Question about Pioneer Audio Players & Recorders
1970's pioneer amplifier comes on, sound comes out of speakers for a minute then gradually gets quieter and fades out all together
  • 4,234 Answers
Without the specific make and model, it is difficult to rpovide specifics. But, your unit neds a general overhaul. There are probably numerous poor solder joints that need to be fixed as well as capacitors that should be replaced. Expect a repair bill in the $100 range.
Dan
Posted on May 21, 2008
How do I connect these two together so I hear it from my surround sound?
You'll need some type of amplifier to drive the speakers. The Samsung TVs mostly have a line out and a headphone out, but that wont drive speakers unless they are powered speakers like PC speakers or a powered sound bar. (Like the Pioneer SP-SB23W soundbar/subwoofer) If you have some of these get a mini 1/8" stereo plug to RCA plug adapter from BestBuy or similar. If you have PC type speakers, You'll need a 1/8" mini stereo patch cord to go from the line out to the speaker input. (Set the audio out on the TV to variable so you can control the volume with the TV volume.)
Jan 15, 2016 | Pioneer Audio Players & Recorders
Pioneer djm 800 will only play through 2 channels on mono??
try to clean your fader with contact cleaner and move it many times after cleaning -check your connection plugs(buy it from radio shack near you.
Apr 11, 2009 | Audio Players & Recorders
Volume fade
Check to be sure there are no speaker wires touching ground, and that the wires are connected in phase to the head unit.
Front Speakers 5 1/4" Doors Left Front (+) Green Left Front (-) Black/White Right Front (+) White/Red Right Front (-) Black/White Rear Speakers 6" x 9" Rear Deck Left Rear (+) Pink/Red Left Rear (-) Pink/Blue Right Rear (+) Pink/Light Blue Right Rear (-) Green/Red
The symptoms you are relaying definately sound like an internal amplifier problem. It is fading in and out for a reason - usually due to heat.
Have you had the radio bench tested (seperate from the car) to eliminate the car as being the culprit?
Since the radio was run with damaged speakers originally, the output or amplifier power supply on the amplifier may be bad.
As an alternative to repairing, I would suggest investing in a small 2 channel amplifier to power the speakers.
The radios claim 50W per channel, but in reality give 12-15W RMS power.
A dedicated amplifier with built in crossovers and gain adjustments will prolong the life of your speakers and add to the tonal qualities of your new speakers. Instead of turning up the volume on the head Unit, and sending out a distorted signal that will blow your speakers, an amplifier will give more CLEAN power to them, so it will be louder at a lower volume setting.
This will bypass the internal amplifier on the radio, and send a Low Level signal ONLY thru a set of RCA cables.
Good Luck!!
Jan 10, 2009 | Car Audio & Video
Car Audio Fade
sounds like you got a bad stereo. it happens. i've i had the same thing happen, but the volume went up instead of down. check all the wires and make SURE they are all hooked up right.
Jan 10, 2009 | 2000 Jaguar Vanden Plas
NAD C370 Amplifier
This sounds like a problem with the protection circuit, and/or the speaker relays. More specifically, a capacitor within those circuits that is not behaving properly. I strongly suggest having it looked at ASAP.
Sep 15, 2008 | NAD C370 2-Channel Amplifier
Pioneer gm-5000t amp
If the amplifier is powering, but no sound, try disconnecting the speaker outputs from the amplifier and connecting a test speaker to the output channel. If you get sound, then one of the speakers in the car may be bad or shorted out. That can be confirmed with a voltmeter. If still no sound, then you need to check the input to the amplifier. Disconnecting the RCA cable from the input and testing that with an amplified speaker like you can get from Radio Shack will allow you to make sure that the amp is getting signal from your radio.
Jul 13, 2008 | Pioneer GM-5000T Car Audio Amplifier
Car radio
HI BBunk,
Sounds like the dead speaker took out the amplifier output too. You may need a new head unit.
Nov 13, 2007 | Elliott's Car Radio 50C564797 Car Speaker
Head unit is on but no sound coming out
I Had That Happen To Me Its A Ground Problem. Check The Negtive Speaker Terminal And The Ground Wire Runing To The HeadUnit This Should Fix It.
Dec 17, 2006 | Kenwood KAC-9152D Car Audio Amplifier
77 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
