Question about Panasonic Microwave Ovens
I have purchased a microwave oven--Model # NN-T664SF. I need to look at the window display at eye level in order to see the time AM/PM and the remaning time for cooking. Cannot see from an angle as other appliances. Am I able to darken the background in order to read the settings other than at eve level ? pls advise/ Thank you gene wuestenfeld
    Genius:
  • Panasonic Master
  • 1,689 Answers
This is the polarization effect from the design of their LCD display for the panel. There is nothing that I know of that can be done for this.
I myself have a microwave oven, and it looks the same as you are describing.
You can try to call Panasonic tech support to see if they will help you with this.
Jerry G.
Posted on May 21, 2008
It just beeps when plugged in cannot press anything to start it timer menu does light up model # nn-sn960s panoasonic micro wave
Panasonic Microwave - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Microwaves
Rating: 2.6 - ‎53 votes
After looking, door was starting to arc and burn around the edges in three places, ...You can't leave this oven unattended for a minute or you could be calling 911! ... In October 2014 I purchased a Panasonic microwave model NN-SA661S. ... The timeremits "4 beeps" when the time is up; other microwaves, continue to beep ...
[PDF]operating instructions - FTP Directory Listing - Panasonic
ftp://ftp.panasonic.com/microwaveoven/.../nn-sn651_nn-sn661...
PanasonicModels no. nn-sn651b ... nn-sn661s .... Use this appliance only for its intended use as described in this manual. do ... Thank you for purchasing a Panasonic MicrowaveOven. ... you press Start. note: The Glass Tray can turn in either direction. ..... If a pad is pressed and no beep is heard, the unit did not or cannot accept the
Jan 19, 2016 | In Microwave Ovens
Need user manual for National model no: NN-8655 Microwave oven user manual...
I would suggest that contact the dealer from whom you purchased the oven or call any number listed on the model tag of the oven.
Jan 06, 2014 | Panasonic Microwave Ovens
Microwave stops mid cycle
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Dec 27, 2012 | Panasonic NN-T664SF Microwave Oven
How can use USA microwvave in UK WITH 240VOLT TO 120VOLT 1400WATT
Unless the microwave oven is equipped with either an auto-transformer (which automatically compensates for the input voltage), or has a switch that you can change the voltage from 120VAC to 240VAC, you will need to buy a small step down transformer that plugs into the wall, and then you plug the microwave oven into. Keep in mind, however, that the frequency of the A/C voltage in the U.S. is 60hz. In Europe its usually 50hz. What this means is even if you are able to step down the voltage to use the appliance, the time will not be accurate. You will lose about 10 seconds per minute. Or, 10 minutes per hour. Something you may want to consider.
May 31, 2011 | Panasonic NN-T664SF Microwave Oven
How much does a magnatron cost?
The same as a new microwave does. $154.99
Dec 19, 2009 | Panasonic NN-T664SF Microwave Oven
I need a glass tray for my NN-T664SFX
go to this website
http://www.pstc.panasonic.com/Epartr/PartsListChoice.asp
you can either search by model: enter NN-T664SF and click the part number box, then find the tray listed under accessories. OR
you can search by part number from that same link. Enter F06014T01AP and click retrieve part info. Once you add this to your shopping basket you will see two items listed, as the original model has been replaced by another model. Click verify availability... and the shopping basket will adjust and only show one item in the cart, which will reflect the replacement model item. Finalize your purchase from there by entering your personal info. Good luck!
Oct 06, 2009 | Panasonic Microwave Ovens
Child sign in window of microwave ,cant start it panasonic
On my NN-L738BA there is a Child Lock feature.
You set the child lock by pressing the Start button 3 times.
If the Child Lock is enabled it displays the word :CHILD".
To disable this feature on my microwave the manual says to
press the Stop/Reset 3 times.
Check your manual for the Child Lock.
Mar 06, 2009 | Panasonic NN-S541 Microwave Oven
My microwave says "child" and won't play anymore
Not sure of the TT series models but for the NN series models the procedure is as follows:-
If "Child" is displayed in the display window, then the child safety lock is on.
To remove the child safey lock, press the "Stop/Reset" button 3 times in fairly short succession (less than 3 seconds). The time of day or just the Colon sign (:) is then displayed
If you later want to apply the Child safety lock, then, when the time of day (or colon sign) is displayed, press "Start" 3 times (again in short succession).
Hope this helps
Doug
Nov 08, 2008 | Panasonic NN-T990SA Microwave Oven
Microwave Ovens Logo
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
