SOURCE: Vinotemp VT-60 Condenser won't shut off, unit running way too cold
It might be a sensor or control board problem. Any appliance repair place should be able to help you out with this. Or you can try contacting the manufacturer directly for help or if you need to purchase replacement parts. Otherwise, my cheapest suggestion would be to hook the cooler up to a timer, so you can turn the unit on and off maybe every 20 minutes or so. That should help keep it from causing more harm and then you can monitor the temperature with a thermometer. Hope that helps!
SOURCE: This VinoTemp vt 60 just quit working. No
if the evaporator coils are warm, you have a leak and no refrigerant.
SOURCE: Vinotemp VT-16TEDS has light on but doesn't cool
You may need to change the cooling system on the unit if the unit is free of dust and still does not cool.
SOURCE: My Vinotemp VT 200 stopped
Does the internal light still come on?
If it does then the thermostat is faulty.
Fit a new thermostat
