Question about Gateway M675 Laptop
Gateway 450ROG Heating Up, Fan Constantly On, Screen Distortions
My Gateway 450ROG is 4yrs old now. Extended 4-yr warranty just expired on 9/30/06. From nearly the beginning, this laptop would get warm, really warm. Had to replace those cushiony feet on the bottom of it several times.
Now the thing gets warm, as warm as it used to, and the sreen starts to do the shimmy, gets distorted, shaking, then freezes up. I have to use a paperclip to turn it off on the bottom. I let it totally cool, then it starts normally. Soon after, it starts the shimmy again.
I brought it to the Geek Squad at Best Buy, paid $60 to have them check the hardware (only hard drive & memory--I didn't know memory was hardware) and they said it was ok. Concluded it must be a software problem, virus, etc. Funny the fan was listed on their form under hardware check, but it was not checked off at all.
Can you please help me? I can't afford to buy another laptop, & I really need this one. Realized my Gateway was running all the time (fan) and pretty load... My son told me to try to clean out the dust to see if it gets better. Oddly I can use it sitting over the A/C vent on our floor and the fan NEVER comes on and it is faster changing programs and all. Definitely a heat issue. I will try cleaning it with air and then if it is still too hot I will check into the cooling of the processor.
  • acatnap Jan 26, 2009
    My problem isn't quite that bad. I have a cooling pad with 3 fans.
    The fans on the Gateway M675 are constantly coming on and noisy!
    Getting on my last nerve, especially when I'm trying to be quiet on a conference call. It sounds like a vacuum cleaner going off!
    I've looked at replacing the fans, but wouldn't that be throwing money away by putting the replacement part number fan just as noisy and the one I replaced???!
  • phplady Feb 20, 2009
    I have the same problems noisey noisey noisey fans that run all the time.
    Scholar:
  • 143 Answers
Your son may have solved your problem. You will be amazed at how much dust can accumulate inside a laptop. I clean mine out at least once a week. The drop in temp is suprising! Please report back if that solved it.
Posted on May 21, 2008
Why does my led screen have a white spot
may be the panel, in which case it should be under warranty. This unit has a 1 yr mfr warranty , if less than 1 yr old it would be covered. contact servicer for service immediately before warranty expires
Sep 09, 2014 | TCL 48FS4610 48 LED HDTV 1080p 120Hz Slim
I have a gateway nv44 and it will on power on if the screen is in the right position. I have to hold down the power button and move the screen up and down until it come on. Then it works fine.
It sounds like you have worn, loose or cut wires at or near your laptops hinges. You need to contact gateway if it is under warranty or the purchase place if you have an extended warranty through them. If it's out of warranty you will have to find a technician that repairs gateway laptops or pay for gateway to fix it.
Oct 04, 2013 | Gateway NV44 fan - NV44 laptop cpu cooling...
Hi, I have a 1.5 yr old gateway NV52 laptop that has stayed in sleep mode for two days...I've tried turning it off and cutting back on but it is still in sleep mode...please help
Hi aiomason.
Remove the AC cord and the battery from the notebook. Re-attach battery and AC cord and power up the notebook. This will clear the Ram memory and force the operating system to "Cold Boot", in other words start the operating system loading up from the beginning instead of resuming from Ram the last time it was active. This proceedure should restore your Gateway Notebook to normal operation. Post back your results and good luck.
Jan 24, 2011 | Gateway 450ROG Notebook
Gateway 450rog computer constantly restarts
remove all other devices hooked to your pc except for the basics, mouse and keyboard. then try the last known good configuration. press F8 before it boots to windows then choose known good configuration.
Mar 31, 2010 | Gateway 450ROG Notebook
Got a gateway loose complitely the light of screen,but it starts you can hear it, the window but no light
check ribon cable by taking laptop apart and makign sure its conected to board correctly, but more than likely new bulb or replacement screen , search ebay they have a tone of secound hand screens for decent prices, search gateway 450rog lcd displays, hope this helps in some way
Dec 04, 2009 | Gateway 450ROG Notebook
How to replace fan on Gateway 450ROG
The service manual is on the website at http://www.mpcdrivers.com
Nov 10, 2009 | Gateway 450ROG Notebook
Laptop Shuts down to black screen without warning.
it may be over heating !!
turn it on and run it till you hear the fan turn on, then check if there is much air coming out of it.
if not use a vacuum to **** air throw it as you blow hard into the slot that the air should come out of
Jun 17, 2009 | Gateway 450ROG Notebook
Gateway 450ROG notebook repair
I would personally say that it was the motherboard, but it would be impossible to guareente that unless an inspection was carried out.
The support I could offer if you wanted me to take a look would be for you to send the laptop and power cables to us, we would take a look. If we cant fix it we will return it to you with no charges. If it can be fixed you would be informed of the cost before we go ahead and do it.
Please note that you will have to pay for the delivery to us in any case.
Regards
Simon
Rytech UK
Jun 23, 2008 | Gateway 450ROG Notebook
Ursula56,
If you paid them to fix it and they didn't, complain to the manager. Bring the fan to his attention. Software wont cause that kind if problem, unless its the video driver, which in your case it doesnt mess up when you first start it up, so thats not it. You will at least get your money back. You are right about the heat it will cause a lot of problems, because its size.
Please let me know how you make out. I hate seeing people get screwed.
Jan 18, 2008 | Gateway 450ROG Notebook
Gateway M675 Laptop Logo
443 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
