Question about JVC AV-48WP30 48" Rear Projection Television
JVC 48WP30 Rear Projection
I turn on the tv and after about 10minutes it flickers red and sometimes green over the image your watching then goes away and keeps coming back it's perfectly clear but the lines are annoying when they come on and off. Please help? I don't know where to start?
  • JVC Master
  • 8,617 Answers
Are the lines real thin on a slight curved angle when they appear? If so it is probably related to the either the CRT PC boards or the Circuits for the convergence yokes attached to the neck of the tubes as they are all connected in series to each other. let me know if you need further assistance and or parts.
Posted on May 21, 2008
Horizontal lines flicker on jvc av-48wp30
Next time you see it select convergence in the menu, there is a way to adjust or at least see if it is out.
This is actually not a real hard set for this repair IF it is your problem.
The board that needs to be removed to get at the parts is not large and does not require a lot of time to get out.
The set uses two of the STK-392-110 chips for this---at for example Suburban Electronics you can get a pair with shipping for under 20 dollars.
In the customer convergence mode what you are looking for is red lines where they do not belong and if red looking to see red will move left/right and up down in a area that looks off.
If the red for example will not move in some direction change both chips.
If you want help I will attach some photos here of exactly what the board in this model looks like and the chips are easy to see.
Confirm first this is your problem.
I can tell you exactly how to get the board out and what you will need for the repair.
There are "kits" for this but they run over 80 dollars and have a number of parts you will never need or use.
If you have a soldering iron and know how to solder the repair should cost you in parts etc under 30 dollars.
Take it from me, I have done a few hundred of this model for this problem. Pretty good investment for a set with few other problems, life on the replacement parts is 5-7 years.
Let me know if want more information or help.
SD TECH
Dec 13, 2012 | JVC AV-48WP30 48" Rear Projection...
JVC AV48WP30 Projection TV..Half picture distorted and flickering
Ur convergence is dead.Must replaced the 2 convergence ICS and all it resistors.The shop will cost U $300 for parts and parts.
Feb 10, 2010 | JVC AV-48WP30 48" Rear Projection...
Have a JVC AV-48WP30 rear projection tv set and the green seems to be out of place. the green image is lower than the others and is in a wave shape on top of screen and bottom.When I adjust the convergence...
Your convergence IC's are bad. If your not doing the work it will probably cost in the neighbor hood of $250.00 for a service company to do. Not a major repair.
Nov 03, 2009 | JVC AV-48WP30 48" Rear Projection...
My tv jumps with red lines while watching. JVC
It sounds like the begining of as convergence problem or cold solder on convergence board - have a tech have alook
Sep 14, 2009 | JVC AV-48WP30 48" Rear Projection...
JVC NV-50D500 Flickering
convergence board problems u will nedd replacment soon
plz do rate this post
Nov 30, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV 48WP30 projection tv bleeding problem
You need two STK392-110 Convergence ICs. You can get repalcements at the following link, and they will provide free instalation instructions with picture so you can do the job yourself. Heres the link.
http://servicemanuals.vstore.ca/
May 24, 2008 | JVC AV-48WP30 48" Rear Projection...
Jvc tv on button flashing on av 48wp34
Use remote, sounds like Tv is in child lock
Dec 21, 2007 | JVC AV-48WP30 48" Rear Projection...
AV 50D501 JVC projection T.V.
sounds like a bad connection in the deflection circuit. you need a repair tech
Dec 16, 2007 | JVC AV-56WP30 56" Rear Projection...
JVC 48WP74 HDTC rear projection
While it is true JVC tubes rarely fail, they can give trouble.
Another possible solution is bad screen / focus block......
Remove lower front grill panel and access board...Check for
smooth adjustment of RGB screen and focus.....let me know....T..
Sep 28, 2007 | JVC AV-48WP74 48" Rear Projection...
Jvc tv picture quality
sounds like your crt tubes...meaning Red, Green and Blue are out of alignment...or possibly 1 of the crt's is burned out.
Jan 29, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
74 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
