Question about Biostar P4M80-M4 Motherboard
Will not POST with 2g of kingston hyperX ram inside
Im trying to upgrade my pc from 1gigs of kingston ram to 2gigs. i bought two sticks of the kingston hyperX ram 1gig each. the model number is KHX3200AK2/2G. the frequency is 400MHz (PC3200) and the latency times are 2-3-2-6 at 2.65V and it can run at 2-3-3-8 at 2.6V. ive updated my bios to the latest version ive tried running it with one stick at a time for both of them in both slots. i understand this is ram made for overclocking and is not exactly recommended that it be used on this mobo but as far as ive checked no one else has had problems with this. i have even called kingston and talked with them about it and they have no records of it being a problem on this mobo ever before. so im absolutely stumped as to what to do next. im going to give biostar a call and see what they have to say but some added help to solve this would be nice.
    President:
  • 2,351 Answers
If you are going to call. The question I would ask (Very important), will the board run with CL2 = 2.5v & or CL3 = 2.6 to 2.65volt memory.
This site is Kingston memory setter. Type in the board & it show's the type of memory the board can use. (Click on this link). As you look at the link this is for you're P4M80-M4 board.
http://www.ec.kingston.com/ecom/configurator_new/modelsinfo.asp?SysID=33018&mfr=Biostar&model=P4M80&root=&LinkBack=&Sys=33018-Biostar-P4M80-M4+Motherboard&distributor=0&submit1=Search
This should help. I did not see a bios upgrade for this board that had anything to do with memory. The USA Biostar link is lacking opposed to the global link. The global manual give far more information (In depth), for bios instructions.
Global link: http://www.biostar.com.tw/app/en-us/mb/driver.php?S_ID=246
I'm sure the Kingston link will more than help you the_OCer.
Mike
Posted on May 21, 2008
Can't install kvr800d2n6/2g x 4 on aw9d max
What you have purchased is Kingston VALUE RAM. It is budget-priced RAM for generic use. It works well in most cases. I was unable to find an actual 4x3 GB "Kit" on the Kingston site, although I found 2x2 Kits. The problem here may be in matching. The specs for RAM are fairly stringent, but they have variances, and the cheaper RAM is more likely to have such variances. I would try first installing each stick separately in the primary slot and confirming that each is detected. Next place one stick in DIMM 1 and one DIMM 3 slots. This puts one stick in each channel. Each channel operates independently so matching is not an issue. If that works, try adding one stick to one channel or the other. If it fails, swap it to the other channel. The idea is to try to get the sticks matched up as best as possible. Hopefully you will find a happy match-up. Also, check the memory voltage. These sticks operate at a standard 1.8V, but having four installed could be loading down the power supply some and you may need to manually bump the voltage up a tenth or two. Don't go over 2.0V though.
Jan 29, 2012 | Abit AW9D-MAX Motherboard
Trying to upgrade memory in a toshiba satellite a105 s1013
Pls Check this link, in reference to your memory upgrade...it seems that your laptop could only accomodate max 1Gb of RAM
http://support.gateway.com/s/Mobile/Q106/Magic/5948sp2.shtml
Feb 14, 2010 | Gateway MX3215 Notebook
Ram upgrade problems
looks like you have the wrong ram for your system Kingston is showing this for your system KVR667D2S5/2G
but try refreshing your bios i doubt it will work but give it a shot with your ram installed just hit F2 to get into bios when starting your computer save and exit that should refresh it
Nov 03, 2009 | ASUS Eee PC 900HD Netbook
Upgrade to 2g memory
If its a desktop it should be fine with two 1 gb sticks. Check to see how much ram is being shared for video. You can see that in the bios setting. Not sure how much can be shared but it may read differently depending how much system ram is being shared for onboard memory.
Sep 03, 2009 | Compaq tc4200 Tablet PC
Problematic recognition of memory
You may try another OS if you think, this is a software problem. please let me know the update with another os like xp ?
May 24, 2009 | Computers & Internet
2G Memory Upgrade
I had similar problem with CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
If this is your RAM:
Corsair 1024MB Value Select PC2-4200 (533MHz) DDR2 RAM, 128Mx64non-ECC, 240-pin DIMM, Unbuffered, CL4, Lifetime warranty (VS1GB533D2) Then it is high density. You need low density to work, look for one ending with an 8, not 64.
Feb 26, 2009 | PC Chips P23G Motherboard
Upgrade problems
Your system comes stock with one stick of DDR2 (512 MB), which means that it is _ not_ dual channel DDR2 memory as dual channel DDR2 must be installed in matched pairs. Try to exchange the new memory for 2G of some single channel DDR2.
Jan 28, 2009 | eMachines W3507 PC Desktop
Troubleshoot about RAM speed
no pins will not fit in the system , because ur mother board of sysytem will not support it
Oct 26, 2008 | Computers & Internet
Suitable dual-channel memory module for ASUS P5N-D
Hi hellinme, since you want to go with Kingston, can I suggest this link. http://www.ec.kingston.com/ecom/hyperx/modelsinfo.asp?root=
I picked the memory you wanted. DDR2 800MHz. Than picked, Asus for the board & scrolled down through motherboards till I came to the P5N-D board. Listed there will be kingston hyperX memory suggested to work the best for the motherboard.
The memory, KHX6400 D2ULK2 2G(2x1gb), is not listed.
Enjoy!
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 27, 2008 | ASUS Computers & Internet
Biostar P4M80-M4 Motherboard Logo
121 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
