Question about Asko 24 in. 1895 Built-in Dishwasher
Asko 1895 New out of the box been in storage while the basement was finished. flashes door interlock error 4 lights left and the 4 lights right. book says close door. it is closed any idea what the problem is.
  • wsizone May 21, 2008
    I removed the door cover and the door switch housing is broken I will replace that and see if it fixes the problem
  • 868 Answers
First make sure your door switch is making proper contact.If not replace it. If it checks out ok than your main control board is bad.
Posted on May 21, 2008
Dishwasher asko 1895 the pump the working the lights are flashing but the machine is not working
The lights flashing is telling that there is a fault in the dishwasher.
I am assuming you have emptied the dishwasher after the drain cycle failed to work due to the pipe block.
You will have to make a fresh start. Empty the dishwasher, turn the power mains switch off and on to reset the dishwasher.
Start a new cycle and see if flashing lights stop flashing. If still same problem you will have to note which light(s) are flashing and send a post on this page. There is a chance the impeller in the drain pump may have sufferred some damage due to drain block depending on how long the motor operated before you found the problem with the drain.
Jan 04, 2013 | Asko 24 in. 1895 Built-in Dishwasher
Unit has been flashing F1 and now doesn't seem to complete the cycle. Just keeps running.
The F1 error codes is a water heat fault,the control has determined that within 60 minutes that the correct water temp.has not been reached
The possible causes of that are
A burnt out heat element
A burnt out thermostat
Gene
Aug 22, 2011 | Asko 24 in. 1895 Built-in Dishwasher
It has been flashing an F2 error code and the timer starts at 65 then switches to "1" which stays on during the cycle. Now it will run for about a minute then stops completely. Can you suggest any parts...
Welcome to FixYa.
The "F2" for Asko dishwashers indicates either the unit is overfilling, or the valve itself has failed.
The problem is likely the fill valve, based on your description... "It has been flashing an F2 error code and the timer starts at 65 then switches to "1" which stays on during the cycle. Now it will run for about a minute then stops completely".
Depending on the series of dishwasher you have, determined by serial number ( I don`t mean the model... I got it is a 1895 ) because those Asko machines had a revision to their valves moving from a dual solenoid to a single, the single substituting all dual coil valve units.
i.e.
The original Asko number would be # 8057508 and available at most brick & mortar parts vendors or on- line places such as "repairclinic.com".
** turn off the breaker at the service panel before servicing the unit...safety first**
To check the valve will require the removal of the lower panel/kick plate or also referred to as a toe panel, and with the aid of an ohm meter and at least one wire removed from each/the coil, measure the ohm value of the coil.
The valve will be on your right...
i.e.
It should not read infinite, but rather 0 to 93Kohms.
That should move you forward and hopefully solve the problem. Let me know if anything is not clear or if you require further assistance.
Thank you for choosing FixYa and good luck.
** If you have any reservation or are not completely confident servicing this unit please call in an authorized Asko technician **
These can be very difficult to service for one inexperienced, I see so-called pros mess them up all too often.
Regards,
Macmarkus :)
Oct 07, 2010 | Asko 24 in. 1895 Built-in Dishwasher
E40 error door light flashing and clicking noise
E40: Door open, Interlock, wiring or main PCB most likley going to be faulty door interlock.
Turn the power off, unplug the machine and take the top off your machine and on the front right of the machine there is a plastic case with lots of wires.
Put the wires out one block at a time, keep putting them in and out, this will help the connection to seat.
Try the machine again and the problem should be solved.
If not you may need a new board.
Mar 10, 2010 | Zanussi IZ161S Front Load Washer
WD My Book 1TB - can't recognize usb drive
1 go to the start menu
2 Right click computer
3 Click manage
4 Go to the storage tab and open it (its in the box on the left side of the screen)
5 Click disk management
6 look for your unusable drive.
7 If the bar is black and it does not say online then you are going to right click the small box on the left side that says "disk X"
8 Pick the 1st option
9 after hitting next a time or two you will have 2 choices to pic from one says something like mass boot or something along them lines do not select that one pick the 2nd option.
10 Hit next till the window closes
11 If the bar is still black right click the black bar
12 Select 1st option
13 Hit next till you see a box that says something like quick format and check that box.
14 Again hit next till its finishes
15 after you finish that the window should show the box with that black bar turn blue and the box on the left will say online.
Sorry i dont have all the terms but i just got help myself and trying to help you all out as well.
Mar 12, 2009 | Western Digital My Book Essential 1TB...
Asko 1895
the most important thing is to screw it to the bench,there are four screw points two at the top and two on the side near the top if you look you will see the tags where they go.as far as the hoses go just make sure the drain hose is up high and not laying on the floor.hope this helps.if connecting to hot water it must be below 60 degrees.and you probably wont need a pressure limitin valve fitted to the tap.
Mar 20, 2008 | Asko 24 in. 1895 Built-in Dishwasher
Asko 1895
water in base remove dishwasher and tilt to side and it will restart,but you may have a leak,also check the inlet valve may not be closing fully.hope this helps.
Mar 06, 2008 | Asko 24 in. 1895 Built-in Dishwasher
Asko 1885-1895 heater element replacement
Remover the lower front panel, and from there you should reach the element nut. Good luck
Feb 14, 2008 | Asko 24 in. 1895 Built-in Dishwasher
Fan in/on dishwasher keeps running - even after cycle is finished
I have seen this problem before and there are only 2 things you can do about it. 1: take the outer panel off the door to gain acess to the wiring and unplug the fan (it will have a slight negative effect on the drying, but not too much) or 2: replace the control board. The part is about $350-$450 (depending on which board it takes) and that doesn't even include the labor if you cant do it yourself. The only place I know of to get parts for these in the U.S. is american appliance 303 777 0993. If the unit is less than 5 years old, the board is still covered under a parts warranty. Look at your serial nuber on the inner edge of the door to determine when it was built. The first two digit are the year it was made ( so an 01 would be 2001 etc) and the second two digits are the week (so 45 would be the 45th week of the year) HOpe this helps!
Nov 29, 2006 | Asko 24 in. 1895 Built-in Dishwasher
Dishwashers Logo
131 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
