Question about RCA P52926 52" Rear Projection Television
Fl231 I could not find the fl231 by the flyback. What does it look lide?
  • RCA Master
  • 8,617 Answers
Its just a regular fuse some models have F231 instead of FL231 it should be just to the upper right side of the flyback.
Posted on May 21, 2008
So what's a flyback or convergence option ??. Heck, even a stick-figure Diagram might do the trick. It's nice 2 have folks like ya'll sittin' 'round helpin' each-other out
The flyback is the large transformer that has the thick red wire coming out of it. The solder has a tendency to crack slightly which causes the FL231 Fuse to blow ( just to the right of the flyback) When the FL231 fuse blows the convergence option will disappear from the setup menu and the set will appear 3d with an arced picture. I am attaching a pic that shows the Flyback with a white circle, The FL231 is the yellow circled item next to the flyback11_1_2012_11_47_00_pm.jpg
Nov 01, 2012 | RCA Televison & Video
My mom has a RCA HD61W66 and the picture was showing red, blue and green "lines and shadows" as if the picture was warped. It has now stopped showing a picture at all but the power is working....
The flyback transformer has solder cracks around the pins and most likely blown the FL231 Micro fuse to the right of the flyback.I would inspect the flybacks solder. The FL231 and the CL230 and DL231 should also be replaced ( near the flyback) You can get the ITC222 Convergence option missing repair kit from under the RCA repair kits. The kit contains the parts and the CD with repair instructions
Sep 15, 2011 | RCA HD61W66 61" Projection HDTV
Convergency has gone out of sync, went to try to realign but the convergeny setting was not listed in the tools menu.
Thats usually caused by a blown FL231 Fuse and a blown DL231 diode that blow when the flyback transformer develops solder cracks around the pins. The repair is to first resolder the flyback then replace the FL231 fuse and DL231 diode. You can get the RCA / GE convergence option missing repair kit which has the parts and repair instructions from
Jul 09, 2011 | RCA HD61W66 61" Projection HDTV
Replaced the fl231 fuse tv worked for day now blown again and tv keeps shutting off what do i check now
Resolder the flyback pins as thats what causes the FL231 fuse to blow. Soldering the flyback should solve the issue you may need to replace the fl231 again
Apr 28, 2011 | RCA R52WM24 52" HDTV Projection Television
My convergence keep going out, I replaced the convergence twice. I have a rca hd52w59 modle
When you say replaced the convergence twice, are you refering to the convergence boards or the FL231 fuse? If its the FL231 fuse unless you replaced the DL231 and CL230 plus reflowed the solder on the flyback it will continue to keep blowing untill the 3 parts are replaced together and the flyback gets resoldered. If you replaced the convergence boards then try resoldering the flyback.
Nov 27, 2009 | RCA HD52W59 HDTV Projection Television
I replaced the fl231 fuse in my rca HD52W58 and it went back out
Had the same problem , you have to resolder the flyback before replacing the fuse.
Jun 25, 2009 | RCA HD52W58 52" TV
heres where they are located but you have to resolder the flyback and vertical IC also.
Look at the flyback ( with the Large red wire) Just to the right of the flyback you will see three small brown Fuses the cehter one is FL231 DL231 is just to the right of FL231 and Cl230 is just below and alittle to the right of DL231
Jun 14, 2009 | RCA HD52W59 HDTV Projection Television
R52wh74 already changed 231 fuse still not converging
Did you change DL231 and CL230 with the fl231? Also did you reflow the solder on the flyback and vertical IC? Bad solder is what blows the FL231, but without changin DL231 and CL230 and resoldering the flyback and vertical the fix wont be fully effective.
Jun 12, 2009 | RCA R52WH73 Projection Television
Go into menu look on setup see if convergence comes up then do auto converg. if you do not see convergence on menu then you have an open fuse FL231 square brown cap next to flyback.
Jul 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52w59 projection fuse fl231
Instead of taking the board out, I just soldered two wires to the old fl231 fuse on the underside. Installed a fuse holder with a half amp fuse. And I re-soldered all of the flyback points. My tv is working like new. thanks for everyone's help.
Dec 28, 2007 | RCA HD52W59 HDTV Projection Television
RCA P52926 52" Rear Projection Television Logo
54 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
