Question about Whirlpool Duet GHW9150P Front Load Washer
Dryer won't turn on
We had a power outage last night. the power is back on but the dryer will not turn on. there is nothing. the washer works but the dryer is showing no signs of life. i can't find the instruction packet. i tried unplugging it and holding down the end of cycle button with no success. PLEASE HELP???!!!!!
  • 770 Answers
Whats your email?
Posted on May 31, 2008
Why did Kenmore series 110.60202990 dryer stopped working after power outage?
check electric box, termo fuse on air duck (white 2 wires normally blue)
Jan 05, 2015 | Kenmore Dryers
My car won't turn on it was working fine last
Just because you charged the battery it doesn't mean it is any good. Modern sealed batteries fail; just as you described, fine one moment and then nothing, they go open internally.
Jul 19, 2013 | Cars & Trucks
Honeywell thermostat won't turn the furnace on after power outage.
probably tripped a limit switch or a low voltage fuse would kill your display on the tstat, you should have battery power on your stat though.unless you have knowlege of electrical you better call a technician
Dec 09, 2012 | Honeywell Programmable Thermostat Heater
Frigidaire gallery dryer won't start
It is code that every major appliance is to be on it's own circuit (breaker). I would have an appliance tech check the electric in the dryer for shorts. It's possible the terminal block got shorted. The best thing to do is buy a voltage tester, put it on the block and see if it beeps. If it does, the dryer is getting power and it's an internal problem. If not, then the problem lies between the breaker box and the dryer.
May 21, 2012 | Dryers
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
My whirlpool duet washer displays an "F 74" error code. We had a power outage, the washer is plugged into a surge protector. I called whirlpool last night - they had me unplug for around 10 minutes, plug...
F74 is not a valid fault code. If it was F14, then it was bad eeprom value (on timer board).
Try tripping circuit breaker or unplugging the power cord. Connect power back and follow reset procedure again, that will reset NVRam.
Ensure that there is no water inside the machine. If there is water, while machine is disconnected, empty water.
If that does not work, the control board may be defective.
Oct 09, 2009 | Washing Machines
Maytag MDE4806AYW Electric Dryer won't stay running
AFTER A LONG TIME AND CHECKING ALL CONECTIONS IT FINALLY CAME DOWN TO THE CIRCUT BOARD. PURCHASED BOARD FROM REPAIRCLINIC.COM. EASY TO PUT IN. MY ELECTRICIAN TOLD ME BEFORE I START TO TOUCH THE WASHER GROUNDING MYSELF OUT.
FROM CEWAKA.
Jan 30, 2008 | Maytag MDE4806 Electric Dryer
Tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
Apr 04, 2007 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
Whirlpool Duet GHW9150P Front Load Washer Logo
349 people viewed this question
Dan Webster
Dan Webster
Sal De
