Question about Viking 37 in. VGSU161 Gas Cooktop
Viking pro gas range propane conversion
Just had a new 36 open burner gas range installed in new house.
When you turn on the burners you get a 8 to 12" yellow flames. it is a fire hazrd. Installer said that is way it is. That can't be right. There is no low at all without flames. What shoudl we do.
Sounds like your range is set up for the wrong kind of gas, or, in the case of LP, your installer failed to make the necessary adjustments once it was hooked up. First step is to insure that you have the proper range for type of gas you are using. If not, the orifices for all surface and oven burners will have to be changed out. That should be done by a qualified service technician.
Posted on May 21, 2008
Do you know the BTUs for the five burners on this cooktop?
WEIGHTS & DIMENSIONS Approximate Shipping Weight 38 lb Cabinet Width 36 in Cutout Dimensions (Width x Depth) (In.) 33-7/8 x 19-1/16 Net Weight 33 lb Overall Depth 21 in Overall Height 3 1/16 in Overall Width 36 in Space Required Below Cooktop 0 7/16 in
  • POWER / RATINGS POWER / RATINGS Burner BTU Ratings (000's/BTU) - LP Gas (1) 9.4; (2) 7.0; (2) 4.0 Burner BTU Ratings (000's/BTU) - Natural Gas (1) 12.0; (2) 9.5; (2) 5.0 Volts/Hertz/Amps 120V; 60Hz; 5A
  • ACCESSORIES ACCESSORIES LP Conversion Kit Included
  • WARRANTY WARRANTY Parts Warranty Limited 1-year entire appliance Labor Warranty Limited 1-year entire appliance
  • GE 36 Built In Gas Cooktop JGP636WEDWW GE Appliances
    Oct 27, 2015 | GE Profile JGP636 Gas Cooktop
    Is there a specific regulator for a Viking D3 cooktop or can I purchase one off the shelf?
    If it runs on natural gas it has a lower pressure regulator than one that runs on propane gas. Nat gas is 1.1kpa propane is 2.75kpa
    May 03, 2014 | Viking D3 RDGSU2605B 36" Gas Cooktop with...
    Bluestar rangetop clicks several times before igniting
    Do other appliances in your home using LP gas work properly? If so, then this is probably an air/fuel mix problem on the burner(s). If this is a new rangetop there should be directions with the range and the LP conversion kit to instruct on proper adjustments. Be certain the correct LP orifice was installed for each burner (they likely have different BTU ratings for different sized burners) and the ignitor post is clean and spaced properly to burner. Then adjust the air mix to achieve a blue flame with just a tip of yellow. Delayed ignition usually results from the wrong air/gas mixture which doesn't ignite until too much fuel has accumulated. In many locations the company you purchase LP gas from will have someone who can check and adjust this. If the range was shipped from the factory as LP gas ready, then you can also contact your dealer and request assistance.
    Feb 25, 2014 | BlueStar RGTNB364GHCSSLP 36" Pro-Style Gas...
    Flame height on my 36 " 6 burner Viking Range Top
    remove the knob, the center shaft is hollow, slide in a small blade screw driver to adjust the flame cheers
    Dec 11, 2013 | Viking VGRT360-6B 36 in. Gas Cooktop
    B3H0...A7X Propane Conversion Burners Flame Straight up
    Fred did you convert both the orifices on the burners and the gas valve ? they both need it.
    Oct 08, 2013 | Bertazzoni 36 in. P36500X Gas Cooktop
    DCS RGS slow to preheat
    You didn't state whether you used a DCS conversion kit or not. I was able to find conversion instructions for a model similar to yours (not an exact match) but it will give you an idea as to what all is involved.
    DCS RGSC 305 Instructions Manual
    Dec 14, 2017 | DCS RGU-364GL-N Professional Series 36"...
    How do you replace the ignition module on stove.
    Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
    Gas Range Repair Burners Keep on Clicking
    Apr 14, 2010 | Viking Professional VGRT362-4G 36 in. Gas...
    We have a thermador 5 burner gas range top and the pilot light seems to have gone out. The burners don't go on but we smell gas. How do we re-light it?
    Most gas range tops no longer have pilot lights but use an electronic ignition (sparker) to light the burner. Normally when you turn the burner on you should here a snapping or sparking sound, at which point the burner should ignite. Here is a link to the user manual for 36" - 5 burner Thermador rangetop...maybe this will help:
    By the way, in the short term you could always use a match to light the burner. JUST BE VERY CAREFUL THE YOU HAVE THE MATCH LIT AND OVER THE DESIRED BURNER BEFORE YOU TURN KNOB TO START THE BURNER!!!!
    Jan 15, 2010 | Thermador 37 in. SGSX365 Gas Cooktop
    Viking range - no way to simmer
    There is a conversion kit to convert the range from natural gas to propane, it is possible that it was not installed or not installed at the time of purchase. There is a part in the regulator that has to be switched from one gas type to another as well as individual burner orafices that have to be changed. You should have the point of purchase service verify that this has been done correctly. The complete information should be in your owners and installation manual or available directly from the viking website.
    Nov 19, 2006 | Viking 37 in. VGSU161 Gas Cooktop
    Viking 37 in. VGSU161 Gas Cooktop Logo
    364 people viewed this question
    Top Viking Cooktops Experts
    Dan Webster
    Dan Webster
    Lawrence Oravetz
    Andrew Taylor
    Andrew Taylor
    Are you a Viking Cooktop Expert? Answer questions, earn points and help others
