Question about Zebra Z4Mplus Label Printer
Zebra z4mplus on my Z4mplus it dose not print noting out when i print off of bartender it gose to my z4mplus then noting comes out its just blank lables what do i do
  • chris aka10 May 21, 2008
    help me please
  • 155 Answers
It happens that the printer is not calibrated to the labels you want to print. A quick fix is to restart the printer with its factory settings, press FEED and PAUSE when you turn the printer, release the keys when label feeding.
Roberto Martinez
Posted on Oct 06, 2009
    Champion:
  • 254 Answers
IN THE DRIVER CHECK THE head TEMPERATURE ISSUE. Most certainly you do not heat enough to do the transfer.
Else your ribbon is not mounted correctly. Zebra has an out inking transfer film
Posted on Sep 11, 2009
My zebra z4mplus just start printing at the center of the label instead of at the left side of the label. Instead of a normal full printing on a label, now the left half of the label is blank, and the...
Welcome to FixYa.
The Zerba Driver might have been corrupted.
Uninstall the Zebra Driver/Software from the Control Panel.Re-install the Zebra driver using the Disc that came along with the printer.
Thank you for using FixYa.Have a great day.
Nov 29, 2011 | Zebra Z4Mplus Label Printer
I have z4mplus recently i changed print head , fonts are complete one blank line is same place for any priting
If the blank line is vertical (parallel to the print direction) then
Either the head is damaged at this point (dots missing) or you have something on the ribbon which prevents the head from doing the transfer.
Or the ribbon is faulty and you have to change the ribbon
Aug 11, 2011 | Zebra Z4Mplus Label Printer
My Zebra Z4Mplus printer is skipping labels when I print
check the label margins, and label dimensions, and spacing , normaly is these problem, or is a printer driver problem, try reinstall driver
Jan 13, 2010 | Zebra Z4Mplus Label Printer
Zebra Z4MPlus not printing dark enough
In your label software there should be a setting option for print darkness (I assume it adjusts the head temperature) In ours (bartender) you can get to it when you select 'print' and a window appears with a 'documents properties' button. Click on this and select options and a darkness bar appears which you can adjust. You may also need to slow the label print speed if the darkness adjustment is not enough. I suspect it isn't in the printers best interest to run the print head at maximum darkness/heat so a sensible balance of darkness and print speed is best.
Another, less likely, possibility is an incompatability between the label material or surface finish, and the ribbon type. We did have a problem once whem Homebase changed their price label design and we had to test a load of other ribbon types until we got one that did the job. A chat with the label or ribbon supplier is always usefull, they sent us several sample bits to test.
Sep 30, 2009 | Zebra Z4Mplus Label Printer
Z4Mplus pause or feed not working
The first mainboard of Z4Mplus falls short of this error and need replacement.
Roberto Martinez
Sep 22, 2009 | Zebra Z4Mplus Label Printer
Zebra Z4m+ won't print from Bartender 9.01
BarTender uses its own drivers for each model of printer you must install the correct driver, because there are differences in some commands a printer to another.
Mar 09, 2009 | Zebra Z4MPlus Printer
I have a z4mplus and i have no know how to get it toprint bar codes, it prints text but no bar codes
You are using a label design software? Label Matrix or Bartender software, are best.
Feb 23, 2009 | Zebra Z4Mplus Label Printer
I have a Zebra 160s lable printer & i want its installation S\W
You can use software such as Label Matrix, BarTender, EasyLabel or ZebraDesigner (free on zebra.com).
Jan 17, 2009 | Zebra Z4Mplus Label Printer
Zebra Z4MPlus Ribbon Wrinkles
I changed the print head, and the issue was solved.
Aug 01, 2008 | Zebra Z4Mplus Label Printer
When printing more then 10 labels from Acrobat some of them are missing
Hello!
Dear
I need ur assistance about this types of Model TLP-2844,LP-2844,S4M,S-600,105SL,110xiii,140xiiiPlus,Z4M,Z4MPlus,How can I Install a Printer With Label and Ribbon?Can U help me regarding this problem?I am waiting for ur assistance.If possible please send me a video file about how to Install a Zebra Printer with label and Ribbon.
Dec 13, 2007 | Zebra Z4Mplus Label Printer
Zebra Z4Mplus Label Printer Logo
448 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
