Question about Whirlpool Dryers
Whirlpool duet gas dryer
After it runs for about 20 to 25 minutes it shuts itself off and the display says F70. It is about a month old
  • 868 Answers
Call your warranty service,thats what its for.
Posted on May 21, 2008
Whirlpool F 70 error code indicates communication problem between the component electronics and the control electronics.
Disconnect power to the machine for about 30 minutes, reconnect it, and try again. If it doesnt correct it self change control board.
Oct 08, 2014 | Whirlpool Dryers
Whirlpool Duet Gas Dryer, runs about 2 seconds then shuts down. Time remaining display flashes
raoul answered just now
come fare il reset della scheda della lavastoviglie whirlpool ADP 5555 per cancellare un errore dovuto a sensore sporco? non vorrei chiamare l assistenza solo per questo.
Feb 06, 2014 | Whirlpool Duet GHW9150P Front Load Washer
F70 was displayed on Whirlpool duet dryer what does F 70 mean
Isnt F70, really is F07... this means Motor Control Unit Error
Description: The Central Control Unit has detected a short in the motor control unit. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
Check or Repais:
- Check wire harness connections between the Drive Motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
- Check the MCU
- Check the Drive Motor
- Check the Wire Harness
Hope helps.
Aug 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The display indicates "F 70"
you will need to disconnect power to the machine for about 30 minutes, reconnect it, and try again. it will work and here is a thread I ran across, seems to be a big problem. Good Luck Tim:
Feb 22, 2011 | Dryers
I have a whirlpool duet gas dryer and the burner turns on for about 2-3 minutes then shuts off for about a minute then cyle repeats itself. Any ideas?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
Oct 14, 2010 | Whirlpool GGW9200L Gas Dryer
My dryer panel is blinking F70 and smells of gas
F70 code is warning you that the exhaust vent airflow is insufficient.
  • Check the exhaust hose in the rear of the machine and make sure it it not crushed or kinked. The vent pipe should be rigid metal not flexible foil or flexible plastic.
  • If using dryer sheets, rinse the lint filter with hot water to remove filmy residue that can restrict airflow through the filter
  • Inspect the outside vent hood for any blockages.
  • The exhaust system may need cleaning. Cleaning kits are available at most home improvement centers.
May 06, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Same problem but I have a 3 week old maytag 9000 steam dryer, ran for a few minutes then turns off and display reads F 70
From everything I have read on the F70 code (can't seem to find an exact explanation of what it is) It seems like people are getting replacement dryers due to a electrical problem within the dryer control circuitry. Since it is only 3 weeks old, get it replaced. Good luck
Feb 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet gas dryer shuts off after 15 min
I cleaned out the vent that was clogged pretty good, put dryer back together (a solution I read in this blog), and now it is working fine. I was testing with bottom open.
Mar 21, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Jan 30, 2009 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Dryers Logo
105 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
