When i place my video card into my mobo all i get is a black screen. So i place my old agp card back and works fine. i place my ATI X1650 Pro, AGP to my friends mobo it works fine. I dont know y?When i place my video card into my mobo all i get is a black screen. So i place my old agp card back and works fine. i place my ATI X1650 Pro, AGP to my friends mobo it works fine. I dont know y?
I install the driver(the version of the official site)and then my icons not appears.At the third restart of my pc the windows ran at 4bit:(.Can anyone help me please?
I had a simer problem if it is connected with the HD compisit cable
you need to go in to the catalyst control center under advance view you have display options were it will list the 2 diplays and have a third display in a gray box under it
right click on the third display and go to swap that should resolve the issue
firstly you need to make sure *********** board has a PCIe slot or a AGP... this is where your ATI HD3650 will go...see the graphic 512mb has nothing to with your main system RAM which is also 512mb.. so they wont be any problems as such and both will work together without any problems... but i suggest you to add another 512mb to your system RAM.. the difference between DDR and DDR2 is that... DDR2 is a bit newer and is faster in terms of memory read/write/access... do let me know if u have any futher problems....
Yes you can run the AGP version of the Radeon 1650 pro on your system. It is always best & recommended to upgrade memory in pairs. You could upgrade to `gb by purchasing a 1 gb kit which would be 512 x 2. That way you have a matching pair of RAM modules. As for a cpu upgrade you can go to the Asus website and see what cpu's are supported by your motherboard. Hope this helps & please remember to rate my answer. Thanks.
For this card they recomment at leat a power supply rating of 450 watts. If you have lower than this then I would suggest upgrading the power supply. A 550 watt psu is reasonably priced and should give you plenty of power for future use. Hope this helps.
If you have on board graphics try removing video card and reboot when computer rebooted turn it of and refit card and restart when restarted computer should recognize new hard ware and should find the already installed drivers if not try installing drivers again Sometimes windows does not recognize new hardware until its refitted had this problem with modems alot and the above method solved it
the card you have is a PCI express 16X your board is for PCI express 8X. I think some cards can run at a slower speed but I believe you have the wrong card for your board
My bad, i was going to just ask about your PSU and went on trying to fix your problem :) If you do download rivatuner, check how hot your graphics card is running in graphics intensive games (it has a chart recorder). BTW I have a 1600XT and speeding up the fan helped a lot!
Maybe this post is a bit old, but on last deceber I bought an AGP 512MB ATI Radeon X1650 PRO for my Foxconn motherboard and I must say that it's simply awesome!
I can play most games on mid-high settings on reasonable resolutions (most on 1024x768) with good FPS (except with Crysis... but let's face it, did Crytek bought a time machine to warp a 2010 game??).
So, if you already have it, then congratulations, and if you still are thinking on buying it, then what are you waiting for!?
Also, it's AGP x8, if your motherboard support x8, then it should run perfectly fine.
Also, I have a bit of problems trying to run Prey on the X1650...
It always appears an error... it's not of much importance, as I have much better games, but I haven't tried it with high fancy graphics... :P
MOTHERBOARDS
does my motherboard support video cards like
ATI RADEON X1650 512MB AGP?
---YES, When you installing AGP card, please make sure the following notice is fully understood and practiced. If your AGP card has
"AGP 4X/8X (1.5V) notch"(show below), please make sure your AGP card is AGP 4X/8X (1.5V).
Caution: AGP 2X card is not supported by Intel® 845(GE/PE) / 845(G) / 850(E) / E7205 / 865(G/PE/P) / 875P. You might experience system
unable to boot up normally. Please insert an AGP 4X/8X card.
Does it support ddr2 or ddr3 memmory for the agp?
---YES, see the above notes
can the agp memmory be over 512 mb?
More more information go here >>>
http://asia.giga-byte.com/FileList/Manual/motherboard_manual_8ipe1000g_e.pdf
Hope This Helps
If you are having trouble with a Newly bought items then return them and demand a replacement or a refund!
You may have purchased a reconditioned\repaired\factory defect product.
some time it dont find the divice for this ok sir
ATI Radeon HD 3650 Series
yes. i also get a black screen. XD
Nice card - what's the problem?
