackness
Hi, sounds like a shutter problem, try taking a picture in manual mode with an exposure of around 1 second and the aperture stopped right down (small appiture)in daylight.
when you say its not pretty i guess you mean blurred?
If your still getting a black image, take the lens off and put it in bulb and press and hold the shutter release if the shutter dose'nt open and stay open while you hold it then its certainly the shutter.
Its not your fault, all the eos cameras are prone to shutter failure
some are fine for 50,000+ shots others die within a thousand
My fingers are crossed for you that its under warranty.If not a repair in the uk can be done for around 140ukp or $200 in the US, the shutter isn't expensive (about $60) but its several hours work to replace it
Best of luck
Mar 10, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Nikon D40x Digital Camera Logo
65 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
