Question about NewAir AF-330 Air Cooler Fan
Shouldn't it be cooler?
Doesn't seem to be cooling as well as I thought...have another swamp cooler that really cools. it's half full of water, ice is in..why just 'fan feel' on the blow?
  • 1 more comment
  • for_tova Jul 24, 2008
    I am having the same problem. The worst part is there is no tech support phone number in the manual, which you have to download online.
  • mglasser Jul 25, 2008
    My AF-330 arrived today. Full of water and has been running for several hours now. Still feels like a $125 fan. No cooling whatsoever in my 10x10 room. There's an icon lit up on the display panel that looks like a gear with a lightning bolt through it. No mention in the users manual. Wondering if this is some sort of indicator of a problem?
  • musikc Sep 02, 2008
    I have the AF-350 and have the same problem. We live in a dry hot area yet it doesnt seem to keep a 10x9 room any cooler, seems more like a fan. The water tank is full and I put ice in it as well.
    I've used it for about 3 weeks now and now it's started making a weird noise when on high. The noise goes away when I take out the charcoal filter but figure I shouldnt run it that way.
Just found at least one problem with mine. I pulled off the back screen and then pulled off the back cover by undoing the two screws at the top. There is a pad in there that rotates through the water reservoir. If this pad doesn't get wet, you won't get any cooling. My pad was bone dry. Turns out the wire for the motor that rotates the pad was disconnected from the front control panel. I reconnected the wire and now the pad rotates through the water reservoir. We'll see how this works.
Posted on Jul 26, 2008
  • pkangas_co Aug 04, 2011
    Does anyone know if the red lightning bolt light on the front panel means there is a problem? Doesn't mention this light in manual and it is not cooling. Will take the back panel off tonight and see if wire is off for the rotating pad.
Need parts, pump for a ED630J adobe swamp cooler in las vegas, nevada
A swamp cooler PUMP is not really model specific. They are basically small submersible pumps. Contact ANY swamp cooler dealer in LV, tell them you have a 4500 CFM unit and need a pump.
The pump part number for this size cooler is: PN 110436 (there are several alternates)
Contact these folks and tell them what you need:
National Cooler ' Swamp Cooler
3046 Vegas Dr.Suite 1
Las Vegas, NV 89106
(702) 638-8800
If they can not help you... just look under cooling and air-conditioning in the yellow pages and find a dealer near you. This pump is common to nearly every brand in LV. You can most likely buy one at the local home depot, menards, or lowes.
There is also a Little Giant CK-5 "UTILITY"pump that is used for swamp coolers.
Thanks for choosing FixYa,
Kelly
Jun 15, 2011 | AdobeAir Mobile Swamp Evaporative Air...
How do you calculate the cfm in a swamp cooler
You will need to figure the cubic feet of space you want to cool, and then divide that number by two. The quotient will give you the CFM rating for the proper-sized swamp cooler.
Jun 14, 2011 | Heating & Cooling
Just purchased a DeLonghi ev200 this afternoon, filled it up with water, switched it on and still not any cooler, if not hotter....please help, what am I doing wrong.
What yo describe sounds like a swamp cooler, which requires LOW HUMIDITY to actually work. The process of evaporation causes cooling.
If your humidity is not low enough, then you actually RAISE the humidity, and that makes your environment more uncomfortable.
The issue sounds like a physics issue and not the unit that you bought.... My thoughts is that if you live in a higher relative humidity area, units like yours should not be sold..... If you cannot actually evaporate, you will not cool.
Feb 20, 2011 | DeLonghi Heating & Cooling
Swamp cooler works i can hear the pumpon water is turned on but not getting cool air
just because the pump is on dose not mean its moving water. impellers can break and pump can get air lock
Aug 01, 2010 | Mastercool 67680 Evaporative Cooler Air...
Is there any fix for a Sunbeam Brita water filter/cooler mod. WF5900 ? Everything works except the cooling! fan runs ok. Have got it half pulled to bits...problem seems to be in the cooling motor/...
Apprently this unit is unrepairable. I rang Sunbeam and it has a two year warrenty. I suggest you give them a call too as they were very help full to me.
Nov 22, 2009 | Sunbeam Computers & Internet
No cool air fromm swamp cooler, water is on.
is the pump on? pull side panel make sure every thing is clean . Tom
Jun 30, 2009 | Heating & Cooling
Do not know how to work/maintain swamp cooler
Make sure you have water to the unit, the water pump is on and the fan is working. No water=no cooling.
Apr 21, 2009 | Mastercool 67471 Evaporative Cooler Air...
HELP l need instructions for Homebase LF320 air cooler
I have the same unit, also given to me, and there really isn't much to it. Remember, it's an 'air cooler, not an air conditioning unit. Works fine as a floor standing fan on L, M and H settings (lo, med and high) but, if you want the air to cool slightly, freeze the blue ice packs and then put them in the base of the unit and top up with cold water until the level indicator on the front says full (red ball hits red arrow, like in a kettle). Then, turn on as normal and run the 'Cool' function along with your desired fan setting (L, M or H). I tend to add a few extra ice packs. The 'Cool' setting drags a fiber membrane into the water and over the intake surface, thus cooling the air slightly. Nothing like real air con but better than nothing on a day like today. 'Swing' throws the air around a little and 'Mode' gives you bursts of air, and that's about it to be honest...
Apr 07, 2009 | House Brand Dryers
NewAir AF-330 Air Cooler Fan Logo
405 people viewed this question
Top NewAir Dryers Experts
Are you a NewAir Dryer Expert? Answer questions, earn points and help others
