Restore point Went to do a restore point on windows media ,and the operating system is corrupt now.Missing files and can not do a system restore now.
  • teddybear860 May 21, 2008
    Can someone PLEASE help me.
  • 859 Answers
Did you want to revert to a previous Restore Point or create a new one?
Comment back rather than create a new post please.
Posted on May 21, 2008
File is missing
The Error Code 0Xc004e003 error may be caused by windows system files damage. The corrupted system files entries can be a real threat to the well being of your computer.
To fix Error Code 0Xc004e003 Windows 7 Error:
Advanced Computer User Solution:
1) Start your computer and log on as an administrator.
2) Click the Start button then select All Programs, Accessories, System Tools, and then click System Restore.
3) In the new window, select "Restore my computer to an earlier time" option and then click Next.
4) Select the most recent system restore point from the "On this list, click a restore point" list, and then click Next.
5) Click Next on the confirmation window.
6) Restarts the computer when the restoration is finished.
Jan 25, 2014 | Microsoft Windows 7 Ultimate, Full Version...
Boot problems and their possible causes & resolutions
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Corrupt Master Boot Record (MBR)
Boot into Recovery Console and run "fixmbr" to repair the MBR
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Corrupt boot sector
Boot into Recovery Console and run "fixboot" to repair the boot sector
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
"Windows could not start not start because the following file is missing or corrupt:
Corrupt/missing system hive
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Check the boot volume is accessible
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
Missing plug-inn?i want to restore
Title:missing plug-inn?i want to restore
If you set a restore point then do as --
To set a System Restore Point...
  • Open the Start menu
  • Open the Programs menu
  • Open the Accessories menu
  • Open the System Tools menu
  • Finally, start System Restore
  • Pick the option for setting a System Restore Point and click on the Next button
  • Fill in a name for the restore point so you can find it and click on the Create button
  • Click on the Close button when done
In Windows XP, Windows Vista and Windows 7, if booting all the way into normal mode causes problems, such as features that don't work, freezes, etc., it is possible to backdate Windows itself to an earlier state when it was working properly by restoring a restore point created automatically or manually by or in System Restore.
You should know that System Restore does not back up and restore non-system files or third-party software or any changes made by such software. It also does not involve restoring the data files on the computer. Only the essential files required to get Windows running are involved in the creation of its dated restore points that take the system files back to the date on which a particular restore point was created. Nor does System Restore clean up files left over by a botched software installation, which is a common cause of corrupted system files, and it can't be used to restore selectively files that have been accidentally erased. In other words, System Restore is a very handy tool that has saved my PCs on numerous occasions, but it is not a substitute for a full system backup, such as the creation of a disk image of the system, and should never be relied upon as such.
May 07, 2011 | Microsoft Windows XP Professional
Will noy boot up
some of your operating system files is missing/corrupt, that's why the main windows cannot open/load.
You will need to repair your windows operating system (win xp/vista), in other to solve this problem.
To repair your windows, you will be needing a windows operating system CD, insert it into your player and run setup. While you are installing, it will get to a stage where the system will ask you if you want to restore, click restore and the missing/corrupt files will be reinstalled.
Good luck.
Jun 13, 2010 | Toshiba Satellite A135-S4527 Notebook
Windows 32 is corrupt
Try to start on SAFE mode. If you can do that, then try to backstep with the restore function found in accesories, system tools, restore. Use a restore point that is back a month or so.
Jun 06, 2010 | Microsoft Windows XP Professional SP2
Dell inspiron 910 operating system not found
Windows seems to be corrupt - vital windows files missing. Load the Operating System CD and see if u can run the system file checker to replace files that are missing.... OR, save data externally and restore the system.
Mar 13, 2010 | Microsoft Windows XP Home Edition
Ntoskrnl.exe is missing or corrupt solution
Issue:NTOSKRNL.EXE is missing or corrupt.
Related errors:
Below is a listing of the full error message that may be related to this error.
