posted by shutterbug72 on May 21, 2008
I have been using a Tamron 28-300mm lens with a Canon XTi. Thing have been working fine until the last time I used the camera. I can only take pics with manual.
Any suggestions or explanation?
Using Tamron 28-200 on Canon Xti for a year. Suddenly I get an error 99. Canon says lens isn't compatable with camera, Tamron says not true, I need a new lens mine is shot.....
At any rate, I have to buy a new one - should I go Tamron 28-200 again or Canon 28-200? LOVED the Tamron, just don't know how long it will last on the Canon?
Solution #1
posted on May 23, 2008
Hey shutterbug72,
According to the manufacturer the first thing you should try is cleaning the lens contacts with an eraser. If that doesn't work you could try removing the battery and reinserting it to reset the camera. It seems to me that if there was a compatibility issue going on you should have seen that from the start. As far as what lens you should buy both Tamron and Canon make very good lenses, but with Canon lenses you shouldn't ever have compatibility issues. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Sincerely,
Allan
Go Ahead. Use Us.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Tamron 28-200mm f/3.8-5.6 Super II
Email this problem
Email this problem
Can you Help with these Camera Lenses problems?
Tamron 28-200mm f/3.8-5.6 Super II Macro...
this zoom is fitted to a Canon...
finding that the zoom sticks at... Answer This...
Repair Service
Find Camera Lense Repairman Near You:
