Roku Soundbridge M1001 won't see BestBuy Rhapsody
I have a Roku Soundbridge M1001 that is seen by Rhapsody, but when I attempt to access Rhapsody, it refuses to see that Rhapsody is loaded and that its libraries are available. I have a Linksys wireless modem identified by Roku as working well with their device. Add to this that ITunes is recognized immediately, and this tells me that the fault is with BestBuy Rhapsody. Help!
cyrylthewolf
  • 143 Answers
SOURCE: hookup with Vonage device
I am going to attempt to give you a solution here. But you must understand a few things before I begin.
First, I would like to clarify that if you have Time Warner internet service, you are on Cable Internet. Not DSL. (This makes a world of difference when it comes to using a router.)
Secondly, you did not specify model numbers of your devices. Therefore I am assuming that you are using the following devices:
If this is not the correct equipment, continue to follow the instructions but be dynamic and adapt my instructions to the equipment you have. It should be similar enough that you shouldn't have any problem easily doing this.
This instruction set is going to begin from a point that is assuming that we're installing all of this equipment from the standpoint of a completely new installation. From the ground up.
Let's begin.
UNPLUG AND POWER DOWN ALL OF YOUR EQUIPMENT INCLUDING THE CABLE MODEM, ROUTER, PC AND VONAGE BOX. Do not power on any of the devices until instructed to do so.
1.) Connect your cable modem to the cable from the wall.
2.) Find the ethernet port on your cable modem. Connect the blue ethernet (CAT5) cable to the ethernet port.
3.) Plug the other end of the blue ethernet cable into the "Internet" port of the router. (Older routers used to also call this a "WAN" port.) It is the only port that is seperated from the rest of them.
4.) Connect another ethernet cable to port 1 of the router.
5.) Connect the other end of the ethernet cable to the network port of your PC.
6.) Connect yet another ethernet cable to port 2 of the router.
7.) Connect the other end of this ethernet cable to the ethernet port of the Vonage box.
8.) Plug in the power adapter of the cable modem. Wait 1 minute for the cable modem to acquire it's signal and set up the connection to Time Warner.
9.) Plug in the power adapter of the Linksys router. It should only take 15-20 seconds to set itself up. (If you have made any configurations to the router prior to this, I recommend pressing and holding the RESET button for at least 10 seconds to give you a fresh configuration state to start with.)
10.) Plug in the power adapter to the Linksys PAP2 VOIP Phone Adapter.
11.) Power on your PC. You should have an internet connection with it.
You see... As I read the configuration you described, I don't think that you're using a PAP2 phone adapter. You said that you connected the "vonage device" to both your modem and your PC. This is not possible with the PAP2 adapter as it only has ONE ethernet port.
I am led to believe that you are actually using the Linksys WRTP54G which is essentially the same thing as the WRT54G, but with Vonage support built-in.
If that is the case, then you will not need to use the WRT54G router. Instead, follow the instructions that I gave you assuming that the router and the phone device are combined into one device. (The ports will still be labeled the same.)
Download the installation guide for the WRTP54G from the product page link I just gave you. You'll find the link to the User Guide on the right-side panel. This will make everything clearer for you if you do indeed have that router instead of the PAP2 phone adapter.
If you continue to be confused, please let me know. DO NOT just give me a poor rating without asking more questions. I am here to help you solve your issue. Not have my rating decreased just because someone is too confused or lazy to ask more questions.
I'm happy to help you. :)
Good luck and let me know what the outcome is. (And please be sure to list your exact model numbers in the future!)
Cyryl
Posted on Nov 11, 2007
  • 205 Answers
SOURCE: Lost Ethernet and Wireless Connections in Modem
I've not used one of these 2wire boxes before, but I believe the default router's address is 192.168.0.1. Try this instead of gateway.2wire.net to see if you can gain access to the router. This is just the starting point, but see if it works.
Here's a link to, what I believe is, the router's manual.
Before you rate this please let me try to help some more. This could be a multi step process...
Posted on Dec 29, 2007
Agent Aaron
  • 265 Answers
SOURCE: Loading My ITunes library into new Sansa Clip
Hey guyi,
According to information provided by the manufacturer (Sandisk), the Sansa Clip MP3 player can use two different methods to upload songs: a simple drag-and-drop interface, or syncronizing the player with Windows Media Player.
With the traditional drag-and-drop interface, you would need to connect the player to your computer and select the "Open device to view files using Windows Explorer" option when it is presented. Once you have done this, you should be able to double-click on the "Sansa" player and then the "Music" folder. After this folder has been opened, you should be able to drag and drop (or copy/paste) the files into this folder to upload them to the player.
For more information or instructions on how to add files to your Sansa music library using Windows Media Player however, you may wish to refer to your owner's manual or the following link on the manufacturer's website:
http://www.sandisk.com/assets/File/Downloads/user-guides/clip-usermanual.pdf
Unfortunately Windows Media Player does not currently appear to support the ability to directly import iPod playlists, but if you keep most of your music files in the same folder/directory on your computer, both programs should be able to share the same music library. Please keep in mind that this may only apply to music that you loaded onto the computer yourself and other unprotected file formats that both programs recongize (like .MP3 files), and may not necessarily apply to copy-protected songs downloaded from iTunes or other online music services.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on May 30, 2008
xbox fan
  • 28 Answers
SOURCE: Xbox 360 to Linksys wireless modem...
