Question about Sony VPL-HS51A / VPL-HS60 Multimedia Projector
VPL-HS60 Scene Dimming
I have about 900 hours on this Sony VPL-HS60, lately the whole picture just becomes a little dimmer then swiches back to the correct brightness, it seems like this happens when the projector is on for a while (after an hour or so). Does the lamp need to change? anybody has any ideas?
Thanks.
  • 563 Answers
Hi 3mad
This is quite a sticky one as this could either be the lamp or the Ballast ( lamp's powersupply )
And the bad thing is that the only way to be certain , would be to first replace the lamp and if this continues the Ballast as well.
I would suggest you to replace the lamp first , as this is never a waste , you could always keep it as a spare and 99% of the time it is the lamp will give this kind of problem.
Good luck and thanks for using Fixya !
Posted on May 21, 2008
Vpl-hs60 projector diagonal is off
You should be able to readjust the picture by moving the projector physically till you find the sweet spot.
Mar 24, 2008 | Sony VPL-HS51A / VPL-HS60 Multimedia...
I have a big yellow circle in the middle of my projected video. Can this be reset?
no you cannot remove, you have to change the screen inside the monitor. the spot cause burn on the screen picture.
Aug 29, 2011 | Sony VPL-HS51A / VPL-HS60 Multimedia...
I have changed the bulb on my Sony VPL-HS50 video projector and the image is now in black and white. I folloewd the instructions in the manual word for word. The bulb is a Sony genuine part
Is the buld u changed right and in working condition.please clean the optic lens and image CRT board which ( Scanner image board) to see if the issue remaisn or nott
Sep 28, 2010 | Sony VPL-HS51A / VPL-HS60 Multimedia...
The fleshtones of people on the screen is blue
This is not really a solution but when mine does this I switch the input to the projector to another video source and then back again. this usually makes it go away. If you find a better solution I would appreciate hearing it. Thanks.
Jul 06, 2009 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Reset Timer Lamp Sony VPL-HS60 projector
According to the manual, you need access to the RESET button, the left and right arrows and the ENTER button to clear the counter. Press the following in order for less than 5 seconds each:
RESET
Left Arror
Right Arrow
ENTER
The above sequence should clear the counter.
Dan
Apr 09, 2009 | Sony VPL-ES2 LCD Projector
Sony
Turn on projector and Press following button on remote in following order for less then 5 seconds..
RESET, <==, ==>, ENTER.
Above procedure is written in user manual page-49
If you need user manual of VPL-HS50, click Sony Support.
Feb 11, 2009 | Sony VPL-HS51A / VPL-HS60 Multimedia...
To reset the lamp timer:
1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this is not clear in manual).
2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER.
3) Timer should now read '0'.
Jan 14, 2008 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Problems using HDMI
I've had a problem with the HDMI connector, had it replaced twice while my VPL-HS60 was under warranty. This connector seems very fragile, the first time I was not getting any signal from HDMI, so the repair shop ordered a new connector and replaced it, a couple of days after the it was not working again and found that they had to solder it back on the board. If you're not getting a signal from HDMI anymore that could be your problem.
Nov 29, 2007 | Sony VPL-HS51A / VPL-HS60 Multimedia...
I also have this same problem with my HS51A... With nothing on the screen you can see that the panel is physically shifted.
Aug 21, 2007 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Sony VPL-HS51A / VPL-HS60 Multimedia Projector Logo
183 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
