Question about Sony Playstation 3 (PS3) Console
Help me please
How do you fix hard disc and files corrupted then it says restoring and does the same thing all over again
  • 3,037 Answers
If you send it to sony most likely they will send you a new one as you basically need a new hard drive. If they plan on charging you for a new one, you should just replace the hard drive yourself. First call Sony at 800-488-7669 and see what they will do for you. Otherwise you could try returning it to the store but I don't know your warranty situation.
The option of replacing your hard drive would be the next feasible option if you can't get sony or the store to replace it for free.
this link will tell you what you need to do a complete replacement of the hard drive which wouldn't be too hard if you want to go with this option.
http://www.gamespot.com/features/6176090/index.html?cpage=4
Please let me know if you have any further questions and I would be glad to help you, good luck
Posted on May 21, 2008
    Genius:
  • 2,035 Answers
First if its within warranty please get it replaced any manual opening of the PS3 could lead to out of warranty.................
use this company link:
http://www.us.playstation.com/Support/PS3/Troubleshooting/default.html
or : you can try this:
if (u can get past the screen saying "hard drive file system corrupt") u use a memory stick u can upload all ur save files on ur ps3 (make sure u put files in a folder with no other files because u can end up with **** loads of corrupt data) but if (like me ) u r stuck on the screen saying hard drive file system... then u hav 2 re format by following what the instructions onscreen say.
good luck ........................
    Brigadier General:
  • 6,966 Answers
Three options:
1. Call the customer service number that should be listed in your console's user manual. They'll be able to walk you through any troubleshooting methods that are available (if this is a known problem) or direct you on how to send your console in for repair. You can also try 08705 998 877 or 1-800-345-SONY;
2. borrow/buy a 3.5 sata usb enclosure. Remove the hard drive from the PS3. Insert the hardrive into the closure and connect it to your computer. format the harddrive and put it back into the PS3;
3. replace the hard drive if determined by the PC to be mechanically/electrically defective.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
    Brigadier General:
  • 3,614 Answers
How do I use the Restore Default Settings for the PLAYSTATION®3 computer entertainment system
click HERE..- or - click in HERE
Thank you.
    Master:
  • 555 Answers
Instructions on restoring your PS3 system are available here from Sony.
Adobe illustrator file corruption. What to do?
First check your illustrator. Could it open other files or not? Try to create new file and save it, then open again.
Try to open your corrupted file on another PC. Then if it doesn't work, it means that your file is corrupted. So you should try to restore it by Recovery Toolbox for Illustrator . You can download it here http://www.illustrator.recoverytoolbox.com/
Also you can read here about corrupted file recovery: http://www.filerepairforum.com/forum/adobe/adobe-aa/illustrator/513-adobe-illustrator-file-corruption
Nov 18, 2014 | Adobe Illustrator CS3 - Windows for PC...
Disc not being recognized.
The current version of the ps3 firmware has a “recovery console”.
You access it by
1. Start with having the system in standby (redlight is on)
2. Hold the power button down; the system will turn on and turn off once again.
3. Press and hold the power button again and keep holding, it will beep as it turns on and then it will double beep. When you hear the double beeps immediately take your finger off the power button (if your system turns off before you get a double beep just try again and hold the button, it should double beep the 2nd time you try)
4. You will be prompted to plug in your controller via USB and then hit the PS button
You will now have a screen with these options
1. Restart System: Restarts the PLAYSTATION®3 System.
2. Restore Default Settings: Reset all system settings back to default.
CHOOSE THIS ONE 3.Restore File System: Checks for corrupt/missing system files.
4. Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
5. Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
6. System Update: Update the PLAYSTATION®3 System
IT IS VERY IMPORTANT THAT YOU DO NOT CHOOSE THE WRONG OPTION HERE OR YOU WILL LOSE ALL YOUR DATA. The one that fixed my blu-ray drive is option 3: RESTORE FILE SYSTEM
I REPEAT CHOOSE RESTORE FILE SYSTEM
After this, it is going to restart and bring up a screen reading something like “you have Corrupted System Data. Your PS will now replace this data” Then you choose continue and that should be it.
