Question about ViewSonic VX922 19" Monitor Flat Panel
Viewsonic VX922 19" Green Light Blinks when booted, no picture
I have a Viewsonic VX922 for about 2 years. Recently Started blinking upon boot up. Every 7th boot the monitor would catch and all would be well; however the situation has deteriorated and now when I boot up the orange light turns green and blinks continuously while featuring a blank screen. the computer boots okay;because I here the appropriate bells and whistles, but nothing shows on screen. I took the monitor apart and their is a thin elongated chip board with 5 square boxes and a bulb attached to a small harness; Unfortunately I don't know what needs replacing or if I am even on the right track as their is no obvious sign of trouble. Any help would be greatly appreciate as calling Viewsonic was a nightmare talking to off shore folks.
Thanks Gerry
abategerry@yahoo.com
  • 9 more comments
  • pr_o Jun 10, 2008
    My problem is exactly the same. When booting, all I get is a blank screen with the backlight on, and I have to enter the password in the login screen without graphical environment. Sometimes the solution provided below (turning off the monitor for a few seconds or minutes) works, but most of the times it doesn't. Besides, this issue makes impossible a dual boot. The curious thing about it is that when rebooting my computer after a long session I don't get this annoying blank screen, which makes me think of a power management problem, as if ViewSonic VX922 would have some kind of problem recevering signal after a long time off or asleep. Here are my specs: AMD Athlon x64, Windows XP x32 SP2, Geforce 5800 GT
    Thank you
  • Anonymous Jun 10, 2008
    Have the exact same problem! Athlon XP2700+, NVIDIA GeForce 7800GS (AGP). Can't believe everyone who has this problem is coz' of the graphics card.
    But here's my work-around -- I remote into my desktop from my laptop. Within a few seconds, the monitor starts working and shows me the Login screen. So, then I switch to my desktop and type the password (which kills the remote connection).. but anyways thereafter, things seem to be fine till the next time I have to reboot.
  • Anonymous Jun 15, 2008
    I am dual booting this pc. 1 xp pro hard drive, one vista ultimate drive. I have not had problems with this config for quite some time,..until now. With xp pro after monitor goes inactive or after a reboot/restart my vx 922 monitor is inactive. I found that booting my vista drive to desktop then restarting to my xp drive would boot to active monitor in xp. At this point, it seems that is degrading. My percentage of active monitor in xp per boot sequence is decreasing. ::((((((((( I hope viewsonic has a solution. It seems like a driver issue but I'm current on each drive/os.........
  • bansuki Dec 16, 2008
    same problem - one video card hooked up to two monitors so i know it's not card. possibly hardware; no software updates to monitor or other drivers. interesting note, the bios splash screen does show occasionally but the image reliably dies and the green light flashes once the OS starts to load.
    i've had this monitor for about two or three years with no problems.
  • Anonymous Dec 23, 2008
    I have 2 VX922 monitors side by side, one attached to single computer with digital connection and one that can be switched analogue between 3 computers. They are both just over 3 years old with no other problems to date. Recently the analogue connection monitor started doing the same thing which was most noticible on a dual boot machine - linux and windows me, I thought at first grub wasn't loading properly as the green light flashed and the screen went blank. I only realised today that it was a montor problem as you can still boot windows if you arrow down at the appropriate time and press enter.
    It must be a problem associated withe monitor heating up as it always seems to show all the boot up screens from stone cold after a few hours with no use - I will keep looking and email viewsonic for assistance.
  • Anonymous Dec 29, 2008
    My computer has been getting this just recently, around 2~3 months. The boot screen and windows XP logo loads fine, then as it refreshes to the login screen, the monitor just goes black, and the LED power light just blinks. The problems are escalating now. My only current solution was to turn off the power for like a good 30 seconds, then turn it back on.
    Now though, it doesn't work. It just stays back. I've had to force shut down my computer quite alot of times to reboot. Its seems like its an annoying problem with these Viewsonic monitors.
    My screen sometimes works fine while playing games. But when I alt+tab to the desktop, the screen goes black. And I'll have to turn off the monitor for a good 30 seconds before It eventually reappears.
    Any help or recommendation will be helpful.
  • JimmyRoX Jan 04, 2009
    i have EXACTLY the same problem
    Since 1 week ago my monitor started with the same blackout and the green light blinking
    Im running a Mac Pro under Mac OS X 10.4, so i really doubt its CPU software/hardware problem, since users with windows r with the same problem.
    (This happen even when sometimes i go AFK and then come back, wake up my Mac and the freaking light start blinking and the screen never come back)
  • Anonymous Mar 02, 2009
    i have 2 vx 922s both started at the same time
  • choke_arg May 26, 2009
    My monitor has almost three years of use. It started with the same problem. I tested the PC with another monitor and works fine.
