Question about Belkin (f6h375-usb) UPS System
Only my UPS goes down!
I have a Belkin 375VA UPS. It frequently loses power even though everything not connected to it remains up. I am running Vista but currently do not have the Belkin software running. I also do not have the UPS plugged into my machine via USB. I just have the unit plugged into the wall and my computer and 2 monitors plugged into it.
I have no idea how to tell if I have too much plugged into it. Could that be the problem? I have spoken with Belkin tech support twice. They have had me return the unit for replacement. I'm on #3.
Any suggestions?
  • 64 Answers
115V x 8 amps = 920VA x .778 power factor = 717.76 watts Start up 50 watts = 667.76 watts You need a 1000VA UPS. The one you have is way too small.
That 375 UPS is good for answering machines, plus it does not have AVR technology. Your UPS power supply is 250Watts, and the monitor is at least 150 watts and the printer is another 200 watts....=600watts
So that 375VA ups x.778= 291.75 watts. That hardware of yours is killing your very very very cheap UPS. It is obvious that Tech support has no application engineering support. Well I did all the work for them.
I suggest a 1000VA or a 1500VA for more time.
check out my web page, I only sell to dealers, but I will help you out.
Posted on Sep 06, 2009
Belkin n1 vision is shutting down
Is the Belkin plugged into a power strip or UPS? Try another AC outlet. Has the AC jack,plug in the rear or the Belkin been damaged due to pulling on the AC cord, causing a lose connection? Is your computer shut down at night? No Hibernate, No Sleep? Are their setting for the Belkin to shut down/timeout after a certain idle time? Here's a user manual:
Feb 14, 2013 | Belkin N1 Vision Router
I use a Belkin Surge Protector UPS 600VA, and run Win 7 64 bits. In "System Configuration", "Services" tab, Belkin APmonitor is stopped, and Belkin APMRMI is running. Nothing shows on...
2 scenarios will either play out at the end of the day:
1. During power outage, your UPS will continue to supply backup power for the number of is built/designed to do for your PC after which it shuts down and your PC due to lack of power shuts down too.
2. if you've programmed your PC to shut down after say a short period it idles, your PC will shut down even though your UPS is still fully operational.
A third approach is to sync the situation/scenario you envisage by powering off your UPS power supply at the mains/wall receptacle.
Watch what happens next by leaving your PC idle but still connected to the UPS still powered on (but without the mains power supply to it)
Oct 06, 2017 | Computers & Internet
How do i connect my ups to my pc
Connect your PC power plug to the UPS, connect the UPS to the mains. Connect the usb lead from the UPS to your PC. Install the software on your PC. When you lose mains power the UPS will keep your PC alive long enough for an ordered shutdown.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
Feb 19, 2011 | Belkin (F6C800-UNV-PL) UPS System
No power whatsoever. no lights. I have it plugged in and hit the reset button but nothing. I have disconnected and reconnected the battery nothing. Is it possible the thing is dead?
Depending on how old it is, it is possible. You might want to check on replacement battery for it. It may be cheaper to replace the whole unit, I don't know, i haven't priced one lately. If you do replace the battery, be careful or have someone do it who has done it before.
Jan 18, 2011 | Belkin 375VA 200W UPS (WMM79847) UPS...
Belkin Nimo wireless router internet drop outs
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WAP2 or WAP, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, ard welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply) .
4. Check the channels of the wireless routers and access points in your area and and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize the interference with your wireless router from the wireless routers and access points in your area.
Sep 29, 2009 | Belkin (F5D5231-4) Router
Suddenly everything lost power and the CPS1100AVR UPS unit started beeping and clicking while switching back-and-forth from 'powered' to 'battery'. Everything connected powered off, then on, then off,
Most UPS's will check the voltage of the battery periodically when the UPS is running and all is well with the AC power. If the test returns a "fail" on the voltage of the battery, many UPS's will start acting strange. It sounds like this may be the case with yours. The batteries can be changed by removing the access door on the bottom of the unit. A phillip screw holds it in. Here's a link to the battery set:
May 23, 2009 | Cybernet Systems CyberPower 1100AVR...
The monitor goes into power save mode and the ups disconnect
It should work, make sure each profile is set the same way. Keep in mind you should still be able to utilize your standby feature, and your screensaver as well.
Nov 13, 2008 | Belkin (F6C800-UNV-PL) UPS System
I have got rid of my Belkin UPS but am unable to unstall the software "Belkin BulldogPlus" even though the uninstall program says that uninstall was successful. I have put disks (original XP...
ok my friend
i guess u can try using (jv16 power tools) to remove this program
download jv16 and then use it to remove the program
if u need any other help please let me know
Sep 04, 2008 | Belkin Computers & Internet
I keep losing my signal intermittently on my Belkin MIMO plus wireless router it constantly goes up and down from 1.0 Mbps to 54.0 Mbps interferring with my connection. The router is connected to my...
your gonna need the belkin router amplifier for that if its too far away from the router its gonna loose signal and cause you to intermittinly loose signal and connection ./... you could also contact belkin support at
Jul 19, 2008 | Belkin Computers & Internet
Belkin (f6h375-usb) UPS System Logo
127 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
