Question about HTC S710 Smartphone
HTC S720 Smartphone
The softkeys, navagation keys, send, end, home and back keys on my HTC S720 stopped working.
  • Anonymous Nov 15, 2008
    I have the same problem. I did a hard-reset using the soft keys. However, the hard-reset didn't correct the problem with the middle button, call, end, home, back, soft-keys.
    so the only time the soft-keys work is to hard-reset... so its got to be a software issue, but a hard-reset wont fix the problem.
    Novelist:
  • 153 Answers
Try a soft reset (remove and replace battery), If your sure you haven't installed anything that may have remapped the keys, next option is a hard reset (all data will be lost, make sure you back it up)
There are two methods to performing a hard reset
  • Select Start > Accessories > Clear Storage. Enter 1234 where prompted and select YES.
  • Power the device off. Press and hold the left and right soft keys. Power the device on while holding these keys. Follow the on-screen prompts to factory reset the device.
If you find you can hard reset using the second method you know that your keyboard is ok, if the it refuses to reset its looking like an electrical problem which could be the keyboard or motherboard..
best of luck
Posted on Jun 02, 2008
Home button cannot work propoerly
I notice that your smartphone have softkey, meaning that there is no phisycal button. There is no description on what your phone does or does not do, so I have to guess here. If your phone is rooted, then I suggest you install any unofficial ROM for your device that have the Nexus softkey. Thais if the problem is with the digitizer or a hradware problem.
Before doing that I would recommend that you re-flash the current Android OS that you are using, since it couold also be a problem with the firmware.
Oct 27, 2013 | HTC One X Android Smartphone Glamour Gray
The Application HTC Sense (process com.htc.launcher) has stopped unexpectedly
This is the main OS force closing itself, if you can do it the only way to resolve is a master reset. You can do this by:
  1. Power handset 'Off'.
  2. Remove the Data Card, if applicable.
  3. Press and hold Back and Home keys.
  4. While still holding Back and Home keys, press power button.
  5. Click the MENU key to reset.
Feb 10, 2011 | HTC Hero Smartphone
I have the first HTC Tilt, and I have forgotten my passcode to unlock the phone. Is there a way I can reboot, or reset the whole thing instead of sending it in and paying for them to fix it?
If your keys lock then this will not work but here is the instructions to do hard reset. WARNING !!!!hard reset will erase all of your info and your phone will be set to factory. By the way if you take it to an AT&T corporate(not walmart) there should be no charge for them to get your password for your phone.
A hard reset erases all data off of the HTC Tilt.
1. Press and hold the left and right softkeys at the same time.
2. While continuing to hold both buttons, use the stylus to press the Reset button at the bottom of your device.
3. Release the Reset button and continue to hold down the 2 softkeys until you see a message about deleting all data from the device.
4. Press the Phone button to complete the hard reset.
Dec 17, 2010 | HTC TyTN Smartphone
Cost of hts s710 &s720 .does it support 3g
hey there welcome to fixya
the HTC S710 does not support 3G. You get quad-band GSM with GPRS and EDGE, which should keep you connected (albeit at moderate speeds) both at home and abroad.
however HTC is releasing the s730, which is a 3G phone and is basically the next model up from the s710; however, although it is the same form factor, there are some visual differences. Take a look:at theses links
link 1
link 2
i hope this information was of great help to you please remember to rate this solution thank you
regards
magical ink
Jun 01, 2010 | HTC S710 Smartphone
HTC P3400i is not working properly, only a red
Try to hard reset it. You, most probably, know that a hard reset will set your device to its factory defaults, thus deleting every program you have installed, as well as you personal data. Hope you have a recent backup, to be restored after the hard reset procedure.
Anyway, to do it, press and hold both softkeys (the ones marked with '-'), and, whilst keeping them pressed, briefly press the reset pin (at the botton of the device) with the stylus pen. Keep pressing the keys until a warning message comes up. Then, release the keys and follow instructions on the screen (if any).
Hope you are able to bring your device back to life.
Regards, Carlos
May 05, 2010 | HTC Touch P3450 Smartphone
Cannot figure out how to use the phone key pad but was able to before?
key pad is off on the sides left and right is actually somewhere in the middle of the home and call send button or back and call end picture
Aug 05, 2009 | HTC Touch Pro Smartphone
HTC Dash Keypad Problem (some keys dont work consistently)
Wow. That is an old phone. Replacement parts probably will cost more than another phone
Mar 07, 2018 | T-Mobile Dash Smartphone
Back up of data on computer from htc s720
for dat u need 2 install windows synchronize 4.2 and windows outlook,,,,open outlook first and den connect mobile using data cable and den select contact 2 synchronize...dat will b saved 2 outlook...
Oct 26, 2008 | HTC S710 Smartphone
HARD RESET MY 02 XDA SMARTPHONE
To perform a hard reset
1. Press and hold the Left SOFT KEY and the Right SOFT KEY, and at the
same time, use the stylus to press the RESET button at the lower left
2. Release the stylus, but continue pressing the two soft key buttons.
Release them only when you see the following message on your
device screen:
“Press Send to restore manufacturer default, or press other keys to
cancel.“
3. Press send on your device.
Jun 01, 2008 | O2 Xda Orbit Smartphone
HTC TY II Product - messaging not working
You will have to do a master or "hard" reset which will reset your phone to factory state. This can be done via Tapping Start > Settings > System tab, then tap Clear Storage and input "1234". Conversely you can also hard reset your phone by holding both your softkeys (the physical keys that map to left and right menu options) and using your stylus to hit the reset button while holding those two softkeys.
Apr 29, 2008 | HTC TyTN Smartphone
HTC S710 Smartphone Logo
6,013 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