OK I think the easiest way to connect the xbox to the linksys, is if you configure your XBOX to have a static IP address, because the xbox will not have to pick an IP address every time you connect to the internet using the Linksys router and will not have conflicts with other PCs on your house, if you have any. What the linksys does is to convert your Public IP addres into a Private IP address, so example if your ISP gave you an IP address of: 209.235.205.30 that is your IP address for you, then the Linksys converts that number (NAT) into a private IP address so it can be share with many computer inside your house using a single Public IP address. The Linksys always transform it into 192.168.1.?=any number between 1-256 thats the defaults IP address from the manufacturer but you can change it if you want. Ok enough info about NAT or IP jeje.
Where going to use the default IP addres for an easier setup.
First: On your XBOX 360 dashboard go to SYSTEM, then Network Settings, then Edit Settings, then choose the option manual, here put the IP address= 192.168.1.33 (if 33 doesn't work use another numer like 20 or 45 just pick a number between 2 and 250) ; Subnet Mask = 255.255.255.0 ; Gateway = 192.168.1.1; DNS options put Automatic. And see if it connects. If it doesn't work just post it here, any problem that you have.
Posted on Aug 27, 2008
govinda123
  • 2263 Answers
SOURCE: I have a linksys wrt160n wireless router,,
Is there any computer connected to the router ?
If not then connect the computer to the router. If you are connecting a wireless computer then disable the wireless connection on the computer. open the set up page of the router. change the wireless network name to something different that you never used before. change the standard channel to 11. save the settings. Try to connect to the wireless network. Check if you see the new network name ? If you see the new then try t connect and see if that works.
This router WRT160N has issues with the firmware.
Upgrade the firmware of the router. power cycle the router.
Click here for more information about router and network
Posted on Feb 28, 2010
How do I enter code for roku
Go online to the website for whatever channel you are attempting to access.
You need to be online to enter such a code.
Mar 08, 2015 | Roku Televison & Video
I can not gain access to the full set of numbers or alphabet to sign up my email password on the tv
https://my.roku.com/signin to do it, or the website specific to the channel you are attempting to access.
Mar 07, 2015 | Roku Streaming Stick HDMI Version
Trying to link my roku to tv to get facebook
If you haven't done so already, you first need to create a Roku account at the following link: Welcome to your Roku account
Then you will be able to enter the link code from your device at the following link:Roku Link Device , this will link your Roku device to the Roku account you've created.
After you've completed the previous steps, you may now enter the linking code given when trying to open the Facebook Roku Channel on your Roku device. Here's the link: Facebook logo
When attempting to open an unregistered channel for the first time on your Roku Device/TV, which requires a 'Code' for activation, it will show you the specific web-address needed to be opened with a browser on your computer, and your activation code to link both channel, and device.
Feb 11, 2015 | Roku Streaming Stick
I have an emachine and installed airlink 101 ,,keeps kicking me off line..what do i do? i am online for 5 minutes then it kicks me off IE. says i am still connected.. HELP!! thanks
The following wireless access points/routers have been tested for use with the SoundBridge and SoundBridge Radio. While Roku is unable to provide testing results for all available wireless access point and routers, the vast majority will work fine with your SoundBridge product. We encourage you to try using your SoundBridge with your existing wireless equipment, regardless of published result before replacing your current hardware.
The current SoundBridge models, M1001 (connections on the back) and SoundBridge Radio R1000, use different wireless hardware than the older M1000, M500 and M2000 models (connections under the endcaps). This newer hardware has proven considerably more reliable than the older wireless hardware and should work out-of-the-box with virtually any 802.11b-compatible wireless equipment you may have. Compatibility of the older hardware has been improved over time and we recommend that you upgrade your SoundBridge's software to the latest version as soon as possible, particularly if your SoundBridge was delivered with software older than version 2.3.44. Upgrading older software may require using a wired ethernet connection or even taking your SoundBridge to a neighbors house or your office to sucessfully perform the upgrade.
To check your software version and perform an upgrade, use your SoundBridge remote control to navigate to the menu Change Library or Configuration -> System Configuration -> Software Version and Updates and follow the on-screen instructions.
If you still experience Wi-Fi connection problems, check the following items:
  • Make sure your access point/router is configured to allow 802.11b devices to connect. This may be phrased as "Mixed mode" or "802.11b +802.11g".
  • If you have wireless security enabled, make sure it is a supported protocol, and make sure you are using the "Hex" key. See your SoundBridge manual for more information.
If, after checking these items, you still cannot get your SoundBridge to connect to your wireless network, we encourage you to contact support or visit our Roku Community Forums where other customers and Roku employees will attempt to help you.
Bold = recommended by Roku for use with the latest version of SoundBridge software.
Red = poor performance or incompatible with SoundBridge
* = customer tested - your results may differ.
