Question about Apple iPod shuffle Second Gen. Silver (1 GB) MP3 Player (MA564LL/A)
I-pod shuffle copatibility with car stereo
Can I use the shuffle dock that allows you to conect to regular I-pod speaker docks to hook up to a car stereo that has I-pod controls built in. specificly sony explod
No, The iPod Shuffle only transmits Audio, not data.
Posted on May 21, 2008
Wen i connect my i pod to computer it does not connect
Check to see whether your iPod shuffle is the original stick version or the newer version, which plugs into the iPod dock connector.
Turn your PC on.
The PC needs to be on to transfer music and charge the iPod shuffle.
Place the iPod shuffle in the iPod dock connector if you have the newer version.
If you're using the original version, then plug it directly into a high-power USB port on your PC.
Check the monitor to ensure iTunes has loaded.
This means a connection was established.
hope this helps
Oct 11, 2012 | Apple iPod shuffle MP3 Player
Don't how to connect iphone to ear speaker
moz-screenshot-12.pngmoz-screenshot-13.pngmoz-screenshot-14.pngmoz-screenshot-15.png honestytessy.jpgHow to Connect an iPod to a Speaker Bar
A speaker bar is a (usually portable) speaker system that includes a dock for an iPod. The unit is usually bar-shaped, with either a rectangular or cylindrical cross-section. Connecting an iPod to a speaker bar is usually as simple as plugging it in. Many speaker bars will also charge the iPod while it is connected. However some do not have an iPod dock, in which case the iPod must be connected by a 3.5mm audio cable.
Instructions
Things You'll Need:
* 3.5mm cable (for some speaker bars)
Turn the iPod on. Look to see if the speaker bar has a dock for the iPod. The dock will fit an iPod perfectly and will generally be located in the center of the speaker bar. There will be a connector that resembles the connector on the docking cable that came with the iPod. Place the iPod on the docking station and turn on the speaker bar. Such is the case with the "2.1 Channel Bar Speaker with Dock for iPod" or the "Yamaha YAS-71BL Front Surround Speaker System"
iPod headphones use a 3.5mm audio cable.
Connect the iPod via the 3.5mm cable. If the speaker bar does not have a docking station it will have a 3.5mm cable connector with a jack like the headphone jack on iPod ear pods. Plug the 3.5mm cable in the iPod headphone jack. Plug the other end in the iPod. Turn on the speaker bar. The procedure is straight forward and Apple specifically designed the headphone jack with third party stereos in mind.
Select a song on the iPod and play it. The speaker bar will play the music from the iPod.
Hope that helped..
have a nice day.
Feb 23, 2011 | Audio Players & Recorders
I have a Sonic Integrity Tube Pod (Tube Pod) and need to know how to make it work with iphone 4. I can play the iphone 4 only through the earphone jack at this point. The iphone 4 however can sit on the...
It is normal to get incompatible devie message when you attach your iphone to dock because you don't use apple dock. I have 5 different brand portable speakers, charging docks. And all of them give same message when i attach my iphone 4 to dock. When you press "ok" on your iphone screen, it should start to play your songs. You don't need to use your iphone at airplane mode.
You may have problem with your iphone dock conncector cable pins. If audio related pins are damaged, you can not use any external iphone speakers with your iphone4. In order to test your sonic integrity tube pod; try another ipod or iphone on its dock. If it gives same result, you may need to change dock connector unit on sonic integrity tube pod due to damaged pins. If it works; iphone 4 dock connetor cable of your iphone 4 needs to be replaced.
Nov 29, 2010 | Sonic Integrity MP5-DS iPod Tube Docking...
I just bought a I Pod dock ASD 11R and would like
Get a 3.5 plug with two RCA plugs and connect it to an aux imput via the headphone out of the dock.
Jan 24, 2010 | Denon AVR-3803 Receiver
Shuffel and universal dock
you can't .... If you want to use the ipod to play music through a stereo system you will need a 3.5 mm audio jack and use this to connect.. but the shuffle will not hook up to a universal dock made for regular ipods
Oct 18, 2009 | Apple iPod shuffle Second Gen. Silver (1...
My docking station has a loose conection where the i pod sits!
You need to dismantle the unit and resolder the ipod socket. It is soldered to the board and the solder joints crack under the strain. This will happen to every JBL dock eventually.
Jun 19, 2009 | JBL (JBLRADIALWHT) Speaker System, Docking...
Need a dock
Greetings ronvibb,
Your in luck! (I almost thought this couldn't be done with a shuffle) There is an adapter that should allow you to connect your shuffle with the standard Yamaha ipod accessory. The adapter can be found at:
http://www.bestbuy.com/site/olspage.jsp?skuId=8525287&st=ipod+shuffle+docking+stations&lp=7&type=product&cp=1&id=1186007813594
Enjoy the music.
Jon
Go Ahead. Use Us.
Jun 22, 2008 | Audio Players & Recorders
Charge
k i have the same model>try this when hook the i-pod on the docking make sure its off and charge ir fully for one hour and check
Oct 17, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Apple iPod  shuffle Second Gen. Silver (1 GB) MP3 Player (MA564LL/A) Logo
88 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
