Question about Cameras
Have a nikon coolpi S51 . error message saying memory card is write protected. it is not will work in other camera's and tried a new memory card and it says the same thing. skips over format card when trying to accesses it from the setup menu
  • 2 more comments
  • Anonymous Jul 22, 2008
    ya i have the same problem i got a new one too. I also tried switching the switch but that didn't work either!! what can i do..... or what did i do
  • Anonymous Aug 20, 2008
    same
  • KALLETAH Oct 06, 2008
    EACH TIME I TRY TO USE THE CAMERA IT TELLS ME MEMORY CARD IS WRITE PROTECTED. I SWAP OUT THE MEMORY WITH ANOTHER AND IT'S SAY THE SAME THING. I FORMATED THE CAMERA AND UP LOAD ALL MY IMAGES TO MY DESK IN HOPE THAT IT WOULD HELP... AND NO RESULTS!!! I AM PISSED, BECAUSE I USE MY CAMERA EVERY DAY. HOW CAN THIS PROBLEM BE FIXED? OBVIOUSLY IT'S NOT THE MEMORY CARD.
  • kristin663 Nov 14, 2008
    i have the exact same problem...the memory card is unlocked, even a new one, and still get the same error message that it is "write protected".
If this problem is dealing with an SD-Card, there should be a little switch on the side of it. Just switch it off of lock. It worked for me.
Posted on Jun 01, 2009
I had the same problem and was on here looking for a solution and my friend just told me the card has a little catch on the side which can accidentally get pushed into protect card position. So all you need to do is slide the tiny catch on the side of your card in the opposite direction and it should work perfectly again.
Hope this helps you as it did me!
Katie
Posted on Feb 20, 2009
I'm having the exact same problem with my s51 camera and have been frustrated with it for a while now.
Posted on Jul 16, 2008
    Champion:
  • 203 Answers
Ususally this happens when switch is moved on memory card-odd that it would say it for 2 cards-try one last sd card -if not camera issue-make sure slider switch is not locked on card
Posted on May 21, 2008
Camera says memory card is write protected. How can I delete pictures on the card and take new ones?
write protection lock is turned on,, turn it off this maybe 1. a switch located in the camera 2. on off option in the camera menu else plug the camera to memory card reader to delete or format the chip :)
Dec 15, 2010 | Nikon COOLPIX S51 Digital Camera
My nikon coolpix s51 show message memory card is
For the message that show's on your camera here's is what your need to do. 1. Remove the memory card and check for the physical lock toggle.
2. Toggle the lock on and off.
3. Try blowing on the memory card and the memory card port so it will be cleaned somehow. here is the picture of the lock toggle of the SD memory card 919a7e0.png
Apr 13, 2010 | Nikon COOLPIX S51 Digital Camera
Nikon coolpix s51 digtal camera memory card says can not be used?
hi..
There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it.
You need to unlock the card itself. Take it out and look for a tab on the left. It should be pushed up.
thank u
rate me
Jul 22, 2009 | Nikon Coolpix S51c Digital Camera
Memory card write protected
Check the side of the memory card. Some of them have a little switch that turns on/off write protection. If there is no switch, you can try to format it in the computer first, then put it in the camera and format it again.
Jul 11, 2009 | Nikon COOLPIX S51 Digital Camera
My camera is write protected
Dear Hannahboggs9,
I am not quite sure of what is the make of your Memory card however most of the memory cards have a small switch on side that could be toggled to make it write protected. I am sending you a link with picture to make it more clear.
http://media.digikey.com/photos/Toshiba%20Photos/SDM%20MEMORY%20SERIES.jpg
See the yellow slide lock on left edge of the above card...
Now if there is no lock on your card or if the above mentioned is not the problem then you might want to try formatting the card using your computer with "FAT" OR "FAT16" file system selected from the drop down (DO NOT SELECT FAT32).
If that too doesn't work then you might want to try with a different memory card.
This issue doesn't seem to be with camera.
In case any further assistance is required please write back and I would be glad to assist.
Regards,
Srinivas
Jun 25, 2009 | Nikon COOLPIX S51 Digital Camera
Memory Card is write protected
Does your MMC have a Lock/Unlock swap features? if it does. Then Unlock it. Or, you might want to format it.
Jun 14, 2009 | Nikon COOLPIX S51 Digital Camera
Write Protection: There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it.
Mar 31, 2009 | Nikon COOLPIX S51 Digital Camera
''Memory card is write protected''
Remove the SD memory card from the camera and move the small switch on the side to the unlock position. That should solve the problem.
Mar 16, 2009 | Nikon COOLPIX S51 Digital Camera
"memory card is write protected"?? but it's not the memory card!
It's not the camera. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jan 13, 2009 | Nikon Coolpix 4500 Digital Camera
Cameras Logo
410 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