This option reinstalls the system files and drivers inside the PS3 with the original ones that are stored on your hard drive. In this case, it replaced a corrupted driver for the blu ray drive thus fixing my issue and hopefully yours!! This option will only replace all system files thus saving you from loosing any data that’s stored on your hard drive. Again this option does nothing to your hard drive it reads a file from the drive and rewrites it to the PS3 system.
Here is a video of the recovery screen.
www.youtube.com/watch?v=m0SPmkV-jco
If you want a more technical understanding of what this is really doing continue reading. DO NOT NEED TO READ THIS TO COMPLETE REPAIR. The PS3 does not boot from your hard drive as a computer does. It has a flash memory like a cell phone that stores all system files and system firmware updates that you get when the PS3 updates. This is why reformatting your hard drive will not fix your problem, none of the system files are stored on your hard drive (ex. XMB, system firmware, etc.) nor do they run from the drive. However, your hard drive does contain a full backup of your SYSTEM files and thus when you choose option 3: RESTORE FILE SYSTEM it rewrites the original system files from your drive (which aren’t corrupted) back to the flash memory which is corrupted thus fixing the problem.
Aug 21, 2010 | Sony Video Game Consoles & Games
My ps3 says hard disc file carupted it will be restored but wont restore
bigbazcmon
If you are getting the corrupted file message then this mean you have corrupted data on your hard drive or there is something wrong with the hard drive.
The link below will help you format the drive externally. If this does not fix the problem then you will need to replace the hard drive.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Aug 12, 2010 | Sony Playstation 3 (PS3) Console
Hard drive corrupt won't restore
the only thing that you can do is to replace your hardrive and then reset it this will clear any error messages that you may have had because of your hardrive being corrupted
Hope that i could Help!
Jul 15, 2010 | Sony Playstation 3 (PS3) Console
Disc reading problem
Be sure to folleow these instructions to the letter, you could damage your PS32_bing.gif if you choose the wrong option! I do not take any responsibility! Please proceed at your own risk! If you read and follow the instructions exactly you should not loose any data! Feel free to ask questions if you are confused so you don’t make a mistake!! Sorry, I had to say it, I don’t want anyone mad at me if they make a mistake, don’t back up their data and erase it, and then blame me…
You access it by
Mar 13, 2010 | Sony Playstation 3 (PS3) Console
Donald
If the hard drive will not reformat itself, then it needs to be replaced.
Aug 21, 2009 | Sony Playstation 3 (PS3) Console
I just receiver recovery and system disc from Acer to restore my laptop to factory settings. I tried couple times and followed the instructions. The recovery disc formatted partition 2 on the computer but...
Looks like your recovery cd is corrupted. You must obtain a copy of Ms Windows cd and install it using the license from the back of your laptop.If that doesn't work either its a hardware related (hdd) problem.
Aug 19, 2009 | Acer Extensa 5620-4677 Notebook
THE HARD DISK'S FILE SYSTEM IS CORRUPTED AND WILL BE RESTORED
hold in the power button until you hear 2 beeps. might not work the first time. if no 2 beeps repeat power button again or until 2 beeps. go to restore hard disc and click on it. you will lose anything saved on the hard disc but fixes it 75% of the time. did it myself this morning.
Nov 15, 2008 | Sony Playstation 3 (PS3) Console
Plesase help me
you need to reformat the ps3 call sony for more information and when you get the automated press 0
May 21, 2008 | Sony Playstation 3 (PS3) Console
External hard drive -help please?
Hi
Have you checked it on other pc ? If yes then your hard disk is corrupted you lost partition information but dont worry u can retrieve your data by getbackdata for NTSF. Its able to retrieve about 98% of data or other is Acronis Disc Direct Suite, the same reliable and really working tool to restore information. It really restored ALL files in lost partition
After using these tools just format your hardisk and it will work dont worry
Regards
Balisonu79
Feb 14, 2008 | Sony 1.44MB Floppy Floppy Drive
Sony Playstation 3 (PS3) Console Logo
95 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
