Question about Car Audio & Video
Wiring diagram I have a 2004 gmc pick up. I want to hook up an auxillary amplifier to my existing stereo.I have a converter to change stereo outputs to rca outputs.I need to know what wires and colors I need to hook up to the converter.It has the Bose system in it.Any help would be appreciated. The dephi part number is 12246889 the gm part number is 10357886
    Problem Solver:
  • 7 Answers
Go to 12Volt.com
They have the best and most complete wiring diagrams for all your makes, model for stereo installation and other wiring problems.
Posted on Jul 21, 2009
  • 57 Answers
See if this link is of any help. I know how crazy these new wire colors can be. I don't know why they don't keep it simple and universal meaning all constant power be red, alt power blue/white, ground black, etc. etc. Even my Hyndai has crazy wires. my red is lf speaker, yellow, lr speaker, etc. Goodluck with it man.
http://64.85.6.118/diagrams/diagrams.asp
Posted on May 21, 2008
How do I hook up a sub woofer & speakers to my car stereo?
If you are replacing the existing door/deck speakers with replacements of the same size and not adding an amplifier, you will be able to use the existing wiring, making note of the positive and negative notation.
Subwoofers, on the other hand, require an amp. There are subs that have an integrated amp in the enclosure, otherwise you will need to buy a separate amp. Connecting the amp to your existing system will highly depend on what outputs your head unit (aka stereo) has. If it has pre-amp outputs, those can be run straight to sub amp. If there are not pre-amp outputs, you may have to buy a "high level" adapter that connects to the same head unit outputs as your speakers.
Jul 02, 2016 | Car Audio & Video
How do i hook my car speaker and the sub and output converter together
you splice the output converter into the stock stereo speaker wires, then run rca cables from the converter into the amplifier rca inputs. the amplifier prolly has left and right speaker leads, you will have to locate a manual, or photo of the mono bridged lead position, if it isnt labeled on the side of the amp
Jul 18, 2015 | Car Audio & Video
2004 Tahoe Line Output converter
You can get the signal wired behind the radio or if it is more convenient you can tap into the rear speaker wires in the colums in the rear of the vehicle which will make your rca's from it be shorter to the amps in the rear.
Jan 16, 2013 | PAC Audio Pac Sni-35 Line Output Converter...
Need wiring diagram fo 1994 nissan quest gxe premium stereo
A picture requires an installation, which is what you are doing. You should invest in a vehicle specific wiring harness. The wiring colors match for the connection and said harness then plug into the factory harness. If the factory harness no longer exists then you need the wiring diagram for the vehicle. You mention the vehicle has a premium stereo, the Metra part number is 70-5510. It's for an amplified system.
Aug 11, 2012 | Nissan Vehicle Parts & Accessories
Jvc KW-AV50 subwoofer amp hook up
very good ! there is nothig wrong with your system, buy a stereo to mono RCA jack (Rs10/-) and connect the subwoofer (if single coiled) L+ & R-- of your existing amplifier. NB: Please go through the manual of amplifier
Apr 08, 2012 | Car Audio & Video
How do i take out the factory stereo for a 2008 mazda 6, in order to install an after market amp?
http://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/pdfs/receiver_guide.pdf
Hi Lo Adapters
Hi/Low adapters are devices that installers use to convert a speaker level stereo to RCA levels so it can be hooked to an external car stereo amplifier. You can cut the speaker wires and hook the hi/lo adapter right up or you can tap onto existing speaker wires without cutting them so the speakers still play while the tap gives you a connection to the hi/lo device for adding something like a subwoofer amp to the existing speakers.... We have hi lo converters in TWO CHANNEL and FOUR CHANNEL configurations and we have them WITH and WITHOUT adjustments.. The adjustable hi/lo converters allow you to fine tune the hi/lo device to match other levels in the car or to make sure the match between your stereo and amplifier is a good match.. The adjustable line converters are the most popular.. We also have some specialty hi lo converters that have special radio plugs on them that may plug right into your factory stereo.
Now you can install an amplifier with your factory radio or install a new radio with your factory amplifier!
Mar 30, 2010 | Kenwood Car Audio & Video
How do i hook up the amp wires to the factory stereo and the speaker wires
Amp wires are direct to battery..as far as sound, you need a line level converter to connect to your rear speaker wires (left/right) that sends the signal to the converter and switches it to RCA level outputs. You would then just connect an RCA cable from the converter to the amp and there you go. A converter is $20-$50 depending on the quality you want. The better ones connect to pos/neg and have a metal caseing.
Nov 05, 2009 | Rockford Fosgate 800.2 Car Audio Amplifier
Need to hook up an amplifier to a stock 2000 Buick Lesabre radio, do you have a manual?
In order to hook up an after market amplifier to a stock stereo your going to have to use a line output converter to adapt it to RCA cables to hook up to your amplifier.
Oct 14, 2009 | 2000 Buick LeSabre
Installing self amplified sub to factory stereo
Hello Jax GS300,
Yes, you can use RCA cables. Just wire in a "low-level" converter.
Using RCA's is really the best way, allowing you to run shielded wiring to the sub, making it less likely that the wiring will pick up electrical interference. I'd install the converter on the rear speaker wires behind the dash.
If you do not want to convert the speaker output, you can drive the Kenwood directly from the speaker wires. The diagram in the install manual shows the connections coming off the rear speakers.
Here's a link to one output converter. This one will convert all 4 speakers.
http://www.crutchfield.com/p_142SLC4/Scosche-SLC4.html?search=level+converter
Hope this helps.
Apr 09, 2009 | Kenwood KSC-WD250 Car Subwoofer
Car Audio & Video Logo
1,188 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
