Replacement bulb I have been looking for a replacement bulb my HP DLP tv ( part #C2114-80001) for a couple days now and have had no luck. Do you have any ideas where I might be able to find one?
  • 8,617 Answers
Try www.alltvlamps.com they should have the lamp you need.
Posted on May 21, 2008
How does a ballast for a hitachi ultravision dlp tv look
Anon, the bulb/lamp plugs into the ballast, The attached videos shows the ballast and location near the end of the video. Check the attached links. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HITACHI how to replace your enclosure guide
Mitsubishi Toshiba Samsung DLP TV Bulb Won Turn On DIY Easy DLP Ballast...
hitachi ultravision dlp tv replacement ballast Google Search
Apr 20, 2016 | Hitachi Televison & Video
WHY DOESSAMSUNG DLP BULB KEEPS BLOWING
When replacing the bulb, it is will be best to replace the ballast also. Make sure that the bulb is of original replacement part.
Nov 29, 2012 | Samsung DLP HL-P5663W 56" TV
Where can I find a Ballast for HP ID5220 DLP TV?
It looks as if you have to return it personally, and have them fix it. I saw nothing on the HP ID5220 DLP TV in the ballast lists. Sorry, man. Wish I could be of more help. Maybe someone else has a better site, or connections, that can help you. Your best bet is to get professional help with someone, like the company that manufactures the hardware.
Mar 13, 2011 | HP Televison & Video
SAMSUNG DLP SLIM 50" AFTER I TURN IT OFF IT WONT TURN BACK ON TILL 30 TO 50 MINS LATER THE THREE LIGHTS IN THE FRONT BLINK. iT ACTS LIKE ITS GONA TURN ON BUT IT DOESNT IT JUST MAKES THE NOISE AND FLASHING...
Chris,
I had the same problem. I bought my tv at Best Buy and my warranty included a new bulb for the lamp. They only last about 2 yrs or so depending on how much you watch the tv. You can also buy replacement bulbs online that don't cost too much. BUT, you will need to replace every couple of years. The things you listed are exactly what happens when the bulb goes out. Hope this helps!
Sep 14, 2010 | Samsung 50" Slim-Depth DLP HDTV
MY TV TURNS ON AND STAYS ON FOR 5SECONDS AND THEN THE SCREEN TURNS BLACK BUT CAN STILL HEAR THE SHOW PLAYING. TURNED IT OFF AND EVEN UNPLUGGED IT FOR ABOUT 5 MINUTES, BUT STILL THE SAME THING HAPPENS.
the lamp is likely bad .. they only work a few thousand hours .. then must be replaced .. your lamp can cost a couple of hundred (maybe even more if bought locally) .. here is one for less if you have someone handy that can change it.......
http://www.purelandsupply.com/50PL9126D-37-Bulb-Philips-DLP-TV-Bulbs.html
..... of course make sure power is off (unplugged) and make sure things are not hot .. there is usually a little cubby in the back where the lamp is located .. you an see what the lamp looks like at the above URL .. dont get finger prints on the bulb . that will cause it to crack when hot .. if you are unable to change the bulb then a call to philips service should do the trick. make sure you ask what the bulb replacement and labor will cost ..
Jan 27, 2010 | Philips 50PL9126D/37B 50" DLP TV
Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Jul 11, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
RCA SCENIUM MODEL D44LPW134 IS MY BULB BLOWN?
If this is a DLP, which I believe it is, your bulb is blown. Look for an indicator light on the front of the tv. After you hear the bulb try to warm up two or three times the indicator light should come on and stay on steady.
I own a 57" Mitsubishi DLP and have replaced the bulb three times now. It was the latest and greatest technology when I bought it, but knowing what I know, I dont think I would buy another DLP.
By the way, get the bulb number then check ebay, by far the best prices.
Jun 02, 2009 | RCA Scenium HD50LPW52 Replacement Lamp
TV shuts itself off after a couple minutes of being on.
One must be very careful of the quality of the replacement lamp. Many of the cheap 'deals' on the web for replacement lamps are substandard. I always recommend that replacement bulbs be the original manufacturers bulb.
Apr 30, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
50? Samsung DLP TV Model #HLR-5067W
Did you use an original replacement lamp or an aftermarket replacement? From the price you give, it sounds like an aftermarket lamp, which are notoriously buggy and the problem may be with the lamp. If not, the lamp driver is your next likely culprit. It is also called a lamp power supply or lamp ballast.
Oct 19, 2008 | Samsung DLP HL-P5663W 56" TV
Hewitt Packard high definition DLP tv Product #EX543AA#ABA need part, hp no longer carries them.
I have a brand new L2114a lamp for sale. I paid 299 plus shipping on ebay but it turned out to be the wrong one (despite what the manual says). I ordered the correct one I needed from HP. I am willing to part with it for 200. I can send pictures of the lamp and the box and the reciept. This is a BRAND NEW LAMP.
This lamp works in the following televisions and replaces the lamps listed below:
HP Pavilion md5020n 50-inch High Definition DLP TV L1735A
HP Pavilion md5820n 58-inch High Definition DLP TV L1736A
HP Pavilion md6580n 65-inch High Definition DLP TV L1737A
HP Pavilion md5880n 58-inch High Definition DLP TV L1798A
Jan 28, 2008 | Televison & Video
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
