Question about Archos 605 WiFi Digital Media Player
Archos 605 wifi frozen/bricked
The screen shows "archos entertainment your way" then go's to error code 102 and do i want to repair or reboot,tried both and it just go's back to "archos entertainment your way"tried a reset no good.
    Genius:
  • 2,035 Answers
You need reset the master reset on your wifi ...
In the event that your ARCHOS freezes or does not respond anymore, try to reset
it: press the button for 15 seconds (the ARCHOS will shut down completely)
and turn it on as usual.
If this does not work, you can also press the “master reset” button as shown below.
You can use the end of a paper clip to press the button in the hole.
Please click on this link to download the manual:
http://www.archos.com/support/download/manuals/english_user_manual_archos_gen5_v3.pdf
Use this link to contact tech support from the company website:
http://www.archos.com/support/support_tech/email_support.html?country=us&lang=en
good luck...................
Posted on May 21, 2008
    President:
  • 2,712 Answers
1. If you have a 102 error, try to turn off the Archos, take out the SD memory and turn on again. If you don't have the same error code, just insert the SD memory and never turn off the Archos:)
2. You can reset the system by using a paper clip and press the button next to the connector on the bottom. You can go to the archos site http://www.archos.com/support/support_tech/manuals.html?country=global&lang=en and download the manual, it will show you where to reset with paperclip.
If all else fails, and your device is still under warranty, I recommend getting it replaced.
Hope that helps!
  • 3,940 Answers
I did some searching and here is what I found:
The problem occurs if the OS got corroupted,
Follow the steps.
First download the lastest Firmware ( OS-(firmware_a605.aos)) from the ARCHOS website.
Plug your device to your PC
Power down the unit completely, While off hold down the Power and TV/LCD button. This will bring up again the screen with 3 options.
1) No
2) Repair
3) Formate Disk
choose the Repair option, wait for 5 mins then you can see your device detected in the PC.
copy the OS .aos file downloaded from ARCHOS website to the root of the device not in any folders.
In your device now choose the option done. It will update the new OS and it will restart automatically.
You can also search this site for the 102 error:
http://forum.archosfans.com/viewforum.php?f=25
Most posts I found on this issue indicated a failed hard drive in the 605. A lot of comments on quality too.
    Brigadier General:
  • 3,614 Answers
There's a possible error on the disk or the archos storage, - a certain corrupt file could possibly the one making the unit into freeze..
POst back here again
Thank you
How to fix archos 605 code 102
I was think maybe there is something was wrong with the Firmware so i decided to download the new firmware that was available at Archos.com. at the white screen wen you see the white screen keep hitting no rapidly until it starts up to your regular screen. If you must try the recovery. Anything to get to the main screen. Then try putting the updated fimware into the root directory after you connect via USB. Then try rest settings.
I hope this helps
Sep 09, 2009 | Archos 605 WiFi Digital Media Player
Wont start recovery 102??
Remove your memory card and restart your archos, when it asks if you want to repair blahblah... just keep pressing the cross till it loads as normal with the sd card 'out', this should work, to stop it happening in the future format your memory card 'sd' with your archos once it has started. Hope that helps!
Sky DD
Jul 09, 2009 | Archos 605 Wifi Portable Multimedia Player
Recovery code 104 appears on my archos 605 wifi 4gb
recovery code 102 and 104 appear in archos screen. it doesn't work.
Jun 07, 2009 | Archos 605 Wifi Portable Multimedia Player
Getting a white screen with 102 error message
I fixed my son's 605 4 GB had Recovery code (104) on it. This might work for other error codes too. These are the steps i followed
* Use the computer for this process that you always used for this archos Archos should be plugged in toPc before starting the process.
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white option screen comes up pick the format disk
* Wait until all done do not pick any option on archos after format is done Pc should recognize your archos in 5 seconds
* Put the firmware in root section of the archos not in any folder.
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug it back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving, wait until it is all done, it will shut off. Turn it back on and  your archos will be back to normal
Mar 13, 2009 | Archos 605 WiFi Digital Media Player
My archos 605 won't do anything but to show recovery code 102.
recovery code 102 screen - this error message means the the hard disk has failed - I am guessing that the unit has been dropped at some point - Sorry but it back to Archos - The UK number is 0207 949 0115
Jan 20, 2009 | Archos 605 WiFi Digital Media Player
It shows-recovery error-102 & error-104
Hi
i had same issue. nothing worked until i saw a guy who fixed his by dropping it on floor?
i dropped my archos in the protective case from 2 feet off floor. the bloody thing when came back to life, 100% good. i think the hard drive was stuck and the fall fixed it!! it cannot hurt as yours is broken still i guess. hope it works for you to
Jan 07, 2009 | Archos 605 WiFi Digital Media Player
I Have a Archos 605 wifi 30GB
You can try to connect to your computer with the usb connection. In case it shows up after some time in ´your computer´ as a regular old diskdrive, then you could try a chkdsk /f command, in order for fix a harddrive error, or reformat and download the firmware, and try to run that on your computer to the harddrive of the unit.
Gerard
Nov 20, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 160G Error cod 102
Hi everybody i just got off with archos USA tech support there is no other way but to send it in and they wil replace the HDD with a new one. If the archos is not under warranty repair cost is $ 172.50 i think you can buy another one for that price. Although they give you 90 days warranty for their fix.
Jun 29, 2008 | Archos 605 WiFi Digital Media Player
Archos seems to have Bricked itself
my archos just goes back to code 102 and i have tried it several times
what do i do now
please help
Apr 23, 2008 | Archos 605 WiFi Digital Media Player
Recovery code 104
Same issue on my Archos 605 wifi 4GB
The Repair didn't work so here's what I did.
1) connected via USB and got all my Picture, Videos and Music to a safe place.
2) Downloaded firmware update.
fouund it here - http://www.downloadplex.com/Drivers/Firmware/Archos/Download-Archos-605-Wifi-4GB-Firmware-2.1.04_109044.html
3. Copied update to root of archos drive and rebooted
4. Archoes installed the update and rebooted and came up to desktop again
5. reinstalled plugins (thank god I saved them) copied plug-in to root.
6. Back on the road again
Feb 23, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 WiFi Digital Media Player Logo
589 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
Jim Goldsmith
Jim Goldsmith
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