Windows NT could not start because the below file is missing or corrupt:
  1. Keyboard issue
  2. Miscellaneous corruption
  3. Corrupt boot.ini file.
  4. Missing boot.ini file.
  5. Missing or corrupt ntoskrnl.exe file.
  6. Windows NT installed on a partition bigger then 7.8GB
  7. Corrupted hard disk drive or severely corrupted Windows.
Solution:Keyboard issue
This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer.
Make sure the line pointing to the operating system and its drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Microsoft Windows XP users:
If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648.
Microsoft Windows NT and Windows 2000 users:
To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
  1. Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
  2. In the setup menu, type R to start the repair.
  3. When prompted for the ERD diskette insert the diskette and inspect the startup environment.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
  1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
  2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
  3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
  4. Select the operating system you wish to fix, and then enter the administrator password.
  5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
  6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
  7. Type exit to reboot the computer.
If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below.
OS Loader v4.01
Disk I/O error status=00000001
Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
Please reinstall a copy of the above file.
If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Attempt to check the hard disk drive for any errors by running the chkdsk program. To do this follow the below steps.
  5. Once at the recovery console type chkdsk /r
  6. Once completed type exit and see if issue is resolved.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186.
Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
Oct 01, 2009 | Microsoft Windows XP Professional
"<Winnt_root>\System32\Hal.dll missing or corrupt:
  1. Verify the boot.ini file is found on the computer by using a boot diskette or use your Windows CD to get to the MS-DOS "C:\>" prompt.
  2. From this prompt edit the boot.ini, verify that it is pointing to the correct operating system, and that no anomalies are found within the file. Below is a listing of what to verify
  • If only one operating system is on the computer verify that the boot.ini only has one operating system listed. In some situations an alternate configuration line may be added for the same operating system, leaving the improper line.
  • Verify that the "default=" line as well as the operating system line are the same and that they are pointing to the correct operating system.
Verify that the computer has the hal.dll file
From the MS-DOS "C:\>" prompt quickly determine if your computer has the "hal.dll" file by typing "dir hal.dll /s" at the prompt. If the computer returns a "File not found" message, the hal.dll has been deleted.
To recover this file boot the Windows operating system CD and choose the option to "Restore", "Repair", or "Recover." This option will prompt you for the Windows installation to use, the administrators password and will allow you to restore the proper file. At the MS-DOS prompt type the below command.
expand C:\i386\hal.dl_ D:\windows\system32\
In the above example "D" would be the letter of your CD-ROM drive and "C" the letter of the drive your operating system is installed on. For example, your disc drive may be D: and your hard drive is likely C:.
Jun 04, 2009 | Compaq Presario 5000 PC Desktop
Some of the files needed to play video are missing or corrupt
When that happens you usually need to backup your data, and reinstall the system to fix Windows corrupted files.
Try first doing a system restore to the most recent date before you started having the problem. If system files are damaged this will not help.
May 16, 2009 | Microsoft Windows XP Media Center Edition...
How to get more restore point fron corrupted windows 98 registry. my friends move all directory to d: drive. how to bring back to C :
Hey there
The first thing that you should aware of is you cannot move the system file that are currently being used by another program to any of the directory. If it is so then you wont be able to log on to ur computer. because it will give you a lot error of missing system files.
For restoring your system do the following:
1. Go to Start -> All Programs -> Accessories ->System Tools
and select System Restore
2. Go to next window, Choose the restore point that is available remembering ur system was exactly what you wanted for.
3. Select that restore point by reading the description.
4. Click next to restore.
Note: Your system will restart after choosing the restore point and clicking next. It takes some time to restore.
for creating the restore point, follow the same step specified above except the second one. you need to select create new restore point insted of choosing restore point to restore.
Type a restore name and click next to create.
Gimme ur acknowledge by rating me
Jul 05, 2008 | Microsoft Windows 98 for PC
Computers & Internet Logo
David Payne
David Payne
