Question about Philips 60PP9363 60" Rear Projection HDTV-Ready Television
Philips 55 inch hdtv rear projector
TV has a problem, there is a white haze around all white color in the picture and when there are black or black shadow the darkness gets real dark. there are white halo around black or shadow when both white and black are together. Does it worth the fix (cost) or just buy a new one.
  • Philips Master
  • 3,459 Answers
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Jan 26, 2009
  • Edward
    Edward Feb 16, 2009
    Your TV most likely has one or more possible problems.
    Problem #1: Convergence Chip Failure ( common problem )
    Here are some of the most common symptoms and example photos of a convergence problem
    • Screen looks 3D
    • Colors don't line up
    • One or more colors can't be adjusted when using the convergence menu.
    • Screen is bowed or warped.
    Here is a quick test....
    Using your original remote go-to the tv settings then goto the convergence section.
    Try to adjust the red and then the blue convergence.
    You should be able to move them up, down, left, and right.
    If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
    Solution #1
    You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
    Problem #2 CRT Fluid is Cloudy
    Picture of a set that needs the fluid changed.
    TV set after fluid change
    Solution #2
  • Edward
    Edward Feb 16, 2009
    • Screen looks 3D
    Solution #1
    Solution #2
I have a phillips rear projection tv model no 55PP8620/79. Its showing a a red haze and poor picture quality. How do I fix this?
If the red haze is not convergence---that requires parts.
The set has three picture tubes---with set unplugged and back cover removed clean the three large lens that are topside---as for the red haze a quick way to know what is wrong is with set on turn the color to zero----what color is the screen? Should be black and white--if red to some degree tracking or screen controls may need adjusting inside the set---Yellow picture in that situation is a different issue.
Jun 05, 2012 | Philips Televison & Video
58'' TV IS SHOWING ALL RED
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 21, 2010 | Philips 55PW9363 55" Rear Projection...
The image appears to have excessive yellow tint. and there are no images coming thru the blue projector
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • TV shutdown - does not display video
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 20, 2010 | Philips 55PW9363 55" Rear Projection...
55 inch with blue ghost like glow on white or blue colors
Inside of your TV their is a fluid that keeps the tubes cool. Over the years this fluid will turn cloudy and cuase the screen to look dull, bright white, have halos, etc. You can get the fluid over the internet from various sources or your can get a complete kit including repair instructions from www.TvRepairKits.com.
May 08, 2009 | Philips 55PW9363 55" Rear Projection...
Blue color bleeding
the color issue is most likely the crt coolant needs to be replaced you can get the phillips CRT coolant replacement kit at the following link which contains the coolant and the instructions on how to do the replacement.
http://servicemanuals.vstore.ca/
The crack you hear could just be the speakers or a intermitant ground problem in the audio circuit more likely the spealers if its only on strong Bass
Apr 03, 2009 | Philips 55PW9363 55" Rear Projection...
Black and white picture
you have the cables hooked up the wrong way
Nov 09, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Philips 55PP9401 ProjectionTelevision
it seems as you need your tubes re-alinged dont get riped off by tv experts saying it will cost you loads if you have a screw driver and a gentl touch just re focus your red green and blue-simple cost you nothing
Aug 08, 2007 | Philips 55PP9401 55" Rear Projection...
BIG TROUBLE with my 52" Phillips Magnavox Rear Projection Tv, HELP!!
It sounds like the 3 "GUNS" are not aligned.
One the controls at the bottom, left hand side You will see an arrow pointing to the first 2 on the left.
That will allow you to scroll down the list of options until you see....CONVERGANCE!
make the red gun center by using the up/down arrows on right. Then add the next 2 until you see a white X or cross.
Thats it!
Mike
Jul 16, 2007 | Philips Magnavox 51MP392H Rear Projection...
Green dot in middile of my screen
The green dot in the center sounds like a burn mark on one or more of the picture tubes inside the set, and the curved lines are telling me that you have a problem in the convergence circuits. The blue haze around everything white tells me you either have a lot of dust build up on the lens over the CRTs, or your picture tube(s) are very weak. If this set is over about 12 years old, I would replace it. I doubt if you will be able to get the green dot out of the picture without changing the tubes which would be VERY expensive.
Jan 05, 2007 | Philips 60PP9401 60" Rear Projection...
Philips 60PP9363 60" Rear Projection HDTV-Ready Television Logo
1,372 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
