Question about GE Spectra JBP78 Electric Kitchen Range
GE Spectra JBP79 Self Cleaning Electric Range
Dropped a bottle of wine on the glasstop. Cracked pretty bad but the burners still work. Where can I find a replacement top and how hard is it to replace it.
Sea Breeze
  • 4655 Answers
SOURCE: Burners on a GE Spectra JGBP30 Gas range don't ignite
Try this link and download PDF has numbers and answers
http://lib.store.yahoo.net/lib/usappliance/JGBP35manual.pdf
Posted on Jan 31, 2009
SOURCE: Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Posted on Feb 26, 2009
2coolrick
  • 560 Answers
SOURCE: ge glasstop oven
Check the element connections for good tight connections in both connectors. If ok, swap the element with one of the same size working elements and see if the swapped element works. If it does, replace the element. If it doesn't, the control switch or switch connections are the problem.
Posted on Jul 30, 2009
  • 464 Answers
SOURCE: inside of front double burner not working on my
this is a 9" 2600 watt element and may have to be replaced, here is the part #WB30T10050. if the element checks out ok, you may have to replace the infinite switch and this is the part #WB24T10011. hope this helps.
Posted on Oct 15, 2009
  • 189 Answers
SOURCE: GE JBP79 door locked, no led readout after self clean
Hello- Control is about 250$. Could save 100$ by installing yourself, but the popular "self-destruct" cycle can cook other switches and what-not. Find a tech and inquire up-front if completed repairs are too high, they keep parts, you pay trip charge.- Hope this helps- ED
Posted on Mar 01, 2010
Dual top burner will only heat up on high.It is only the large ring burner GE JBP79
Does it go straight to full heat even though it is on the low setting. If this is the case the hotplate controller is faulty and requires replacement.
Feb 24, 2011 | GE Spectra JBP78 Electric Kitchen Range
Have a GE Spectra Elactric 4burner w/Self
the two front burners are not working - no electricity
Mar 14, 2010 | GE Spectra JBP78 Electric Kitchen Range
Mar 01, 2010 | GE Spectra JBP78 Electric Kitchen Range
Can I use cast iron on a glasstop electric range?
yes it is true, the heat transfer will be to great and will crack or explode the glass. definately not recommended.
Nov 08, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Knocked burner off kilter & it won't reset into place or turn on
you should take it off anf take it to lowes, home depo, or a appliance store and replaceit it should be fine then. It most likely got cracked.....
Jul 10, 2009 | GE Spectra JBP78 Electric Kitchen Range
The oven of GE Profile range simply stopped igniting
If it is a ge it would have a glow bar ignitor, either a flat rectangle shaped or a round ignitor. That is want the problem is 95% of the time. It is pretty easy to do. The floor of the stove will come right out and it probably has two screws in the back corners you can see. Remove them and the floor will lift out and you can see the burner and the ignitor.
Jun 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
How do I clean a GE gas range (self-cleaning oven?)
What do i clean the burners with ? the round surfers is harder to scrub, what do you advice .
Apr 20, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
MAYTAG GAS RANGE MODEL # MGR5765QDW
sounds like a bad bake ignitor, common issue with all gas stoves.
Nov 05, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Model JBP79 FFFcode
FFF Control Error, Failed EEPROM Replace Control
Unfortunately when you get this code the oven control will need to be replaced.
Nov 12, 2007 | GE Profile Spectra JBP95 Electric Kitchen...
GE Spectra JBP78 Electric Kitchen Range Logo
587 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
