Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
How to change my NAT
I need to kno how to change my NAT from moderate to open for playing my xbox 360 on xbox live...how would i do that
  • Connor bibb Jul 13, 2008
    But I have a Belkin Wireless G Plus MIMO Router and I seem to connect to XboxLive Fine?? When i do a Test connection my NAT is : OPEN :O
    But Last night I was screwin around with my router trying to configure it like updating firmware . It Gave me an error and said i have to go to a new page. I accidently Pressed OK without reading the Message then my internet went down and Now im back up and Routers on but No Homepage and i carnt connect to xboxlive. Its basically screwed some part of my route or connection. >=[
  • Anonymous Jan 20, 2009
    need 2 know how 2 change NAT
NAT is network address translation is the tool that your modem uses to share a single IP address across multiple devices. For XBOX 360 these problems happen when your modem attempts to communicate with another players modem. First try to change your router settings enabling UPnP (universal plug and play) on your router. This step works in most cases. If your modem is running multiple devices try unplugging the other devices if possible and test your connection if it now gives you open nat than one or more of the other devices is causing the moderate or strict nat setting.
Posted on May 14, 2009
hi
may i know how to downgrade the firmware on Belkin Wireless G+ MIMO router?
i've upgraded to a newer version, but found out the newer version has a lot of bugs. how do i downgrade it?
thank you
Posted on Oct 16, 2008
    Problem Solver:
  • 41 Answers
You need to check first if your router is Xbox Live compatible (all routers will work, but only certain ones will allow an open NAT):
http://www.xbox.com/en-us/support/connecttolive/xbox360/homenetworking/equipment.htm
If your router IS on the list, make sure you have a compatible firmware version (usually the firmware version is written on the router somewhere). If you do not have the proper firmware, you will need to downgrade your firmware (reply to me for instructions on this).
If your router is not on the list, you're outta luck.
Posted on May 23, 2008
Every time i try to join my friends game it says session is ureachable and it is really annoying. We live at different IP addresses and could connect before. We all have the same DLCs and it is only me...
make sure you and your friends have open NAT, you need to port forward certain ports for xbox live on your router, try to check if ubisoft also has specific ports need to be open. if still the same contact your ISP, they might be having problems.
Mar 23, 2011 | Ubi Soft Assassins Creed: Brotherhood for...
I need to make my Nat type open instead of moderate. How do I do that?
I just opened my NAT type to play xbox live...using a SURFboard Motorola.
And this site helped me alot:
http://webcache.googleusercontent.com/search?q=cache:d_5pu90czsoJ:news.softpedia.com/news/Guide-to-Opening-NAT-Xbox-360-71775.shtml+nat+type+xbox+360+open&cd=2&hl=en&ct=clnk&gl=ca
but watch this video first, cause it will help out allot too:
http://www.youtube.com/watch?v=gb9kafn8Ebs
With these guides, and bit of web reading from other peoples FAQ's.. I did it.
The guide you need will depend on what modem/router you have.
Good Luck
Jan 13, 2011 | Arris SURFboard SBG900 Wireless Router...
My ports are not open and my internet say you nat type is moderate
If you have a firewall or network hardware, such as a router, you might need to make a configuration change in order for your Xbox 360 console to communicate with Xbox LIVE. This configuration change is sometimes called “opening ports” or "port forwarding."
Xbox LIVE requires the following ports to be open: • TCP 80 • UDP 88 • UDP 3074 • TCP 3074 • UDP 53 • TCP 53
Jul 01, 2010 | Microsoft Xbox 360 Elite Console
My nat settings for my xbox 360 is set to strict, I am connected to xbox live from my laptop, my laptop is connected to my linksys router, how do i change my nat settings to open if my connection is set up...
You'll need to log into the linksys router and find the setting for UPNP. Please make sure this is enabled. That should allow your NAT setting to at least Moderate, if not Open.
Mar 12, 2010 | Microsoft Xbox 360 Console
Switching from moderate NAT connection to an open NAT connection
yo tengo problema co el asistente de conexion del linksys
Feb 10, 2009 | Linksys WRT160N Wireless Router
How do i change my NAT connection from moderate to open
This one is simple. Find the IP address that your Xbox is assigned by your router, then put it into the DMZ. This also goes for PS3 users who are having trouble with internet access.
Change NAT to open
You need to call xbox live tech support. From there they will give you a code. This code will need to be entered in the settings for you wireless interenet product under "Port range forwarding."
Dec 28, 2008 | Arris SURFboard SBG900 Wireless Router...
Change NAT to open
Ok kids... all you hve to do is log in to your belkin 54g at http://192.168.2.1
Find out what ip address your xbox is using and then Click on the DMZportion of your settings on the left hand side of the page.
Enter the xbox's ip address and click the enable box.
Click apply.
Your NAT will now be OPEN!
Cheers!
Mar 24, 2008 | Linksys WRT54GL Wireless-G 54Mbps...
Xbox live connection: My NAT
its likely your router needs to have port forwarding setup on it, or you could try setting up your Xbox ip address as a DMZ on your router.
however some routers simply wont work, I had a voyager 105 using port forwarding but it still never worked till i changed to a Draytek
post more details of your router and what you have tried.
also you cant go far wrong visiting here
http://www.xboxlivetheguide.co.uk/XBoxLiveTheGuide2.php?department=Home
Mar 10, 2008 | Microsoft Xbox 360 Console
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
1,218 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