    In my case, it seems that the problem is with digital input. As my graphics card allow to work with two monitors, I found that the graphics card detects the vx922 over the DVI input but nothing is seen on scren.
    After several powering on and off I can make the display shows something but only in analog mode, which seems to be working fine yet.
    I could not find a way to make to the display start always in analog mode. It is annoying. Changing capacitors may help me? is there any way to fix the analog mode?
  • smithy1001 May 11, 2010
    'I have the same problem with my VX922 as do MANY others. The problem seems to be caused by leaking/bulging capacitors on the circuit board. The only solution is to replace the faulty capacitors either on your own (which is fairly easy if you're good with a soldering iron) or send it to Viewsonic and have them fix it. '
    Could you be more specific on which capacitors on the board need replacing.
    Many thanks
  • Eric Smale
    Eric Smale May 11, 2010
    Gerry, have you tried this monitor on another computer to isolate if it is indeed the monitor or perhaps your video card?
Posted on Jan 03, 2009
Exactly same problem. I have two computers and experienced the same problem.I will let them repair it.
Posted on Dec 20, 2008
I also have the same issue, although it does not happen all the time. Sometimes when I reboot my computer or when I try to bring it back from sleep mode.
8800GT
Posted on Jul 02, 2008
Lol i got the same blink prob 8800gt videocard
Posted on Jun 13, 2008
I have the exact same problem on my Athlon XP2700+, NVIDIA 7800GS (AGP).
My workaround -- remote into my desktop from a laptop. Within a few seconds, the monitor starts back on. Then switch to desktop and it usually works fine until the next time I reboot. Rinse.. Repeat...
Posted on Jun 10, 2008
  • 3 Answers
A temporary solution I've found is to turn the monitor off for 10 seconds with the frontal switch then back on. Works for me most of the time. Looking for a solution myself.
Posted on Jun 09, 2008
Had the same problem.
What helps for me is to turn on the computer, wait 2 minutes till its fully started up (login screen), and then turn on the monitor.
Posted on Jan 07, 2009
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
The last led light blinks green and sometimes it turns solid red
red light is stands for hardware boot and the green one is stands for system boot and disc boot. when red light remains solid it means your system is in 0% cpu usage and nothing doing, stop working
May 09, 2010 | Intel SC5299BRP
Green light on front rapidly blinks after power outage. No picture, or can't turn on
This unit, when first plugged in or after power interuption takes 70 to 90 seconds for the digital module to boot up. During the time the LED blinks green and the set will not respond to anything. After the appropriate amount of time the blinking should stop and the set should operate normally. If the blinking never stops then you have to have the Digital Module repaired.
Apr 25, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Sony kds-r50xbr1 turns itself off and then green light blinks 52 times
Just replace its Lamp and procedure is written in user manual of KDS-R50XBR1
F93087600 XL-5100 LAMP BLOCK
Lamp is available in Sony Accessories and price is $250
Always buy Sony original lamp for good picture in TV and avoid aftermarket / cheap lamps that can cause damage of TV circuits.
Click Sony Support to download Instruction Manual copy, if you want it.
Apr 22, 2009 | Sony Video Cameras
Computer will not boot or respond
Beeping upon startup is generally a problem with memory ..
Mar 13, 2009 | HP Compaq dx2000 PC Desktop
My viewsonic monitor is not working
Considering the price of monitors versus the cost of repair. It would cost less to replace the monitor.
Mar 12, 2009 | MPC Computers Viewsonic E771 17 in.CRT...
Viewsonic problem
Get the RMA, I had no problems whatsoever with thecustomer service folks. They answered email within 1 business day, shipped off the monitor last week...
Jun 22, 2008 | ViewSonic VX922 19" Monitor Flat Panel
Sony LCD television will not power on.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is.
no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Viewsonic Monitor problem, blinking LED light, no picture.
you guys......you don't have a software (driver, refresh rate, etc.) problem. When you first power up the monitor, do you get any display at all (ex, "analog input" or "No input signal")? Of course not - that's because you have a hardware problem with the monitor. Go here and watch the youtube video on how to take apart your monitor and find and replace the "domed" capacitors that have blown:
http://www.tomshardware.com/forum/247964-33-viewsonic-vx922-monitor-black-screen-green-power-light-flashes
Fortunately I only had 1 ($1.76 at Radio Shack). I replaced it in less than 30 minutes and my monitor showed "no input signal" upon powerup as expected because I wasn't connected to my pc which is full of all kinds of drivers and refresh settings, etc.
Aug 16, 2007 | ViewSonic VX922 19" Monitor Flat Panel
ViewSonic VX922 19" Monitor Flat Panel Logo
1,554 people viewed this question
Top ViewSonic Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
