My magnavox smart series keeps shutting off. - Televison & Video
  • 8,617 Answers
You will need to have the set checked by a prrofessional as its shutting down for protection due to a component that has failed allowing the voltages to flucuate there by triggering protective shutdown
Posted on May 21, 2008
Can't find install code for philips magnavox smart series plus
Universal remote codes for Philips Magnavox TV are: 0062 0204 0207 0183 0226 0288
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Sep 27, 2012 | Philips Smart Plus TP3285C 32" TV
Our Philips Magnavox Smart Series TV Shuts Off
It is possible it could be a switch but this is usually after extensive use. If it does the same with the remote control chances are it's not the switch. These sets had problems with the vertical circuit as well. I've fixed a lot of these with vertical problems. It should not run but about $80-$100 to repair if it is a vertical problem. These sets have a lot of safety cicuits as well so it could be a horizontal circuit problem as well or power supply. Kind of hard to say without a good troubleshooting. Thanks
Nov 01, 2009 | Televison & Video
No sound, no picture. tried unplugging and plugging back in...same problem. the green power light just keeps blinking 14 times over and over again. tv is around 11 yrs old...philips magnavox 32" smart...
check your h-out transistor, in high voltage area, capacitors and resistors, need reservicing and resoldering....hope you can do it, or check out with qualified tech
Oct 25, 2009 | Philips Magnavox TS3260C 32" TV
How do i get the closed caption off of my magnavox smart series tv?
There is a little button to the right of the "0" that says "CC" for closed caption. Just keep pressing it till the option "closed caption off" appears on the screen. Then, hit STATUS EXIT, and you're done.
Jul 05, 2009 | Philips Magnavox 20MS233S 20" TV
Philips magnavox smart series pr1920c601 turning off itself!
well let me ask ya something so it is coming back by its self then going back out may be solder connection okay call tv shop good luck shad
May 03, 2009 | Zenith B27A11Z 27" TV
How do I shut off the Closed Caption feature?
Bluffy you should access the menue on your remote and be able to shut it off!
Feb 16, 2009 | Philips Magnavox 27MS343S 27" TV
HOW TO REMOVE CLOSE CAPTION FROM SMART SERIES TV
on your remote go to cc push that until it sayes closed caption off not positive but pretty sure
Jan 11, 2009 | Philips Magnavox 20MS233S 20" TV
Need codes to unlock the smart block on my phillips magnavox tv
do you have a 3 digit code for RCA TV for the philips universal remote?
Dec 30, 2008 | Televison & Video
Phillips/magnavox smart series
I have a Smart Series 32" Phillips-Magnovox TV I bought april '99. Around July 4 weekend 2008 it decided it just does not want to come on any more! Was working just fine before that...I can not find my manual. Any suggestions?
Thanks,
cely
ceorunner@aol.com
Mar 04, 2008 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