Model M1001,
R1000
M1000,M500,
M2000
Notes Airlink101 AR410W Yes Yes Fast! Apple Airport Extreme (Snow) Yes Yes Buffalo WBR-G54 Yes Yes Very reliable Buffalo WBR2-G54 Yes Yes
D-Link DI-514 B1 Yes Yes
D-Link DI 624 Yes Yes D-Link DI 784 Yes Yes D-Link DIR-655 * Yes Yes Set to b/g or b only. Problems reported in b/g/n mode. Linksys WAG300N * Yes Yes Disable wireless AP isolation. Linksys WRT51AB Yes Yes
Linksys WRT54G Yes Yes
Linksys WRT54GC Yes Yes Linksys WRT54GS Yes Yes Works great Motorola WA840G Yes Yes Works great Motorola WR850G * Yes Yes Wireless mode should be set to Compatibility. Problems have been reported with using Performance wireless mode. Netgear DG834Gv3 * Yes Yes Firmware v4.01.06 may be required for internet connectivity and WPA. Netgear DG834G Yes Yes Netgear WGR614 v5 Yes Yes Netgear WGT624 (all hardware revisions) Yes Yes Netgear RangeMax WPN824 Yes Yes Works great. Siemens GigaSet SE361 * Yes Yes SMC SMC2804WBRP-G Yes Yes Needs firmware v 1.956 or greater SMC SMC2804WBR Yes Yes
USR 8054 Yes Yes Needs firmware v 1.64 or greater XRouter Aero WSR-5000 Yes Yes ZyXEL Prestige 335WT * Yes Yes AirLink AR315W Yes Yes Poor performance Airlink AR420W * AP/Router/Switch No
AVM 3070 * AP/Router/Switch No
D-Link DI-524 AP/Router/Switch No Some users report this router works fine for them. Linksys BEFW11S4 No No. Performance is unacceptable Linksys WRT54GL * No No Downgrading to original firmware fixes rebuffering issues. Linksys WRT54GP2 Yes Yes Very slow performance Linksys WRT55AG Yes Yes Works, but some customers have reported issues with accessing the Internet through this device Netgear FVM318 Yes Yes May work for some, does not properly route UPnP discovery packets between wired and wifi Netgear MR814V2 Yes Yes Poor performance Netgear WGR614 v4 Yes Yes May require B-only mode . SpeedTouch 716G * Yes Yes Can connect wirelessly and stream locally, but no internet access. USR 5462 Yes No
Note: If your wireless access point does not work well with the SoundBridge, please make sure that both the SoundBridge and the access point are using the latest firmware available.
Apr 20, 2013 | Computers & Internet
Need registration code to link a roku to amazon prime
I have the save problem when i access my amazon prime video, and this topic does help me out. BTW, if you hope to copy or share your Amazon video purchases anywhere, you may interest in removing DRM from Amazon video on demand.
Apr 15, 2012 | Roku 2 HD
How do i connect a roku soundbridge to TX-NR509? I have tried optical, coaxial, and rca connectors. I have tried every inout.
The Soundbridge only has Audio OUTputs, so they would only work with INputs on a downstream device. Did it not come with a manual?
http://soundbridge.roku.com/support/userguide.php
http://soundbridge.roku.com/soundbridge/features.php
The Soundbridge is for all intents and purposes an external digital or analog source, not unlike a CD player, from the TX-NR509's perspective. ANY digital input must be assigned internally at the TX-509, which also has documentation here...
http://www.onkyousa.com/download/own_manuals.cfm
Jul 09, 2011 | Audio Players & Recorders
WHERE CAN I GET A BASS KNOB FOR ALPINE MRD-M1001
Any AUTHORIZED DEALER of this Product Although this Spacific Part May NOT be Available, Not EVEN From Manufacturer.
May 12, 2010 | Alpine MRD-M1001 Car Audio Amplifier
Need to enter code for roku
what's the exact model of the ROKU It will be asking for the wireless security pass code for your wireless router , I have a M1001 and you can set that up if known from the wireless configuration - after it asks for SSID - it then asks if security enabled say - yes and enter the code - IF you do know the code
Your Wireless signal may already be secured by the manufacturer and often the wireless code is printed on a label stuck to the router itself
IF not already set here is how you can see the wireless security code. Log into the setup of the router - to do that open a web browser, use Internet explorer (some routers setup pages do not work correctly with other browsers) In the browser address bar - type:
Different manufacturers use different default address to To access the Web-based Utility of the Router and log into the setup pages
DLink Type: http://192.168.0.1
A setup login screen should now appear requesting a user name and the password - use admin for both username and password - default setting for the d-link Now you can goto the wireless section or secruity section and see the type of encyption to WEP, WPA, WPA-PSK and the code used
Apr 10, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Station memory problem
Sorry, I haven't addressed the station memory problem further since replacing the AC switch by-pass capacitor, which same didn't solve the problem. I'm using the receiver only as an amplifier for a Roku SoundBridge, so the station memory isn't a problem at present. When we return to AZ, I may look at it again.
Sep 04, 2008 | Kenwood KR-A3080 Receiver
Computers & Internet Logo
176 people viewed this question
David Payne
David Payne
