Question about Toshiba PDR-M700 Digital Camera
Card lid open
When I turn camera on I get a message card lid open. It is closed - don't know what to do
  • Anonymous Jul 10, 2008
    Same problem "Card Lid Open"
  • lin1 Sep 28, 2008
    Card lid open
  • 3,037 Answers
Try seeing if the sensor switch is still working, try pressing it down by hand and see if this fixes the error. Let me know how this works out
Posted on May 21, 2008
I need the user guide for my Vivicam 8340 digital camera, since I want to install an SD card on it but I don't know how to do it. Thank you, in advance!
The user guide is not available online as a download. However installing an SD card is usually pretty simple. On this camera, the SD card slot is on the bottom inside the compartment where the battery is housed. Simply slide the door open, and locate the slot for the memory card. The memory card should only go in one way, so don't try to force it. If it doesn't fit fairly easily try turning the card around. Remember: the gold pins on the card go into the camera!
May 05, 2011 | Cameras
Canon Si5 Lens Error message. Have tried suggestions on line
Welcome to FixYa.
There where wo reasons why do you receive a "lens error".
1. CF card slot cover or battery cover opened with camera on
2 . CF card slot cover or battery cover opened while camera was recording to CF card
In this case you have to ensure that CF card cover and battery cover is closed while camera is turn on.
You also need to be careful not to block the camera lens when turning on. Lens will have issues while retracting if your hands or even small thing that will block the lens to retrack while in motion of turning on.
Thank you for using FixYa.
Apr 08, 2011 | Cameras
Have an Olympus Stylus Tough -6000 digital camera and when I turn it on a message appears on the screen that says "card-cover Open" and it won't allow me to operate the camera. The problem is...
remove the batteries and the card from the camera and clean it with something smooth and dry ...after that reinsert the card in th ecamera several times until it is recognised..this happens when the card it is not proper inserted ..or something is meesing with the sensor that detects the cover a gentle cleaning inside will help also..
Dec 21, 2010 | Cameras
The cover on the battery and SD card opening on the camera broke off and couldn't be found on the ground. A small piece of cover and the hinge are still on the camera. When the camera is turned on a...
I imagine the only way to obtain a proper part is to send it to an approved Olympus service centre, hopefully under warranty (though I expect they would not regard this as covered).
The camera must have some way of telling that the door is open. Is there a tiny switch on the catch, or behind a little hole that something on the lid poked through? If so, perhaps you could jam it. Maybe there is a reed switch that was activated by a magnet in the lid.
I don't really see why this should be an issue for the camera to worry about, as long as things aren't falling out. My high-end Lumix pays no attention to hatches being open.
Nov 03, 2010 | Olympus FE-240 Digital Camera
Card cover open error message
You need to make sure that the memory card is correctly installed on the camera and that its door lock is closed.
Sep 05, 2009 | Olympus Stylus Verve / ?-mini Digital...
Card cover open display wont come off the lid is a lil open how can i fix its for an olympus digital camera 6.0 mp
Check you memory card slot cover.. it shuldnt b closed properly...
Close it properly and try it!
Sep 22, 2008 | Cameras
"Card-Cover Open" Warning
Have same problem when camera is used underwater. Take out battery and xd card. Put camera in front of fan with lid open and facing fan for several hours.
May 23, 2008 | Olympus Stylus 790SW Digital Camera
My printer doesn't recognize that I've closed the scanner lid
there is a switch on the lid, look for a protruding piece of plastic which corresponds to a hole in the machine if you put a flat screw driver ( or a business card ) in the hole it should push on a micro switch, if the message goes away when you do that then the switch needs to be adjusted, remove covers and adjust lever.
Feb 11, 2008 | Lexmark X1150 All-In-One InkJet Printer
Error message: battery cover open. This message appears in the window and will not let me operate camera until problem is resolved. The cover is closed, but the message will not go away. I have re-set...
try closing the battery cover. if you do not know what that is, it is where the sd card and the battery are held. the cover for that is the battery cover. if it is closed, and still not working, make sure its closed all the way, if it is, take it to best buy or circut city or any other electronics store and ask them.
Dec 12, 2007 | Gateway DC-T50 Digital Camera
Toshiba PDR-M700 Digital Camera Logo
41 people viewed this question
Top Toshiba Cameras Experts
john milligan
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
