Question about Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point
Cable modem the modem send light dont work when the router is hooked up to it but when it goes directly to the computer it works fine was working with router before i dont know what happen to tryed resetting and differnt cables but no luck any advise would be helpful thank you .
    Genius:
  • 1,224 Answers
Sometimes this problem is just a simple one i found out threw service provider that if you unplug your router for 30 seconds and replug back in this relieves all the packets that have bound up on your system to give you a hang up
basically i like to call it flushing the system packets cause there always running like never ending pot of gold
Posted on May 21, 2008
I have connected the router to the modem, my laptop gets the signal but it keeps telling me that there is no connection to the internet??? what do i need to do in order do? o and i dont have the cable that...
You will have to hook everything up in a very strict order. First turn everything off. Plug your modem in and let all the lights come on. Then you need to run that wire to your router and plug it in let all the lights come on if the wireless light comes on then you know it is putting out wireless. restart the laptop and then try to connect to the wireless. If that does not work you will have to reset the router and enable wireless conections and this is just a most likely answer it could be many things.
If this dont work send me email to
B52computers@gmail.com and I will try to help
Chris Thrash
Jan 20, 2011 | NetGear DG834G Router
Yesterday had Cable Internet hooked up at new house--when done modem had all lights green, and wireless router connected and worked fine. Now router won't connect to Internet, and USB connection direct to...
Sounds like a problem with your cable connection. Check your coaxial cable, and the splitter from where the cable enters your home. The tech will use a signal meter to measure the quality of your cable, and then replace the wiring if necessary.
Jan 04, 2011 | Motorola Computers & Internet
I have a WBR-2310 D-Link wireless router. Yesterday it started not getting the signal from the Comcast cable modem. I can connect the cable modum direct to this computer and it works fine. But the gold...
If ever I have had a problem with my D-Link I have contacted them directly and they have solved it over the phone for me. There is an initial answer message that states that you MAY be charged $40 for the help ... but I have never been charged. It is a brilliant service.
phone 0800 900900. I hope that this helps you.
Oct 29, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
I hooked up everything right modem to router, router to computer. but i still cant get internet to my computer. if i hook my modem directly to the compiter it works fine but not through the router
Some ISPs (Internet Service Providers) limit you to *ONE* unique computer connected through the cable-modem (or DSL-modem).
Turn the cable-modem off.
Turn the router off.
Connect the cable-modem to the router, via an Ethernet cable to the 'WAN' port on the router.
Turn the cable-modem on.
Turn the router on.
Connect, via an Ethernet cable, from one of the 'LAN' ports on the router to your computer.
Restart your computer.
You should be OK.
If not, telephone your ISP, and get them to trouble-shoot from "their" end towards your end.
Sep 20, 2010 | Linksys Wireless-G WRT54G Router
My internet works fine when i hook it up directly from the modem, but when i try to use the router it says no internet connection. cables all work fine. My lights are all lit like they are suppose to be.
Are you trying to install the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 15, 2010 | Linksys Wireless-N WRT150N Router
Automatic installation failure
unless you were switching from DSL to cable Broadband, there usually wouldnt be much reason to rerun the software just because you got a new computer. when you ran the software the first time on the other computer, it was the router you were setting up, not the computer.
if the new computer is not getting internet when hooked to the router, try this.
1.turn off computer and unplug electricity from router and cable modem.
2. connect all ethernet cable to the right location. ethernet from modem to router goes in the non-numbered port, ethernet from your computer to router goes in numbered port.
3. plug in cable modem electricity first, wait for all its lights to come on like normal.(this part is important). the ethernet light on the modem (it might be labeled ethernet, link, pc link, or something similar) will not be lit, this is normal until you get to the next step
4. plug in the router electricity, give the router 2-3 minutes to get connected to the modem.
5. start up the computer, wait for everything to fully load and check internet again.
hope this helps.
Mar 21, 2009 | Siemens SpeedStream 2624 (SS2624) Wireless...
I unplugged the cable connected to my desktop and the wireless function stopped working
You must always have a 'host' adaptor whether you want a LAN or a WAN. Go to your configuration utility or control panel via your Run command to set or view your options. Steve Medley
Nov 07, 2008 | Belkin (F5D8231-4) Wireless Router...
Can't seem to hook up D-link router to my Arris cable properly
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
May 29, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Hooking up rounter to cox cable
hello!
-- is the router working fine before or is it a brand new router
note:
May 27, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point Logo
61 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
