Question about Whirlpool GHW9300 Duet Washer
Sometimes leaks from the bottom
Full model: GHW9300PW4
Every few loads the unit will essentially flood the room. Sometimes we find a sock has slipped inside of the rubber seal - can that be causing such a flood? It appears to come from the bottom front of the unit and does not happen every load.
    Genius:
  • 1,028 Answers
Ckd door seal closley for tears or distortion..try removing bottom panel for a few loads this may help in locating source
Posted on May 21, 2008
I have a Whirpool Duet HT and the bottom of the machine SOMETIMES leaks water from the bottom corner(same corner where the detergent is put in). Sometimes it leaks a small amount if water but sometimes it...
Common parts that leak on a front load washer:
Door boot (also know as gasket or bellow), drain pump, intake system (which is either intake valves or soap dispenser). From my experience in that order.
The door boot can be inspected from the inside although if you didn't find any holes could still be it. (so if you find a whole than it most likely it, but if you didn't find holes it does NOT rule it out since it has to be inspected properly from the inside.
Aug 21, 2014 | Whirlpool duet Washing Machines
Draining from bottom of washer flooding floor
need to check the hose from the pump also pump could be cracked causing leak
Apr 07, 2014 | GE WSXH208A Front Load Washer
Washer draining on to floor
take bottom cover off and check to see if the drain hose running from the pump is leaking also check the pump sometimes they crack causing a leak
My brush stop working
Barring any electrical failure or loose plug the most common cause for the vacuum brush to stop turning is belt clogged with debris or string.
Unplug the unit and check the brush for string or debris (Hair) wrapped around the pully on either end. Clear this and check the belt to make sure it has not broken, stripped or simply slipped off. Usually the bottom plate is held on with just a few screws. Easy to remove and check Belt slipped off or stripped replace. Belt slipped off you can sometimes put back on and be vacuuming in no time.
Anything wrapped around the spindle a pair of needle nose pliers comes in real handy here. If you have snagged a rug, sheet or sock etc.. check the manual for a reset button. Some vacuums have this and all it takes is clearing the chute then resetting the switch. Good luck hope this helps!
Apr 03, 2014 | Vacuums
My maytag epic z is leaking from underneath
Remove the front bottom panel. Should be three 1/4" screws on bottom lip of panel. See if you can tell where leak originated. Chances are good you just need to pop the cap off the drain pump and clean it out. Here is a vid that explains the procedure.
http://www.youtube.com/watch?v=iLftnaruKp8
Jan 21, 2013 | Maytag EPIC MFW9700S Front Load Washer
How do you stop the cycle immediately after starting (found a sock that needs to be added in the washer) and then re-start wash cycle
You can only add items to the wash for a few minutes after that washer starts. If you found something you want to add you have to restart the cycle. This is a safety feature added to the front load. After the washer is full of water it doesnt allow the door to open so the water in the machine doesnt flood you laundry room.
Jul 15, 2011 | Asko W6021 Front Load Washer
Won't shut off machine turns off after a few seconds
You may have a burnt motor. This is usually caused by a clog in the pump. Sometimes small items such as socks find its way to the pump. It could also be the timer itself. If there is a burning smell when that happend it is probably the motor.
Jun 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
Leak
Ok Let us look at everything that can leak on the machine, get a good light and check the following.
Hoses on the back of the pump
The bellows, grey seal at door
The boot were it attachs to the tub
Look at the tub for water dripping off of center where the seam is
Aug 05, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washing Machines Logo
144 people viewed this question
Dan Webster
Dan Webster
Sal De
