Image with double background and red color in corner of TV
Thanks for the data regarding the ICs the model set is panasonic PT-51HX41
THANK YOU VERY MUCH FOR YOUR HELP.
  • 8,617 Answers
Your set uses two Convergence ICs they are both STK392-110 you can get replacements at the following link and they provide free instalation instructions with pics, plus offer free tech support by instant messageing which is always free for all thier customers.
http://servicemanuals.vstore.ca/
Posted on May 21, 2008
The green, blue, and yellow colors seperates also tv will no longer come on
You need to replace Both of the Convergence ICs,they are big black ICs and will have Part Number on them .
Example STK392-110
Mats Electronics has ICs 1-800-628-1118
Feb 05, 2011 | Panasonic PT-51HX41 51" Rear Projection...
Red ghost images
Yes there is a repair kit for your model which contains the two Convergence ICs and the 6 feed resistors. The kit alkso has step by step instructions with pictures so you can easily do the repair. Heres the link for the correct kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-1/cName/convergence-repair-kits
Jun 01, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Double vision
You need to replace the two convergence ICs they are STK392-110 you can get replacements at the following link with fre installation instructions.
Aug 19, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Double vision
you need to replace both convergence ICs they are STK392-110 you can get replacment ICs at the following link with free instalation intructions with pictures. Here is the link.
Aug 11, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Double vision
Its a repair you can do yourself for under 40.00 if you can solder . You need to replace both convergence ICs they are both STK392-110. You can get replacement ICs at the following link with free instalation instructions with pictures. TV shops generally charge between 400 and 600.00 for this repair which takes about an hour.
Heres the link
Jul 18, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Red tinted double image above the normal image.
hello consumer MG,
you need to change your STK392-110. Replacing those 2 chip will fix your set.
best regards
circuitcity
www.interactiverepair.com
Jun 08, 2008 | Panasonic PT-51HX40 51" Rear Projection...
Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
C-Dog
Feb 18, 2008 | Sony KP-41T65 41" Rear Projection...
Panasonic Model No. PT-47WX42F
Replace the convergence amps. That unit takes two Sanyo STK392-110 and you could use 150's for greater reliability. Also replace one or more of the 1.2 ohm resistors in the yoke return circuit out front of the amps.
Oct 06, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic 52"problem
You need to change the two convergence IC's - Generic part# STK392-110, Panasonic part# C5AA00000203. You might have problems using the generic #, I would use the Panasonic #
Sep 26, 2007 | Toshiba 46HM95 46" HDTV
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Electro Med Services...
